Question about HP OfficeJet G55 All-In-One InkJet Printer
Print configuration page on hp 400 m425 - HP OfficeJet G55 All-In-One InkJet Printer
2 Suggested Answers
SOURCE:
  • 313 Answers
SOURCE: hp 3005dn prints blank pages, even the configuration pages
if you haven't any error message then you may have a problem in laser shutter, check and reseat your catrtidge, or you have a problem in your DC Controller
Posted on Apr 01, 2010
I Purchased NEW THIS PRODUCT HP LASER JET PRO 400
default must be no password , here are the steps to reset the printer
NVRAM reset for the HP LaserJet 400 colorMFP M475dn (Confirmed functional) 1: Print configuration page before beginning reset
2: Disconnect all cables except for power
3: While printer is in ready state, note the position of "Ready" message on the screen (Probably bottom right)
4: Power off the printer via power button
5: Touch the location on the screen where "Ready" message appeared.
6: while touching the screen, power on the printer. Continue to hold the screen.
7: When "Memory Limit Reached" message appears, release the screen.
8: Printer will reboot, clean and calibrate
9: Return cables to their appropriate ports
10: Print configuration page to confirm settings are cleared. Restore settings desired manually.
Finally have access back!
Mar 08, 2017 | HP Computers & Internet
Which is the best printer copier
Depends on if you want color or black and white, how many pages you are going to print. If you want color, look at one of the HP X series inkjet units, cost per page way lower than laser. If you are looking only black and white, small office I would buy an HP M425.
Sep 06, 2014 | HP Office Equipment & Supplies
Hp cm4540 configration device code
Not sure if you just want to print a configuration or if you have an error code. To print a configuration page
  1. Scroll to and touch the Administration button.
    1. Open the following menus:
    1. Reports
    • Configuration/Status Pages
    • Configuration Page
  • Touch the Print button to print the report, or touch the View button to view the report on the screen. The report consists of several pages.
    I
    Aug 24, 2014 | HP LaserJet Office Equipment & Supplies
    The logo in my print job is color Green but its coming out in color blue. what is the problem
    Check the yellow toner cartridge, printing a configuration page.
    Configuration page
    The Configuration page lists the current settings and properties of the printer. You can print a
    Configuration page from the printer or HP Toolbox. To print the Configuration page from the printer,
    complete the following steps.
    1 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select the Reports menu.
    2 Press the button (SELECT).
    3 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select Config report.
    4 Press the button (SELECT) to print the Configuration page.
    Yellow print OK?
    No? try print with another yellow toner cartridge (Q6002A).
    Aug 10, 2011 | HP Color LaserJet 2600n Printer
    Printing only symbols and numbers
    The two most typical causes for this type of behaviour are:
    1. wrong print driver being used. Ensure that you are either using the proper HP print driver for the 4600 or the HP Universal Print driver.
    2. Bad communication cable, loose connectors or dirty connectors.
    Try printing the configuration page from the control panel. If that prints ok then it is more likely the two above causes. If the configuration page prints wrong then you probalby have a formatter issue or memory issue.
    To print the configuration page, press the down arrow until it reads information, press the check mark, then use the down arrow until configuration page shows then press the check mark again.
    Jul 01, 2011 | HP LaserJet 4600 Printer
    How to wirelessly print to HP 2410v Photosmart printer
    This is the official how-to for network setup from HP:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00781863&lc=en&dlc=&cc=us&product=303759&lang=
    Introduction Print the network configuration page and obtain the IP address, subnet mask, and default gateway address for the printer. Printing the network configuration page
    1. Press the Setup button.
    2. Press the arrow buttons to select Network and then press OK .
    3. Press the arrow buttons to select Print Network Configuration Page and then press OK . The Network Configuration Page prints.
    Obtaining the IP address, subnet mask, and default gateway address The IP address, subnet mask, and default gateway address are printed on the Network Configuration Page
    The manual link is here:
    http://h10032.www1.hp.com/ctg/Manual/bpu70241.pdf
    Hope this helps:
    WizardRepair
    Jul 18, 2009 | HP Office Equipment & Supplies
    Lens Error M425-12 (7F80) on HP M425
    Try taking the SD card out and restart the camera. Also, make sure the batteries are fully charged. There is also a firmware upgrade indicating a problem with the lens getting stuck.
    May 13, 2008 | HP Photosmart M425 Digital Camera (5MP,...
    Plz help me am in trouble
    Network Configuration page
    NOTE The Network Configuration page is only available on the HP LaserJet p2015n,
    HP LaserJet p215tn, and HP LaserJet p215nw printers.
    A Network Configuration page prints whenever a printer configuration page is printed. You
    can also print a Network Configuration page by pressing the network Reset button at the
    back of the printer
    The Network Configuration page provides information about the network configuration,
    including the IP address, firmware revision, network statistics, protocol information, and so
    on. The Network Configuration page automatically prints when you print a configuration
    ENWW Printer information pages 37
    Using the HP Toolbox
    The HP Toolbox is a Web-based program that you can use for the following tasks:
    ● Check the printer status.
    ● Configure the printer settings.
    ● View troubleshooting information.
    ● View online documentation.
    You can view the HP Toolbox when the printer is directly connected to your computer or
    when you are using a supported network connection. You must have performed a complete
    software installation to use the HP Toolbox.
    NOTE You do not have to have Internet access to open and use the HP Toolbox. However, if you
    click a link in the Other Links area, you must have Internet access in order to go to the site
    associated with the link. See Other links for more information.
    To install the HP Toolbox, you must install the TCP/IP protocol and the most recent version
    of the Java™ Virtual Machine on the computer. You must also install the DOT4 protocol for
    all USB connections, LPT connections for Windows 2000 and Windows XP, and LPT1
    connections for Windows 98 S.E., Windows Me, and Windows NT 4.0. See the system
    administrator or computer manufacturer's documentation for more information about
    installing the TCP/IP protocol and the DOT4 protocol.
    Jan 22, 2008 | HP LaserJet P2015dn Printer
    HP OfficeJet G55 All-In-One InkJet Printer Logo
    41 people viewed this question
    Clive
    Clive
    Ekse
    Thomas F. Schneider
