Remove the whole top of valve, put on the ground and push down with your feet, then drive out the pin in the handle, the whole thing will come apart
Shut off system take all screws out of multiport remove top make sure to make a mental note of which direction its pointing like filter or backwash check to see if gasket needs to be cemented in
SOURCE: multi-valves on hayward sand filter mixed up
Key Cover Assy needs new spider gasket. If it is a newer model the gasket is made into the key cover and it will have to be replaced
SOURCE: While my hayward filter is on ''filter'' the discharge is leaking
u need to replace the spoke gasket.
SOURCE: problems with hayward vari flow valve.
It sounds like you might just need to replace your valve. They are fairly inexpensive. Try contacting this company. They will be able to tell you exactly what you need to do (free advice) and will have the parts necessary if you do need to buy a new pool filter or new parts.
Backyard City Pools 888-751-0101 or www.backyardcity.com
Just let them know that you need to speak with the person in charge of pools. He will be able to help.
SOURCE: My Hayward Swimpro Sand filter is not backwashing
Be sure it is not plumbed backwards and be sure you got a sand valve as a DE plumbs the other way.
SOURCE: My hayward s230t sand filter is leaking out the
If you remove the top of the valve you will see a spider gasket that has pulled out of place. remove this and clean and dry throughly. Add a small amount of silicone sealer to the bottom of a new one and install in groves then replace top of valve and let sit for a couple of hours. That should fix. If not you will need to replace the top half of the valve also.
