Question about Canon ZR100 Mini DV Digital Camcorder
Zr100 distorted display
In playback mode, the screen is showing a distorted image. The content is there, but is in vertical sections on the screen...like a portion of the middle part or a portion of the right side. Any suggestions on how this can be corrected?
SOURCE:
Gryfox
  • 216 Answers
SOURCE: Vertical lines
This is a defect in the CCD ( light sensor ) - check with Canon and they'll replace it free of charge even if the camcorder is out of warranty.
Posted on Jun 16, 2006
SOURCE: cannot finalize dvd-r
Have solved the finalized problem by simply looking on the Canon website and read that you have to plug the camera into the wall to do it! If only they simply put this in the manual!!! Goodluck!
Posted on Mar 08, 2008
Ajkill
  • 2035 Answers
SOURCE: playback
You need to check the what format are is used by the can coder if in the audio mode you cannot see the video , or the tape may copyright protected...................To trouble shoot use this link to get the manual:
http://www.css.washington.edu/gallery/albums/userpics/10136/ZR100IM-EN.pdf
good luck.................
Posted on Jun 05, 2008
SOURCE: Camcorder doesn't record I just see a blank screen with multicoloured vertical lines
It is a manufacturing defect in a chip. Canon is replacing it irrespective of warranty. See below URL:
http://www.imaging-resource.com/NEWS/1128632808.html
Posted on Jun 12, 2008
SOURCE: In Camera mode, only streaky vertical lines visible on screen
Found the company,
UK only (bound to others round the world)
PLYMCARE
Marshall Road,
Plymton,
Plymouth
Devon
PL7 1 YB
01752 303 555
FREE OF CHARGE if it is the CCD
Posted on Aug 14, 2008
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Screen shows no image for picture taking or playback
Is this Sony DSC-T1 camera or some other model? let me know to help you out.
Jun 15, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
LCD screen purple and distorted in Shooting mode
There is recall on this model for this problem, Go to Canon USA web site, Look up Service advisory, CCD malfunction N/C to repair.
Feb 24, 2009 | Canon PowerShot A80 Digital Camera
Showing file names on the screen
while your camera is in playback mode.. check the option to show the OSD which'll also show ur image file name...
Mar 12, 2008 | Olympus Camedia C-765 Digital Camera
Double picture
your problem is in vertical section. 1 any capacitor in vertical section is defective. 2 transistors in output ckt might be defective 3 loose contact in vertical section. 4 problem in feed back circuit(if you are a technical person )
Sep 14, 2007 | Emerson EWF2704 TV
Black horizontal lines across bottom 1/3 of screen
This is due to vertical section failure. Change the vertical supply rectifier diode and supply filters. Then check zener diode leakage in pumpup circuit section. Also check any electrolytic capacitors leakage in vertical section. If it is old model tv change vertical height, vertical lenearity presets also. I hope given details useful to you.
Aug 23, 2007 | GE 27GT722 27" TV
What is the focusing screen display?
There are two display modes newly added for the DiMAGE 7i, grid and scale. The grid mode is to show a grid over the entire screen. This makes it easy to align the camera to objects vertically or horizontally. In the scale display mode, horizontal and vertical lines cross at the image center to divide the view to four sections, and each axis is scaled. This function is useful for close-up photography. The grid or scale on display is not recorded.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Canon ZR100 Mini DV Digital Camcorder Logo
54 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
