Question about Tannoy Sensys 7 Speaker
No sound from subwoofer
I have a subwoofer connected to the sub out jack of my reciever via a Monster cable. When I powered the unit up, there was no sound from the subwoofer, only the mains (2 speakers). I checked the connection, and tweaked the subwoofer controls, but still no sound. What have I overlooked?
  • 749 Answers
Have you checked for the continuity of the wirings? check for the resistance of your speaker from it jack..... it should measure close to 8ohms or 4ohms using a digital multimeter (DMM). check also the sub out jack of your reciever if there is a signal from it using your main speakers if they come with jacks also (turn the volume low to prevent damage to other speakers you connect on it!
Posted on Nov 17, 2007
Kenwood vr606 reciever shutting off subwoofer and centre speaker simultaneously after few minutes/seconds of powering on. WHat's the cause?
The receiver's out put sections are grouped in pairs. Front left and right in one output, rear left and right in second output, and center channel and sub output on the third. Sounds like a semiconductor or semiconductors have gone bad in the center & sub output.
Nov 19, 2015 | Kenwood VR-606 Receiver
Kenwood SW-32HT Subwoofer Dropping sound Yamaha Reciever
Several possible answers. First - is that the Yamaha has a fault that is sending a signal with too much power on it. And the sub detects this and switches off.
Second - either the Receiver or Sub is switching off when no audio is present. A setting problem?
Third - the sub has a fault, possible overload, and goes to standby for safety.
Jul 01, 2017 | Audio Players & Recorders
Hi ive got a b&w as2 subwoofer but theres no sound? the power light works but my denon recievers not picking up the sub is there a fuse in the sub which may have blown ive tried all the settings on...
Are you running this subwoofer via an LFE (RCA line level) connection, or via high level (speaker lines in and out of the subwoofer)? There may be different ways to hook up this unit and it would be helpful to know how you have the unit connected. Thanks!
May 04, 2011 | B&W Audio Players & Recorders
Can i put an extra sub woofer on my lg da3525 via the woofer out socket and what plug do i require to do this
How to Connect 2 Subwoofers to One Receiver
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver
Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores.
2 RCA subwoofer cables
2 subwoofers
Instructions
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
Have a nice day...
Feb 19, 2011 | LG DA-3525 Theater System
From reciever output to sub input only load hum.but if connected to input does work some. also if you move around RCA input connection hum will stop, and you will get some bass
You have a RCA input short, replace with new monster RCA cables tighten any screws, unit would need internal soldering possibly. You may need to get Serviced or fix on your own.
Apr 08, 2010 | Audio Players & Recorders
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Sub doesnt do anything while plugged in ( Sunfire mk II)
Some subwoofers can sense the signal on their input and will only start when there's enough signal for long enough time for them to turn on the amp.
Try seting the "subwoofer signal out" on your reciever a bit higher, see if it does the trick, if not, try it with some other source (e.g. an mp3 or CD/DVD player) plugged directly into the subwoofer. If it still doesn't work, there's some other problem with your sub (bad connection inside sub, sub amplifier problems, maybe there's another fuse for the speaker itself, try to check it out).
If it works well with an alternate signal source, the problem might be either in reciever or the signal cable that you use, but could also be something else.
good luck
3rq8 (Triarcuate)
Jul 15, 2009 | Sunfire True Sub MK II Subwoofer
No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Mar 31, 2009 | Yamaha RX-V363 Receiver
Trying to connect powered subwoofer
Try setting the speaker settings on the receiver to small.
Jan 12, 2009 | Pioneer VSX-D511 Receiver
Subwoofer VERY weak
According to the KLH manual for the 9906 "6 pack" with the BassBite sub... it says "if your sub is connected via the speaker - level terminals, your reciever must be set for "NO" subwoofer - even though you are using one. VErify proper polarity on your speaker connection wires. (red or gold to +, black or silver to -). Depending on how you have your woofer connected to the reciever, if connected to a reciever without a subwoofer out then set your reciever for LARGE speakers and turn the subwoofer setting "OFF". Failure to do so will result in little to no bass. If you do have a subwoofer out from your reciever adjust your speaker size setting to small or large speakers as appropriate. Set the recievers sub output to ON. Connecting small speakers to a reciever set for LArge speakers can result in damage to small speakers.
Hope this helps.
Jan 14, 2007 | KLH HTA-4100 System
310 people viewed this question
Top Tannoy Audio Players & Recorders Experts
 Grubhead
Grubhead
Rommel Balcita
Are you a Tannoy Audio Player and Recorder Expert? Answer questions, earn points and help others
