Question about Radio Shack Pro-82 Scanner
Where can i find a list frequencies for pro-82 weather alert?
    New Friend:
  • 160 Answers
Http://www.radioreference.com/apps/db/
Posted on Jun 30, 2009
My scanner is locked on weather alert and no buttons will work
Just take apart the scanner with a small phillips precision screwdriver and clean the pcb board of all corrosion with a dry toothbrush. And it should work like new. Shotgun 420
Jan 03, 2011 | Radio Shack Pro-82 Scanner
Where do i get a list of channels,codes or freguencies from so i can reprogram my scanner
There are several websites and books you can buy. I would try 'radio reference DOT com' for your state. Realize that your scanner CANNOT do DIGITAL, so if there is a digital system in your city/county/parish, your radio will not work. It will however still work on weather, Skywarn, ham radio frequencies and some more rurual police, fire and businesses.
Nov 09, 2010 | Radio Shack Pro-82 Scanner
I need to program a weather scanner for a pro 2018 weather scanner from rdio shack
Weather frequencies are factory programmed into the PRO-2018. Just press the weather button to start scanning them. You can also program one or more manually if you wish. For a list of NOAA weather broadcast frequencies, follow this link:
http://www.nws.noaa.gov/nwr/indexnw.htm
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69290.pdf
Bill B
Sep 05, 2010 | Radio Shack Pro-2018 Scanner
My pro-82 scanner scans threw all channels but will not pick up any frequencies?
To verify that the scanner is working properly, program one or more of the weather frequencies(162.4, 162.425, 162.45, 162,475, 162.5, 162.525, 162.55, 161.65, 161.775, 163.275) into memory and then scan. NOTE: Not all frequencies are in use in all areas, so you may need to try several. If you receive the weather broadcasts, then you may need to adjust the squelch setting on your scanner to receive local signals. You also need to verify that the frequencies programmed into the scanner are valid, active frequencies in your area. For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
If the scanner fails to receive the weather broadcasts, you need to check the antenna connections inside the unit and/or have the scanner checked/repaired by a qualified technician.
Bill B
Jul 08, 2010 | Radio Shack Pro-82 Scanner
Scanner not receiving
Performing a RESET will not clear/erase frequencies or other data programmed into the scanner. If the RESET doesn't work though, you may need to INITIALIZE the scanner. That procedure will clear all programmed data and return the scanner to its "as new" state. Need the manual for your PRO-82? You canb download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
For a comprehensive database of active frequencies in your area, visit:
Bill B
Nov 02, 2009 | Radio Shack Pro-82 Scanner
I have a radio shack weather alert pro 82
Tilt the scanner in a different direction while looking at the display. Do you see anything on the display when you look at it from a different angle? Sometimes manufacturers don't put the LCD display in correctly, and because LCD's have a really small viewing angle it can result in not seeing what is displayed.
Oct 19, 2008 | Radio Shack Pro-82 Scanner
Automatic Weather Alert
Weather Radio WR.100 was defective. Returned unit to retailor for replacement. Problem solved.
No further action required.
Krehgil
Sep 12, 2008 | Midland WR-100 Weather/RDS Radio
Need to unlock our radioshack pro 2018 200 channel desktop scanner
Easy to use right out of the box!
Explore preset frequencies used for non-trunked police/fire, aircraft, marine, NOAA weather and more. Just attach the antenna, switch it on and touch one of five buttons. With just two keystrokes, you can store a frequency you find in the 200-channel memory for later scanning or monitoring. You can also search for activity in frequency ranges you specify or program known "action" frequencies on the keyboard.
  • 1-touch search lets you find police/fire, HAM radio, marine and 7 NOAA WX frequencies fast
  • Built-in weather receiver sounds an alarm when your NOAA weather station sends an alert
  • 50-frequency search skip locks out undesired frequencies
  • Programmable by computer (requires Scanner PC Programming Kit #20-048)
Aug 06, 2008 | Computers & Internet
Pro-82 scanner
go to cityfreq.com and see if the frequencies in your area have changed. you might even need a new anteanna radio shack should have a really good one for 20 buck. a little longer than the original but good
Jun 15, 2008 | Radio Shack Pro-82 Scanner
162.550 NOAA weather frequency
If your still having the problem, it could be that the transmitter for that freq lost some of it's power, so your scanner cannot pick up a clear signal. If everything else is working ok, that's my guess. Hope this helps,,, Mechanic
Nov 15, 2007 | Radio Shack Pro-94 Scanner
Radio Shack Pro-82 Scanner Logo
101 people viewed this question
Top Radio Shack Radio Communications Experts
john milligan
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
