SOURCE: aircon works fine for 5 min after starting car
Check the compressor when you notice the smell. See if its running or not. It could also be the blower motor itself. I'd suggest checking the blower motor first off. Those usually only last a few years, and if it got wet some how it could have rusted or corroded on the inside. Or a wire broke on the inside and it shorts out to ground which could explain the smell.
SOURCE: vw passat will not run
*Assuming everything ran fine prior to running out of petrol*, the most likely cause is air in your fuel lines or fuel injectors.
For a Volkswagen, the most sure fix is to have a Volkswagen mechanic inspect and maybe clean and prime your injectors. If you are handy enough, you could possibly do this yourself, but it can be quite hard.
Also, there are some additives that claim to be able to fix this in a bottle, but there efficacy is marginal at best.
Last, this problem can sometimes work itself out, though the process of waiting for the bubbles to clear (you may have to endure many quits by your engine) can be more than frustrating.
I hope this helps.
SOURCE: engine starts and stops ticking
Sounds like oil pressure problems to me. Check to make sure your oil level is correct. If the oil level is OK get the engine checked by a professional.
