Question about HP Officejet Pro L7680 All-In-One Printer
0005FBB6 error I press the power button on the printer and it cycles thru a whole bunch of tests and always ends up with this error message which makes the printer inoperable. HP 7650 printer
Lookup how to reset the NVRAM on the printer to factory default. On the HP OfficeJet 7680 power on while pressing # and 3 on the keypad.
Posted on Jun 21, 2010
  • 102 Answers
Sounds like you need the drivers
Posted on Jun 29, 2009
I cannot print. Always in the scree The waste ink absorber is almost full; What can I do Thanks for answering
Right at the bottom of the printer case, underneath the cartridge dock, there's a whole bunch of wadding/pads packed in to soak up excess ink.
These pads need to be taken out, cleaned, dried and replaced. Then you need to reset your printer.
I've just done this on a Pixma ip2000. Basically, all the casing unclips one way or another, all needs to come off, but you don't need to remove the cartridges.
When I say it all unclips, it does save for the main casing which clips and there's screws at the front to remove.
Once dismantled, check out the area behind and below the cartridge docking area, you should see the wadding. Rubber gloves time.
Remove all the wadding, mine came in 6 pieces from an "L" shaped tank, remember where each piece goes because they're different shapes. Wash clean and dry the wadding, then replace them.
I couldn't get one piece back in, just too awkward, so I left it out. Made no difference.
Then re-assemble your printer.
Then you need to reset your printer to remove the error message. (This works for many Canon printers, yours should be the same)
1) Re-connect your printer back to the power source.
2) Press and hold the Resume button.
3) Press and hold the Power button.
4) Release the Resume button.
5) Press and release the Resume button 2 times.
6) Release the Power button and wait for the green light to stop blinking.
7) Wait for initialization to complete.
8) Press resume. (Once for power down, twice for test, 3 for eprom info, 4 for inktank reset).
9) Press Power button to accept the reset.
Sep 08, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Canon MP830 message re: waste tank full. How do I get to it to empty it or replace it.
The waste ink tank refers to may be a small well, surrounded by a
rubber ring, that sits under the cartridge when it is parked.
Place a cotton tip swab ("Q-Tip") over the hole to wick out the ink inside.
Oct 07, 2008 | Office Equipment & Supplies
On my Photosmart D7460 HP printer, the error code 0005FBB6 keeps coming on the screen saying that I have not powered down properly... not allowing me to print and setting off all sorts of flashing...
1) connect printer directly to wall
2) try different walloutlets
3) unplug the power from the back of the printer and then press and hold down the power button for 30 sec release the button. plug in the power chord..
4) if it does not work service the product
Mar 26, 2011 | HP Photosmart D7460 Printer
It begins to print then stops half way
Having the same problem here... very random... send a print job of labels and it will print the whole lot, or freeze at random points but always halfway through a label... no error message... unplug usb and replug doesnt do anything, but unplug and replug power and off it goes printing more lables but may even freeze again after only a few more have come out... also, every day the first print job of the day prints half the label and pauses for about 10 seconds then keeps going...
- Windows XP Pro SP3
- LabelWriter 400 as supplied out of the box
- Genuine DYMO labels
Jan 28, 2011 | Dymo LabelWriter 400 Thermal Printer
What does error Oxc05d0281 mean
This error message means" ink system failure " and to resolve this issue please follow these troubleshooting steps:
Unplug the printer and wait 30 seconds for power to discharge.
2. Plug in the printer.
3. Hold the CANCEL and OK buttons simultaneously, and keep them depressed while you hit the ON button. This resets the printer.
4. When the printer turns on, if you still get the error message, it's OK. Then perform the steps listed
1?Press and hold the “*” key
2?Press the “#” key and release both keys,Display should say “Enter Special Key Combo”
3?Press and release in sequence the “1”, “2” and “3” buttons
4?Press and release the right arrow button until the display says “System Configuration Menu”.
5?Press and release the “OK” button.
6?Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure
7?Press and release the “OK” button.
8?Display should say “Hardware failure status: Clear. Press OK to clear”.
9?Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
10?Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
11?Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
12?Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
13?Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
After you perform the steps listed above, when you are at the step at the end where you are pressing the cancel button until you get to the WELCOME screen, if at some point you see a message, “Inproper shutdown, hit OK”, go ahead and hit OK and the Welcome screen should appear.
One thing that is nice about this method is that it doesn't use up all your ink doing a recalibration.
The error message should not pop up so try to print a self test Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
all the best
Jun 04, 2010 | HP Photosmart 3210 Printer
Solid orange light and blinking green lights
To check the light Pattern of your printer
Click on Light and Error HP Laser jet 1012 Printer
Check the error details from the above link
Condition of the printer Action/Description Ready
The printer is ready to print. No action is necessary. Processing
The printer is receiving or processing data. Wait for the job to print. Processing...(job name) Ready LED is blinking.
This message is displayed while the printer is processing a current job, but has not begun to pick pages. Processing...(job name) From Tray XX Ready LED is blinking.
This message comes up for any job, once the printer starts to pick paper. Manual Feed or Continuable Error
The printer is attempting to Manual feed, media is not loaded in the paper tray, media loaded is the wrong size or type. Verify that the correct media is loaded.
Press and release the GO button to continue printing. Out of memory
The printer is out of memory. The page you are printing might be too complex for the printers memory capacity. Try lowering the resolution. See Understanding print quality settings for more information. Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Printer initialization
A printer initialization is taking place. No action is necessary. Fatal error
All lights are on.
  • Unplug the printer for 30 minutes, and then plug it back in.
  • If the printer still has an error, contact HP Support.
All lights are off.
  • Verify that the printer is turned on.
  • Make sure that there is power.
  • Unplug both ends of the power cord, and plug them back in.
Job Cancel
All the LEDs cycle. Canceling...(job name)
The Job Cancel button was pressed and the job is aborted. Power ON
All the LEDs cycle. Checking Paper Path and Checking Printer
This only occurs at power up. Cleaning mode/Engine test
A cleaning page or engine test page is printing.
All the LEDs cycle. Cleaning Page prints
Wait until the cleaning page is finished printing and the printer is in Ready mode. This could take up to two minutes.
Wait until the engine test page is finished printing and the printer is in Ready mode. Clearing Event Log
All the LEDs cycle.
This will happen automatically during an NVRAM Init and a cold reset. No message will be displayed. No Action is Necessary. Power On
Initializing
This occurs when the product is powered on and coming out of EDOS. No Action is Necessary.
Jan 03, 2010 | HP LaserJet 1012 Printer
Copy feature doesn't make copies
  1. Turn on the HP All-in-One.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 3 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Then when that's done, try printing, or copying items. If its still not working, check the ink and change those out and this should fix it.
May 11, 2009 | HP PhotoSmart C4180 All-in-One Color...
Error code 0005FBB6
Cloud Striver
If you have further questions email cloudstriver@gmail.com
Dec 15, 2008 | HP Officejet Pro L7680 All-In-One Printer
Ink system failure erorr 0xc18a0306
Although it did not work for me, HP offered this as a solution. If it does not work, HP indicate you have a hardware fault that can only be fixed by a service engineer repair.
1. Get the unit into the “Support Menu” by following the steps below :
A. - Press and hold the “left arrow” key.
B. - Press the “Setup” key and release both keys.
C. - Press and release the “OK” button.
Display should say “Support” and display the FW rev (something like R0616R)
2. Press and release the right arrow button until the display says “System Configuration Menu”.
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
5. Press and release the “OK” button.
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
Mar 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
Canon Pixma mp760 - won't power up or initialize
I found this on another forum it'll clear the EEPROM so give it a go.
MP750 / MP780 waste ink counter reset instructions..
1. Service menu: Menu -> Scan -> Copy -> Scan (one at a time in sequence)
2. Select "TEST MODE"
3. Select "[8] ETC.."
4. Select "[4] EEPROM CLEAR"
5. Select "[1] INK COUNT"
6. Press the [OK] button.
7. Press the [Stop/Reset] button (returns you to the TEST MOD sub-menu))
8. press the [ON/OFF] button (which resets the printer)
TIP: Don't rush the printer as it can often take considerable time to respond to your commands. Frantic button pressing will just push the printer into snail mode (ie: slow as heck!).
Patience :)
Hope that helps... :)
try that, i stole it off http://www.stevesforums.com/forums/view_topic.php?id=87060&forum_id=40 <http://www.stevesforums.com/forums/view_topic.php?id=87060&forum_id=40> -----
Feb 17, 2008 | Canon PIXMA MP760 All-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
802 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
