Question about Sansui HDLCD3210 32 in. LCD TV
Sansui 21in LCD VOLUME is lowering
Sanui 21in LCD. The volume must be up to 50 ( all the way) to hear. Used to play it on 10 to hear. What is changing or wrong?
    Sergeant:
  • 349 Answers
If you are using a set-top box for Digital reception....check the output volume setting by going to the menu then audio set up section. On standard TV transmisssions the sound is often fine but on Digital....the box sets the feeder audio signal level.
Posted on Oct 19, 2009
VERY LOW VOLUME
Replace the speakers.
Jun 09, 2015 | Sansui 32" TV
Switched iPod and now new one won't play loud
Perhaps the volume limiter is active? This is to prevent hearing damage. Apple Sound and Hearing FAQ
Jul 30, 2014 | Apple Ipod Touch 4
THE VOLUME, USING THE REMOTE AND THE TV, DOES NOT GO ABOVE 50%. THIS IS NOT LOUD ENOUGH FOR THE OWNER WHO IS HARD OF HEARING. IS THERE A WAY TO INCREASE THE VOLUME. IT IS A SANSUI MODEL #LCDCD1909.
well if the volume wont go any louder on the tv even without the remote that can be a problem what i would recommend to do is get a stereo that you could hook up to the cable or satellite or if you use digital antenna use the output of a vcr to plug into a stereo system then you can use a stereo to increase the volume.
Sep 18, 2010 | Sansui Televison & Video
Volume control on sony bravia kdl-40v5100 is not working correctly. used to be fine around setting of 30 now at 50 to hear it
If you are using a Motorola cablebox, you may need to change the Audio in the cablebox to Heavy Compression. You can find this in the cablebox Menu, Setting, Audio. Set the audio to Advanced then change the compression.
Mar 13, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Low volume on playback
The volume control on the TV does not affect the recording. However, if you were recording from a set top box, and you turned the volume down on the box and not the TV, then this would cause the problem you describe.
If this is the case, then try to keep the STB volume at maximum and only use the TV volume control.
Also, some DVD players and VCRs have a lower output than the standard TV tuner, so an increase in volume is usually needed.
You might want to try some test recordings to see what happens.
May 08, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Sharp LC-42D43U troubleshooting with the maximum volume sound
Found this on another site and it worked, had to switch back and forth a few times but it worked........
I have a Sharp LC-46D43U LCD TV. I think this is a entry level for large lcd tv's. With the volume all the way up at 60, my wife and I could barley hear the tv. I was playing around in the menu and some how have the volume at almost twice the volume. What I did was:
Go into the menu
Go to option
Go to output select
and change from fixed to variable and back to fixed. You may have to do this a few times.
Sometimes the volume goes loud after 1 try and sometimes it may take 10 or 20 tries.
But if I change any settings, even the channel sometimes the sound goes back down to where it was.
Has anyone done this, did it work for you. I don't know very much about electronics and I have now ideal why this happens.
I wonder if this is just something with my tv.
Mar 03, 2008 | Sharp LC-42D43U 42 in. LCD HDTV
Sansui HDLCD3210 32 in. LCD TV Logo
172 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
