Canon MF6500 series
I'm printing, and copying and my pages are coming out blank. My cartiridge is farely new, but i bought a new one just in case, and still am having the same problems.
Please help!!!
  • 4 more comments
  • Pompei79 Dec 20, 2007
    I'm printing, and copying and my pages are coming out blank. I've tried a new cartiridge and still have blank pages.
  • tdailey42 Jan 03, 2008
    I have the MF6500 Canon Printer and I installed a new toner cartridge and i get blank pages no matter what i do - help
  • Anonymous Jan 28, 2008
    i have the same problem with the same model
  • Anonymous Sep 30, 2008
    Same! Please help!
  • Anonymous Mar 08, 2009
    have the same problem. I have unplugged power supply and main cord. Tried resetting the machine. Printing straight from computer. Nothing works.
    Please help
  • gerobinsonco May 19, 2009
    I can't print all copies come out blank. The canon isn't very old what can I do to make it copy?
The problem could be the linkage that opens the laser safety shudder. It is very flimsy and moves from the door, through the cartridge flap mechanism to open the shudder. if the door or cart. is slightly adjar, it might not open far enough to let the laser past. The only adjustable (bendable) peice is a metal tab on the shudder itself. Access it by removing the front control panel and bend the tab so the shudder opens farther when the door is shut. Make sure it still closed when the door is open. Good luck getting the front panel off....lots of tricky snaps.
Posted on Oct 22, 2009
Take the toner cart out and reset/put it back in when it does that. Don't know what the problem is and our office has a dozen of these duds.
Posted on Feb 26, 2008
Not printing
i think your printer head is not right.
take it to a authorised service centre.
Jun 13, 2012 | Epson Stylus CX8300 Printer
HP CM2320 MFP blank pages come out with printout
Hi my hp cm2320 nf prints normally and prints when you press the color copy button. But it will printout only blank page swhen you copy black&white. You press the black&white copy button only blank pages come out. Any help
Lang Dibba, Gambia
Jan 30, 2012 | HP Laserjet CM2320nf All-In-One Color...
All new ink cartiridges and pages come out blank now
please follow these steps:
1. reseat all of the ink cartridges
2. perform a cleaning cycle using your computers maintenance options
if you are using windows go to the control panel then look for the printers and faxes folder, right click on the icon of your specified printer then left click go to printing preferences.
on printing preferences click on the tab for maintenance then look for head cleaning. do it for 3 to 5 times then test by printing nozzle check
if it does not work the possiblity is that the nozzles might have been clogged with dried inks. try spraying it with wd40 then let it dry for 3 to 4 hrs then print.
take note that doing the head cleaning you can take a considerable amount of your inks
Sep 23, 2009 | Epson Stylus C86 InkJet Printer
Fax comes out blank at the receiving fax machine.
This type of fax is "toy" buy a laser fax an get rid of all your problems
May 26, 2009 | Canon FAX-JX200
NO PRINTING
your laser shutter is not opening properly you will need to have serviced by service tech
Mar 04, 2009 | Canon Office Equipment & Supplies
Copier is not copying
possible broken charging wires (corona wires) (chargeing wire) no charge on the drum will not pull developer or broken (transfer wire) will not pull image off drum resulting in blank copy
Dec 19, 2008 | Office Equipment & Supplies
Standard steps for printer troubleshooting
I have a HP 5940 printer. I just bought a new cartridge HP98 black and my printer states that there is a cartiridge problem? I checked the box and it states that this cartridge is compatible with the printer. Please help!!
Aaliyah
Jun 19, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Blank trace appears on printed copy
replace the toner cartridge, this is a case of low toner.
NOTE: you should never clean the drum on the toner cartridge it is sensitive to light and touch.
Jan 07, 2008 | HP LaserJet 1020 Printer
PRINTING BLANK SHEETS
You need to put the test page that was printed into the scanner part of the printer and then press the scan/blue button. This is so the printer can calibrate the new ink. When you have done that the next time you turn on the printer a blank page will not be printed. When you next change ink you will have to repeat the above procedure.
Sep 01, 2007 | HP PSC 1315 All-In-One InkJet Printer
643 people viewed this question
k24674
jasbo
jasbo
