Question about IOGear MiniView DVI KVMP Switch GCS1764 KVM / audio switch 4 ports (S4403597) KVM Switch
When 2 pcs boot at the same time on my GSC1464 switch, the one which the swtich's tune too work the video display like it should but the second limit the second computer (the one who wasn't selected) limit the video display to 1024x768 or 800x600 (Just like if there was no video drivers installed on the pc) Do you know something that may correct the problem? Thx
  • 30 Answers
When a computer first boots up the video card send a request to the monitor to find on what resolutions the monitor supports. If the video does not get a response the card will default to very low resolutions. The only way to avoid this problem is to boot your computers one at time and keep the KVM on the computer until it fully boots to a desktop. This will allow the KVM to pass the monitor information to the computer.
Posted on Jul 07, 2009
XP won't boot with Startech Video Splitter
try to reinstall your Win xp and if it is the same check other system that work for there model and make they may not be compatible
Apr 18, 2012 | StarTech.com Ltd. 2-Port VGA Video...
Screen is blank how do I get it to work again
Do you need the external monitor to switch it back to internal monitor or both on?
Feb 07, 2012 | Lenovo 3000 G530 PC Notebook
The furnace will start and run for 5 mins and kick off. Then the burners will not reignite after that. However, after everything cools down (about a half and hour later) it will restart and run for...
Hello, sounds Like the Furnace is tuning off due to the limit switch or rollout switch opening. A limit switch and rollout switch are safety swtiches that will turn off the furnace if it gets to hot or the burners flames are abnormal. Usually a weak blower motor, dirty blower wheel , dirty burners or even a crack in the heat exchanger can cause this problem. Best bet is to call a hvac technician and have them check it out.
Sep 14, 2011 | Heating & Cooling
I want my player to play dvd while driving how do i bypass to make this possible
  • 1st you will need to purchase a 12 volt or above Momentary Push Button/(Toggle)switch (about $5 Radio Shack)
  • 2 2nd Using the Diagonal Pliers adjust the length of the Radio's Emergency Brake Wire to your desire. Make sure you have enough wire so you can mount it where you can easily access it like beneath your steering wheel/ on the Dash Board.
  • 3 3rd Connect one end to the emergency brake wire from the radio and then connect the other wire from the switch to a ground to your car. You can use the same ground connection that you used for the radio and it will be fine. Make sure you wrap up the wires using the Electrical Tape to prevent shorts.
  • 4 4th (Using Button Switch) When you are ready to use the DVD player insert DVD and after a few seconds the screen will turn blue and the message to "Set the emergency brake" will come on. Now just press the button (4x Times)for one second and release it. On The fourth time the screen takes about 6 second to display the video.
  • 5 5th (Using Toggle Switch) When you are ready to use the DVD player insert DVD and after a few seconds the screen will turn blue and the message to "Set the emergency brake" will come on. Now just flip the swtich on and off (4x Times). On The fourth time the screen takes about 6 second to display the video.
  • 6 Now your Passengers can enjoy the ride & Movie!!
  • Sep 29, 2010 | XO Vision XO9013 Car DVD Player
    Dell E153FPd Power stays on but video goes off after 2 seconds.
    3 ideas here. bad connections on the coils inside. the inverter board has gone bad, or bad capacitors on the power board or inverter board. all of witch should be serviced by a qualified service center.
    Jul 21, 2009 | Dell E173FP 17" LCD Monitor
    Acer 5610 boots for like 3 seconds only
    Hi..
    Most laptop PCs include external video outputs, primarily VGA (Video Graphics Array), with an increasing number of devices offering DVI (Digital Visual Interface), or HDMI (High Definition Multimedia Interface) support.
    When your laptop PC's built-in display isn't working properly, you can quickly and easily determine if the problem relates to the built-in graphics circuitry or to the display itself by plugging in an external monitor. If the external monitor lights up and things work as they should, the built-in display is at fault. If the external monitor also fails to work, it's likely that your laptop PC graphics circuitry has failed. Because this can involve replacing a standalone graphics module or the system board inside the laptop, depending on the make and model of your computer, you need to perform a cost-benefit analysis on making repairs or replacing your laptop PC.
    Good luck !!!
    Regards
    PCmania
    Jul 16, 2009 | Computers & Internet
    TC1100 does not turn on!
    Check the wall outlet to be sure it is providing power. Use a lamp or a fan or other electrical device to be sure that outlet provides power. Check the power surge supression strip, and ensure it is switched on if it has a switch, and it it has a fuse reset button, push that in or push it to the reset position. Recheck the connection of the wall connector cable to the small DC converter box. Finally recheck the connection of the end of the power cable where it connects to the PC. If the Tablet still does not show a green light indicator on the front, try removing the battery. The TC1100 works with the battery completely removed. If you have power but no display, then the problem could be with the display. I suggest that since there are a lot of problems with the older tablet PCs, that if you still have problems with it and do not really need that type, check out the new low priced Atom processor netbooks and the new moderately priced Intel Core2 Duo notebook PCs and AMD dual core and tri-core notebook PCs, with plenty of RAM like 2GB or more, and preferably dedicated video RAM, like an NVideo or ATI video that provides 64MB or 128MB or 256 MB or 512MB or more of dedicated video memory. Back to your TC, ensure it has good power, then look to possible bigger issues that power or power adapter - the CPU or board could be bad, or it may boot up but not display because of a problem with video on board or in the connector to the screen or in the screen circuitry.
    Mar 08, 2009 | HP 303178-001 Compaq TC1000 TC1100 Tablet...
    HP dv1000 monitor just stopped working.
    Description During the startup or boot process of the notebook, the display is very dim and barely readable. It remains dim when it reaches the Windows desktop. Restart the notebook with AC power Perform the following steps to determine if the dim display is due to a hardware failure:
    1. Connect the AC adapter to the notebook and a working electrical outlet.
    2. Power down the notebook PC by pressing and holding the Power button for 5 seconds.
    3. Press the Power button again to start the computer.
    If the display is still dim after restarting with the AC adapter connected try changing the LCD brightness. Change the LCD brightness From the Windows desktop, hold the Fn key and press the F7 and F8 keys to increase or decrease the brightness of the display. If using the function keys does not resolve the problem, determine whether the Lid Actuator switch is stuck. NOTE: The key number may vary depending on the notebook PC. The image on the key should resemble the following images: Figure 1: Brightness Level Down c00776225.jpg Figure 2: Brightness Level Up c00776226.jpg NOTE: During battery power operation, the notebook display will dim to reserve battery power. Adjust brightness control using the control panel Some notebook PCs have the ability to adjust the brightness through video drivers. If the notebook PC has video drivers with this capability, perform the following steps:
    1. Click Start , Control Panel and then double click Display .
    2. Select the Settings tab and click Advanced .
    3. If the feature is available, a tab with the video card name will be present. If it is, select that tab.
    4. Adjust the desired brightness.
    Finding the Lid Actuator switch The Lid Actuator switch is a small button or switch located above the keyboard and LEDs on the right or left side of the notebook. It may also be located near the display hinges. Pressing this switch when the computer is on may turn the notebook display off or cause the notebook to enter a different power state. Press the switch 2-3 times while observing the display. If the display is no longer dim the switch may need to be repaired. Contact HP service and support for further assistance. Contact HP service and support If the display remains dim after the troubleshooting in this document it may be possible that the backlight is damaged. Please Contact HP service and support to schedule a repair
    Jun 05, 2008 | HP Pavilion dv1000 Notebook
    IOGear MiniView DVI KVMP Switch GCS1764 KVM / audio switch 4 ports (S4403597) KVM Switch Logo
    290 people viewed this question
    Top IOGear Computers & Internet Experts
    Jose Velazquez
    Jose Velazquez
    Victorman
    Victorman
    Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
