SOURCE: pioneer vsx-d511 amp error
I've had the same problem for over a month and have yet to find the time to get to it. However, I there may be a fuse on the circuit board that needs to be replace. That's just my guess.
Hope it's the solution.
SOURCE: Pioneer VSX-D412 AMP-ERR message.
The AMP-ERR message in many Pioneer Receivers is caused by some DC in the output. The microprocessor then issues the warning and shuts the unit off. It is definitely not a relay switch. It could be the amplifier power pack, i.e. PAC011A or similar that is faulty or something else. Not easy to repair for the non- experienced DIY.
Good luck
SOURCE: i turn on my Pioneer VSX-D509S 5.1 surround amp
Disconnect all your speaker wires from the back of the receiver and turn it back on. If it shuts off, you need to have it serviced. If not post a comment and I can walk you thru troubleshooting. Hope this helps
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
SOURCE: amp error
You have a defective amp ic.either ic601 or ic602 will be bad you will also have an open fuseable resitor in the channel where the ic is bad. ic numbers are PAC010A AND PAC011A
