How to disable sata on my cq40-108tu laptop - Computers & Internet
  • 33 Answers
Go to the cmos !!! find the disable the sata
Posted on Jun 30, 2009
I want to install windows xp-2 in my laptop presario cq42 notebook, i have a proble with hard drive for sata disable. in this laptop the bios not show the sata disable feature. so i want to disable this...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 11, 2011 | Compaq Presario Notebook
Tip
Windows XP setup disk says disk not found.
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
on Apr 15, 2009 | HP G60-120US Laptop
Disable SATA in BIOS, well but there is no option in Bios to disable or enable SATA. Lately HP DV2000 comes with bios without this option (DV2000 - DV2680ee, I lost a lot of money and time with this...
You should not need to disable SATA as it is a way to interface with the hard drive. In the BIOS you can disable a hard drive to boot within the boot options.
May 06, 2011 | Computers & Internet
How to disable SATA on Toshiba satellite A205
Why would you want to disable it? Chances are it is a SATA HDD installed.
Apr 22, 2010 | Toshiba Satellite A205-S5812 Notebook
Do i need (s)ata drivers for toshiba satellite u400? or i can install xp without a problem?
Start your laptop and goto your BIOS and check if SATA setting is available.if available then configured it in IDE Mode or disable it, (if disable option is available).
Now, you should be able to installed windows XP without any problem;
Usually these days,Laptop BIOS comes with little or standard setting;if that is the case;then you will need SATA driver during installation in other to recognise your SATA hard drive.
Dec 14, 2009 | Toshiba Satellite Pro U400-S1001V Notebook...
How to disable sata on sony vaio vgn nr 110e
For information on how to install XP (without using a floppy which has the SATA driver) on a SATA drive go to this WEB site :-
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
Sep 03, 2009 | Sony Vaio VGN-NR110E/S Notebook
Compaq CQ40-108TU unable to install XP OS
Prepare a Bootable XP Disc installer.
At first go to BIOS Setup to Boot First Priority the CD/DVD Rom Drive.
After that disabled SATA or RAID Configuration. The Bootable XP Disc Installer could not go on when you don't disable the SATA or RAID Connection.
Don't worry that you are thinking it would not detected the SATA HDD by Bootable Disc but it is. Then follow the instruction.
If i am helpful to you please rate me.
Thank you.
Yboyandrei
Aug 24, 2009 | Compaq Presario Notebook
Change geteway laptop from vista to xp
Yes you can but disable the SATA in the BIOS first and after Xp is installed you can install the SATA driver.
XP does not have a SATA driver or a SCSI driver on the CD and you need to interrupt the install process to insert this driver.
Leave the BIOS set to SATA, download the SATA driver and create a floppy with the SATA driver. Boot up the Windows XP install disk and when it asks for a a hard disk driver press F6 (I think it is this key, you have to be quick) insert the floppy with the SATA driver.
May 03, 2009 | Gateway M-6834 Notebook
I have a dell c600 and my hardrive isnt recognised
go to the bios while restarting your laptop and there is option to disable sata for hard drive disable sata you hard drive will probably start working
Dec 05, 2008 | Dell Latitude C600 Notebook
Can't reinstall windows xp
hmmm its seems your HDD is of SATA interface and XP is not able to detect the HDD interface. you can solve this problem by making SATA Disabled in BIOS setup.
Try to make disabled SATA from BIOS, and then make install.
If any problem... Ask me
Thanks
Iqbal
Apr 05, 2008 | HP Compaq Presario C304NR Notebook
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
