Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Canon 3300 touch panel not working
After 2 seconds on startup touch panel of canon ir3300 is hanging and no function is working
please can u get me out this problem guys
Thank you
  • mdgm May 11, 2010
    Can you see anything on the screen? Do you hear normal startup noise?
    Sniper:
  • 89 Answers
This problem can have a number of causes. Best to call a tech to sort it out.
Posted on Aug 18, 2009
E0001-0002 this error comes in canon ir3300 please give solution
This is the standard error code for the fixing assembly is not heating up properly. Most likey the fixing film assembly ( P/N FG6-6039-120 ) is defective. You can reset the error once by pressing the additional function key, then the 2 & 8 keys at the same time and then the additional function key again. This should get you into service mode. Press COPIER, FUNCTION, CLEAR, ERR, Then OK. Turn off the copier for about 10 seconds then turn it back on. This resets the error. If the error or another error with alot of zeros and one digit comes back then you have to have it repaired before going any further.
Oct 20, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Each time l switch on my machine canon ir3300 l have e000007-0000
Try this press additional functions,2 and 8 keys at the same time,additional functions,copier, function,clear,err.power off and on. If that does not work you will need a tech to fix your fixing unit.
Oct 01, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon ir3300 displayis not apper
canon ir 3300 display (control panel ) not functioning ? This problem solve if you replace your 128mb RAM.
For more information
Please contact me -
Ajaya Kumar Mandal.
At/Po- Jharigam
Dist- Nabarangpur
Orissa
Email- ID - ajayakumar256416@gmail.com
Mobile No. - +919178488706/716
Jul 27, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
E00002-0000
Just entering service mode by pressing add. function, 2 & 8 and add. function, touch copier option, then function, then clear and touch ok button. your problem will resolved. if error again come then you need to replace fixing film assambly.
Jul 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
can You Operate switches on control panel,
like '1', 2 start etc.
Jun 22, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Code error of Cannon IR3300 E000006-0000
getfile.asp?rid=1258 November 7, 2002 getfile.asp?rid=3215 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution :
In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS
Apr 29, 2009 | Office Equipment & Supplies
E00002-0000 error code
ont. Panel, press the following, one after the other, * (additional functions), 2, 8, * (additional functions). You are now in Service Mode. Touch the Function Tab, touch the Clear button, touch the ERR button, when it is highlighted, press the OK button at the botton of screen. Power Cylce unit. If it comes back up, may have been a fluke. However, if it comes back, check your Fixing Assy for jammed paper, or damage to the Fixing Film (Upper Roller). Replacing the Film is not hard. After you remove the Fixing Assy., its a couple cables and springs. Rather on the easy side for Film replacements. Remebmer, on these models, the Film is also the Heater and Upper Fixing Roller. The Film is most likely on the pricey side for new, believe you can find rebuilds. Just keep in mind that the Film is still a lil' bit cheaper then the whole assy., and 8 out 10 times, its the Film that fails in the asssy
Mar 21, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Computers & Internet Logo
246 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
