SOURCE: printing heavy weight invitation stock on Epson R200
The card is probably too thick. Try cleaning the feed roller in the Sheet feeder to improve its grip. Check the GSM of the paper is within the spec of the printer.
SOURCE: paper will not feed through - epson DX4000 printer/scanner
Did you check the thickness? My printer won't feed paper that's to think or thick properly it sould say in the manual what thickness of paper you should use.
SOURCE: paper doesn't always feed, and when it does, the paper rolls through without printing
Get a Q-Tip and alcohol. Wet Q-tip with alcohol. Stand in front of the printer and look down where the paper feeds through. On the righthand side you will see a big roller that pulls the paper through and a little one right up under that. Clean both of them with the alcohol and Q-tip. Press the paper feed button and as it trys to act like it is feeding the paper, clean the roller with the Q-tip. Do this until the paper feeds through correctly.
SOURCE: paper will not feed into printer epson r300 printer
This is a common prob of all epson printer. If you use more than 230GSM thickness paper with the printer and use 80 gsm paper next, it wont pick up. This is due to the spring in the back side of the paper picker unit elangated to more thickness and fail to function fully. you can remove the paper pickup unit and change the spring if you have the service manual.
