Question about Refrigerators
Stinky Ice I have a kitchen aid MOD: KTRA22EMSS01 or TYPE: C22TFA04 (not sure which to use to identify) and the ice really smells bad. It has the freezer on top above the frige. It seems to be fine otherwise, but it is really unnerving to have ice that stinky. Any ideas?
  • Anonymous Apr 24, 2009
    Can't be just food - we've gutted our GE Profile side-by-side fridge and cleaned it all down - yet the noxious funk keeps getting worse!
  • 473 Answers
You could try using ice aid, However there is nothing on a fridge that causes an odor only things that are put into the fridge i.e. food, water quality.
Posted on Nov 07, 2007
My ice smells moldy
Icemakers need to be cleaned about every 90 days, especially if it is a bin type unit that holds recirculated water in a tank which is then pumped over a grate to make ice. You didn't indicate what type of ice maker you have. Many manufacturer produce a cleaning produce for their ice makers. Here is a link to the Whirlpool/Kitchen Aid product:
It is made primarily for a bin type ice maker and does an adequate job if you use it on a routine basis (i.e., every 90 days).
If your commercial ice maker has removable parts, remove all parts that have direct contact with the ice. Wash these parts in hot, soapy water and use a brush to remove any dirt or mildew from the parts. Remove any ice or water storage bins and wash them in soapy water. Rinse each part thoroughly to remove all traces of soap. Use a 50/50 vinegar/water solution to break up any hard water (calcium) deposits on the parts. Sanitize your ice maker parts by soaking them in a solution made of 1 oz. of bleach and 1 gallon of warm, clean water. Allow the parts to soak for at least 30 seconds and leave them to air-dry.
Clean and sanitize ice makers that do not have removable parts by running two or three cycles and discarding the ice. Check you manufacturer's instructions for how to clean your ice maker. Some machines may not tolerate diluted bleach solutions, so check the sanitizing solution specified by your instruction manual through the machine. Always throw away the first batch of ice made after cleaning. Also change your water filter, if so equipped.
If you
Mar 29, 2014 | Kenmore Refrigerators
How to defrost freezer in kitchen Aid bottom drawer freezer
My kitchen aid bottom drawer freezer kept melting and freezing to block the drain and then water would leak out all over the floor. I did the WHOLE fridge/freezer defrosting process once, when i really just needed to do the bottom.
I have had issues with other Kitchen Aid (NEW BTW) appliances so I've talked to many repair people. One guy who came out to fix something else, told me that the freezer is really a pain to get to close completely. SO, when you don't close it all the way (Extra push) it will melt and then re freeze when it is closed properly. He suggested I take everything out, leave it open and use a hair dryer on the ice until it melts. Then use a wire hanger to unplug the drain to make sure its draining properly.
It works! You really have to make sure the drawer is shut ALL the way. I have a 2 yr old who is constantly opening it up...this is my issue! The seal is not that great and you have to really push it closed to prevent the ice build up issue.
Hope that helps!
Sep 10, 2013 | KitchenAid Refrigerators
Kitchen aid ice maker not working
make sure water line is not plugged up. The small line can plug.
Oct 22, 2012 | Kenmore Kitchen Aid Ice Maker 4200520...
Problem with water and ice
My kitchen aid superba sie by side stopped making ice. I've changed the water filter and did the trouble shooting options in the book. Everything else is fine. Can you give me any suggestions
Mar 16, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid ice maker is making a pumping noise. The noise is itermitten. It still makes ice. Freezer is at 5 degree and fridge is at 34 degree. Aquasensor filter is at 44 percent left. Thanks...JA
noise from ice mker can only be the ice maker unit... turn of icemker for a while and see if tn=he noise comes on during that period . if not replace ice mker head . mm
Dec 07, 2009 | Dishwashers
Is there a filter on the model KSBS20QEBL0? The ice has a terrible smell - have cleaned with baking soda, with no results.
i stinky piece of fish or any thing stinky in the frig side will smell up the Ice. Dump all ice wash out the bin with bleach and water.
Some frig's have a filter , some do not.
Nov 21, 2009 | Ovens
Ice maker in my Kitchen Aid side by side is not getting water
there is only 2 things that would cause this. either the icemaker is bad and not calling for water or the fill valve that allows the water to come into the icemaker is bad. how old is the fridge ? also check the ice maker and make sure it has not accidently been cut off inside. if this is the old type theres a bar that raises and lowers. make sure the bar is down. in the up position this would turn your icemaker off
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid indoor ice maker
hi there,
i would recommend a technician to help you with this. this part that fell out is from the motor head off the icemaker. have the technician put it back together and make sure that there is nothing else loose.
Jun 14, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerators Logo
365 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
