TX-SR705 Hum problem
I have a TX-SR705 with the same problem. The noise started 2 weeks ago, about a year after I bought it. I hear a low level hum in all speakers on all channels (DVD, CBL, AUX, GAME, etc.). Seens to be a huge problem with +/- 1 year of operation.
  • 2,071 Answers
This a problem of input grounding,the cable input is already loose or crack solder that why you hear a hum or distorted sound because not properly grounded it is a loose contact already thats why also is need to warm up and it will come.First change the cables with a new one with identical size and value then if problem still exist open the back cover ,when open look for the cable input connection parts joints reworks or resolder all soldered joints there .Then checks if it works then cover the unit.If you have no knowledge of electronics dont attempt to open to avoid electric shock.Find a electronics repairman or bring this to a authorized electronics repair shop maybe it cost you only $50.
Good luck;
Dont forget to rate...
Regards:
VOTIT
Posted on Jun 29, 2009
TX-SR705 60 hz. Hum
If you have a Home Theater Line conditioner on this receiver, not a power surge protector, even a "Monster" surge suppressor, your problem Is AC related. For troubleshooting; first if your AC power cord is three pronged, go to Lowes, Home Depot, etc. and get a three prong to two prong adapter. Your problem is a "Ground" issue, however it may not be from the receiver, it could be "Anything else" in your home. Even an actual outlet with a loose wire. It can be very very time consuming to "hunt down". An adapter will take the rest of the house out of the picture. Disconnect all other input sources like Cable, DVD, etc. then turn the unit back on. If you still have a humm, yes the problem is internal and needs serviced. If it stops, re-connect one item at a time until the noise re-appears and you have your culpret. If you don't have a line conditioning noise eliminating Theater surge protection unit; Get one! best few hundred bucks you could ever spend. It will protect all your electronics and could save you thousands! Panamax, Furman, Monster, are your top 3. If you still have issues, post a comment and I can help you further. Hope this helps.
Aug 23, 2009 | Onkyo TX-SR705 Receiver
Unit is running, but is no longer cooling. Fan is blowing, but air is not chilled (or cold). Unit has been running fine until a couple days ago. It has been turned off for the last 12 hours and tried...
not sure if it is a package system or a split but this is what you do.go outside where your outdoor machine is, after it has been shut off for awhile, and you should hear 2 distinct noises.1 is the outdoor fan, you should see it spinning.the other is a comppressor hum.some compressors have noise bags on them so listen closely thru the fan noise.if you hear no hum listen for a hum about every 2 to 5 minutes.if you hear this hum every so often, chances are you compressor is seized or stuck.the only thing to do there is get a tech and try a big boost to get it going.
Aug 07, 2009 | Fedders A6P09S2A Air Conditioner
Loud hum/vibration on acceleration - Saab 95 Linear 2.3t
I have the exact same issue. I can't seem to replicate it for the dealer and it is identical to what you are describing. PLEASE e-mail me if you figure it out or know anything. I want to get it fixed and it to go away! Thanks! Todd. Tm2200@aol.com
Jul 18, 2009 | Saab 9 5 Cars & Trucks
Onkyo TX-SR705 Muting Problem
if what Dark_Orbit said does not work try doing a master reset by ressing and holding the dvr/vcr button and stand by button simultaneously. This would erase all your assignments so you would need to reassign all your sources hooked up to your onkyo.
Mar 04, 2009 | Onkyo TX-SR705 Receiver
Sunfire Subwoofer 110 Noise on input plugin
A few more questions-
Does the sub hum without anything plugged into it except for power? If it makes a real loud hum almost a squeal then I think the rca cable between the receiver and the sub is dead shorted and needs to be replaced. If it's more of a low level hum, then it's a ground hum caused by many things, ie........the receiver and the sub being on different power circuits in the house.......sometimes diconnecting the cable tv feed as it enters the room while the sub is connected and humming to see if it stops........the easy fix sometimes is using a 3 to 2 prong ac adapter but lifting the ground on such a powerful amp could be a fire hazard.
Sep 25, 2008 | Sunfire True Sub MK II Subwoofer
My onkyo tx-sr705 produces a humming noise out off all the speakers when no audio is played
I found the source of my hum. I have Direct TV HD. I found that going into the menu settings (Direct tv HD Receiver) /Audio/Sound Effects and turning that option off, I was able to rid myself of the annoying hum. The option has something to do with keeping the audio settings from channel to channel, while it is changing you hear dead air except for the hum. Nice and quit now. Love this receiver!
Mar 06, 2008 | Onkyo Audio Players & Recorders
56 people viewed this question
 Grubhead
Grubhead
