Question about Epson Office Equipment & Supplies
My Epson Stylus RI800 does not reset when the power switch is turned on. Additionally the printer will not power down when the switch turned off. Also if the switch is in the on position when the printer is unplugged, and then the printer is plugged back into the power the power light on the power switch remains on (green light). Please advise
  • 1 more comment
  • contact370 Jun 29, 2009
    I have just tried you solution and it did not work.
    What is your next option?
    Thank you
    Fred Swartz
    The printer is in the (off) state when I start it. When I hold down the power switch The green light blinks once and the ink cartage carrier moves slightly to the right, then it moves slightly back to the right and stops.
    As I stated in the original email, the printer will not power down (turn off) when the power switch is depressed, it moves to the off position (it becomes flush with the other buttons) but the green light remains on (glowing).
    As for printing, no it does not print.
    President:
  • 2,777 Answers
Hello there, sorry to hear about the troubles you are having, I am sure I can help you out here. So you say it won't reset when the power switch is turned on... the power switch you refer to is it the one in the back of the printer? It is a hard On / Off switch that you can actually flip? As far as I know this model only has the Power button on the front of the unit, so I am going to go on the basis that you are referring to that, please let me know if it is another switch.
The really is no true "reset" option with this printer, you basically have three modes of operation:
Power on - ready to print
Standy by - power save ready to print after warming up (it does this automatically)
Power off - all lights should be off
To power the unit off (essentially a reset, you can power it down, wait a few seconds, power it back on) you need to HOLD DOWN the power button on the front of the unit, it may take as long as 15 seconds of holding the button before it starts to power down. Most people just leave the printer on all the time since it is hardly using any power whatsoever when it is not actually printing.
Please let me know if this answers your question, I believe it should. As long as you respond within the next 20 minutes or so it will guarantee that I personally will address the problem.
Thanks for your time,
Tim G
Posted on Jun 29, 2009
  • 1 more comment
  • Tim Grayson
    Tim Grayson Jun 29, 2009
    When you hold down the power button what does it do, does the light flash or anything of that nature? Otherwise than this reset issue is the printer printing just fine? Have you been able to successfully "reset" this printer in the past?
    Please let me know and we can definitely get this solved.
  • Tim Grayson
    That sounds like it's operating normally to me, I guess I'm failing to see the problem. Does the printer actually print when you send something to it or not? When you power on the printer it should move the ink cartridge as it sounds like it's doing, that's it's normal start-up routine. From there you should be able to leave the printer on, I have a similar model and I can't remember the last time I even shut it down, it's been on for at least 18 months straight.
    Please confirm the actual issue, sounds like the printer powers up and down just fine, is starting up normally, and doing it's warm up routine... however maybe it's not actually printing when you want it to?
    Please let me know
    Thanks
    T
  • Tim Grayson
    Ok I understand now, it is definitely a hardware problem, nothing you can easily fix from your end. You have performed all the steps to verify that this is the case. You will need to contact Epson support, it may still be under warranty and could be free to repair.
    Their phone number is: 562-276-7296 or 905-709-2567 if you are in Canada.
    Sorry we couldn't get it easily fixed, unfortunately it will need actual repairs, especially since it is not printing.
    Thanks for your patience and understanding,
    Tim
My Epson Stylus photo 830 flashing lights
Got the alternate red/green flashing light ona photo830. The app shown by Bill Miller sorted the problem and got the printer back on line. Use the 'protection counter' / 'reset counter option'
Thanks Bill :-)
Mar 03, 2012 | Epson Stylus Photo 830 InkJet Printer
Tip
Manual Counter Reset Method
To manually reset the Ink Jet Counter that compels you to clean your waste pads. For the tip on how to clean your ink waste pads go here.
Please Note: In some cases, your printer may be leaking ink so much and so often that not only does your ink pads need cleaning, but you may need to replace the ink reservoir on your printer or you will have a leaking mess on your hands. This is a decision and judgment only you can make. If your printer is leaking quite of lot of ink, you may have to take it to an authorized Epson Repair Shop or Person. Find an authorized location by starting at Epson.com
The solution below is valid for most of the following printer models listed below this solution, some listed may not work, some not listed may also work it varies as this method is listed below is illegal for an authorized Epson Tech to release.
Thanks to the many user boards on the Internet for this solution that I know has worked for people I've helped here on FixYa.
Don't be discouraged if it doesn't work the first time. The key is in pressing the buttons exactly at the same time. So if this doesn't work the first time, try again and try again. Most people state they get it eventually.
[thanks to fixyourownprinter.com for the crux of this particular solution]
"Printer Onboard Control Panel Key Sequence"
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
Don't give up, if it does not reset the first time. The timing is tricky for some people.
Supported Epson Models that I am aware of, others not listed may work and some listed also may not work, it varies but don't be discouraged to try and try again.
You can also try the software download solution listed in this tip I posted.
Epson Stylus Сolor 400
Epson Stylus Сolor 440
Epson Stylus Color 480 LPT
Epson Stylus Color 480SXU / 580
Epson Stylus Сolor 600
Epson Stylus Сolor 640
Epson Stylus Сolor 660
Epson Stylus Сolor 670
Epson Stylus Color 680 / 777
Epson Stylus Сolor 740
Epson Stylus Сolor 760
Epson Stylus Сolor 800 / 850
Epson Stylus Сolor 860
Epson Stylus Color 880
Epson Stylus Color 900 / EM-900C
Epson Stylus Color 980
Epson Stylus Сolor 1160
Epson Stylus Color 1520
Epson Stylus Color 3000
Epson Stylus C20 / C40 / CL-750
Epson Stylus C41 / C42 / C43 / C44 / C45 / C46 / C47 / C48 **
Epson Stylus C50
Epson Stylus C60
Epson Stylus C61 / C62 **
Epson Stylus C63 / C64 **
Epson Stylus C65 / C66 and PE **
Epson Stylus C67 / C68 / D68 and PE **
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson Stylus C83 / C84 **
Epson Stylus C85 / C86 and PE **
Epson Stylus C87 / C88 / D88 and PE **
Epson Stylus Photo RX420 / RX425 / RX430 **
Epson Stylus Photo RX500 / RX510**
Epson Stylus Photo RX520 **
Epson Stylus Photo RX600 / RX610 **
Epson Stylus Photo RX620 **
Epson Stylus Photo RX700 **
Epson Stylus CX3100 / CX3200 **
Epson Stylus CX3500 / CX3600 / CX3650 **
Epson Stylus CX3700 **
Epson Stylus CX3800 / CX3810 / DX3800 **
Epson Stylus CX4500 **
Epson Stylus CX4600 **
Epson Stylus CX4100 / CX4200 **
Epson Stylus CX4700 / CX4800 **
Epson Stylus DX4200 / DX4800 **
Epson Stylus CX5100 / CX5200 **
Epson Stylus CX5300 / CX5400 **
Epson Stylus CX6400 / CX6600 **
Epson Stylus CX6300 / CX6500 **
Epson Stylus CX7800 **
Epson PictureMate
Epson Stylus Photo
Epson Stylus Photo EX
Epson Stylus Photo 700 / IP-100
Epson Stylus Photo 750 / PM-770C
Epson Stylus Photo 780 / 790 / PM-780C
Epson Stylus Photo 810 / 820
Epson Stylus Photo 820 **
Epson Stylus Photo 825 / 915
Epson Stylus Photo 830 / 830U **
Epson Stylus Photo 870 / PM-875DC
Epson Stylus Photo R200 / R210 **
Epson Stylus Photo R220 / R230 **
Epson Stylus Photo R300 / R310 **
Epson Stylus Photo R320 **
Epson Stylus Photo R800 / PX-G900 **
Epson Stylus Photo R1800 **
Epson Stylus Photo R2400 **
Epson Stylus Photo 890
Epson Stylus Photo PM-890C
Epson Stylus Photo PM-A700 **
Epson Stylus Photo PM-G720 **
Epson Stylus Photo PM-970C **
Epson Stylus Photo 895/ 785EPX
Epson Stylus Photo 900 **
Epson Stylus Photo 925 / 935 **
Epson Stylus Photo 950 / 960 / PM-950C **
Epson Stylus Photo 1200 / PM-3000C
Epson Stylus Photo 1270 / PM-3300C
Epson Stylus Photo 1280 / PM-3500C
Epson Stylus Photo 1290
Epson Stylus Photo 2000P
Epson Stylus Photo 2100 **
Epson Stylus Photo 2200 / PM-4000EPX **
Epson Stylus Pro 5000 / PM-5000C
on Sep 17, 2008 | Epson RX620 All-In-One InkJet Photo...
Cant print anymore print counting is almost full. how to reset count
try this
Manual reset methods several EPSON Stylus Color. Actually there are two methods to reset epson printers counter, that is using software resetter such as adjustment program or SSC service utility or using manual by combination pressing button on the printer. If Reset using software resetter you can follow the way of usage the software but sometimes software resetter for the printer is not available. The only way to reset the printer if software resetter not available you can use manual reset.
The Following manual reset for some EPSON Stylus Color Printers:
1. EPSON Stylus Color
Pressing and holding ALT+FONT+LOAD+PAUSE buttons combination
press POWER button
Release all buttons
2. EPSON Stylus Color 300
3. EPSON Stylus Color 400, 600
Pressing and holding LOAD/EJECT and CLEANING buttons
press POWER button and hold it until you will see blinking INK OUT and PAPER OUT leds
Release all buttons
In 2-3 seconds time press LOAD/EJECT and CLEANING buttons again.
4. EPSON Stylus Color 440, 640, 740, 460, 660, 670, 760, 860, 880, 1160
press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button, until all leds will blink.
5. EPSON Stylus Color 680
Pressing and holding LOAD/EJECT and CLEANING buttons,
In 2-3 seconds time press and hold LOAD/EJECT button, until all leds will blink.
6. EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons
press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
7. EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led
Release all buttons
8. EPSON Stylus Color 800, 850
Pressing and holding LOAD, CLEANING Color and CLEANING Black buttons
In 2-3 seconds time press and release CLEANING Color button, You will see leds blinking.
9. EPSON Stylus Color 900, 980
press POWER button, You will see blinking INK OUT led
Release all buttons
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
10. EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons
turn on printer.
Mar 17, 2011 | Computers & Internet
Printer jamed after putting in more paper and accidently pushed the power button off. Will not respond to anything I have tried.
Reset your Printer by following these steps for your Printer Model:
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button, You will see blinking INK OUT led.
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons turn on printer.
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Error led.
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led.
Feb 27, 2011 | Epson Stylus Photo 785EPX InkJet Printer
Epson stylus c120 lights flashing (ink & paper feed).......... power button stays off............. just happened after I presed the feed button.........nothing else
I KNOW THAT YOU CAN RESET YOUR PRINTER SYSTEM ONLINE BY USING THE EPSON.COM SERVER AVAILABLE SOFTWARE, I JUST HAD MINE RESETED BY A FRIEND AND IS WORKING JUST FINE, AND STILL USING THE AFTERMARKET RESETABLE CARTRIDGES..
Nov 06, 2009 | Epson Stylus C120 Color Printer InkJet
EPSON STYLUS 4000 MAINTENANCE REQUIRED 0040 ERROR CAN ON. HOW DO I RESET THE COUNTER?
While powering up the printer, hold down the three leftmost
arrow buttons:
[left-arrow] [down-arrow] [up-arrow]
You will get a whole different set of menus.
Use the up/down arrow buttons to select the "Clear Counters" menu, then press the [right-arrow] button.
Use the up/down arrows to get to the maintenance tank entry... where you can clear its counter.
Then turn the power off, wait, then turn it on.
You can use this diagnostic startup to clear most of the counters (and their related maintenance codes).
Sep 15, 2009 | Epson Stylus Pro 4000 InkJet Printer
Error message on epson rx425
Follow this link.
http://www.ssclg.com/epsone.shtml
At the bottom of page agree to terms and install.
On the "configuration page" and in the 1st drop down screen select your printer.
On the 2nd drop down screen is where I was getting confused as I have a Epson Stylus Photo RX425 but couldn't see it in the listings, it is there, look for:-
"Epson Stylus CX4600(4500)/CX36x0(3500)/RX42x(430)PM-A700" and select.
Next click this page off and in the botom right quick launch panel right click the multi coloured printer icon.
Select the "Pretection Counter" then "Reset Pretection Counter"
There you have it, switch off and back on the printer and all should be well.........
May 21, 2008 | Epson Stylus RX425 Multifunction...
Epson stylus 880 printer
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Oct 08, 2007 | Epson Stylus 880 InkJet Color Printer
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
