Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Food freezes in back and top of fridge SAMSUNG RF266AASH/XAA
This is a serious issue. It froze my filter housing. This cracked the housing and a flood of my kitchen, pantry, living room and bedroom resulted when the filter housing thawed. I had not even known that the filter housing had cracked. If you have a water dispenser and it sometimes fails to dispense. BE WARNED it is probably freezing the lines inside the walls of the fridge and could very well flood your house if it freezes and cracks your filter housing. The filter by the way was only two months old and the freeze thaw stress broke it in that short time frame.
I have had my main control board replaced, pantry thermistor, and the damper door and DA47-00243K bimetal protector will be replaced today. It sounds like the damper door will not solve the problem if your experience is relevant to mine.
I have been offer a buyout from SAMSUNG and I believe there may be a serious issue with many of these fridges.
Samsung has told me that there have been numerous cases of floods caused by this problem.
I love the fridge otherwise but, I can't risk a flood if they can't solve the freezing issue.
As a temporary measure I have left out the water filter and use an external inline water filter/conditioner cartridge.
I'm still concerned that the freezing of the lines inside the walls may result in future floods when and if the freeze thaw stress gets to them.
Therefore if latest "fix" doesn't solve the problem I am going to take the buyout and look for another fridge.
Let hope I have no floods in the meantime.
By the way I been dealing with this issue since last year with the flood occurring in February or March of this year.
It seems I get a different Executive Customer Relations rep everytime I call in to get an update on the service.
I would be interested in anyone else's experience with SAMSUNG support, repair, and followup.
Has anyone had a similar problem that was able to be successfully diagnosed and repaired?
shaggyrat
  • 1224 Answers
SOURCE: Side by side refrigerator freezing up
inside the fridge there is a cold radiator which has filled with condensation or water from freezing it when say cleaned out the fridge this can be remedied by letting set for a few days outside in the sun so that water can evaporate properly or you can call a repair man and he can pull out frost radiator inside and defrost all the water out by dry wet vac and heater dryer
ice builds apon ice even a little bit can build up to a mountain same thing happended to my top end whirlpool i pulled the metal grate and defrosted this by pouring tap water over the ice which it went down the defrost tube outside water drain this helped greatly havent had trouble with ice since
Posted on May 13, 2008
SOURCE: Samsung RS263BBWP Side by Side Fridge: Water line continually freezes
higher numbers on the tempature set make the fridge
colder lower numbers make wormer
Posted on May 23, 2008
farfield
  • 462 Answers
SOURCE: fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
Posted on Mar 18, 2009
  • 441 Answers
SOURCE: Samsung RS267TDRS Refrigerator -- no water coming
The most common reason water stops are 1. The water line has frozen, but its not the part in the freezer door. Behind the crisper bins in the fresh food section, you might not see it but it behind the back wall. Heat up that area with a hair dryer, or if its not full shut it off for 24 hours and it will do the trick. 2. The pump that sends the water to the dispencer is dead, it will be located behind the ref lower left hand side behind panel (follow the water line) part # DA74-40149D, you can order it at marcone.com for about 27.00
Good luck, if those dont work let me know
Posted on Nov 11, 2010
heatman101
  • 43501 Answers
SOURCE: I have a two year
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 30, 2011
Freezing bottle water on top self and door and foo on shelf
I'm guessing you mean in the fridge, if freezing in the freezer you'd have no issue. Look inside fridge 7sually on back wall or ceiling, there will be a dial to adjust the temperature of your fridge, gradually set warmer until freezing food issues stop.
Dec 27, 2016 | Refrigerators
Samsung rf217acpn/xaa fridge not staying cold and ice build up.
Be sure the drain is clear these are well known for drain blockage. the area behind the shelves is where you would find the evaporator and drain hole.
"Always disconnect power before trying to repair any appliance."
Jul 11, 2017 | Samsung 19.7 Cu. Ft. French Door...
Water Filter Frozen
Air blowing directly on things like a water bottle has frozen it solid ( in the REFRIGERATOR SIDE! -- Block airflow BUT... I think the problem is YOU NEED TO CLEAN ( blow out with air!...the ONLY WAY) YOUR CONDENSOR COILS ( in the back, outside...behind the cardboard cover nowadays) Your fan has to run too long ( because refrigeration is the "removal of heat"...this is what those coils do but they are insulated with dust!)...too long blowing to achieve the same temp result = Frozen Stuff
Sep 24, 2017 | Frigidaire Refrigerators
I have an Gallery series Fridgidaire side by side fridge, model number GLHS68EJSB0... the line to the water filter keeps freezing and unable to depense water... we have the setting on the fridge set to the...
We have the exact same problem. But ours is in a vacation home so we have to keep the water turned off all the time. It seems something in the ice line freezes when the fridge is empty. Then, no ice, no water. When we turn the water back on, after a few days of having food in the fridge, it seems to make everything melt and flood the tray then leak out onto the floor all day and night. The fridge temp goes down to 12 degrees when the fridge side is empty. It seems to stabilize when there are items inside. We put several gallons of water inside instead of leaving it empty and it helps with the temp but not with the leaking. We have had service come out several times and they just said, "don't leave it empty and turn off the water when you leave." What good is that? I don't have water or ice for the weekend when I go up to the house! OR I clean up floods the entire time!! Now it's out of warranty. Now that I see it happens to people in their main house, I would just say NEVER EVER EVER BUY FRIGIDAIRE AGAIN!
Sep 24, 2011 | Frigidaire FRS3R5EMB Side by Side...
My house flooded this week causing damage to all flooring. What can cause water to suddenly come into the fridge? When water was turned back on there was water flowing under the fridge? Would a filter...
There are a number of things that would cause this, including the inlet valve and filter. However, a cracked filter is by far the most common cause. Remove the water filter and if it no longer leaks, the filter is bad. If it continues to leak, it is likely the filter housing that is the issue.
Sep 16, 2010 | Whirlpool ED2FHEXN Side by Side...
No water to the ice maker
filter cracked because it froze . changing the filter is not enough change the housing . as the lines are frozen and wll brake . mm
Apr 18, 2010 | Frigidaire FRS26H5AS Side by Side...
Frigidaire FRS23H5SB6 side-by-side freezing food
It sounds like the fan in the freezer behind the rear panel is not working. You should be able to hear it. It won't run with the door open so hold the door switch in.
Jul 27, 2009 | Frigidaire FRS26H5AS Side by Side...
Water filter in fridge leaks
if the filter froze, its probably cracked the housing.
Jun 05, 2008 | Maytag MZD2766GES Side by Side...
FILTER CUP&HS CRACKED,WATER LINE FREEZE
are you setting the stat right? lower the number, higher the temp. lots of folks think its the other way round. set stat to 2 or 3 and should be about the right temp
Jun 21, 2007 | Frigidaire FRS26KR4A Side by Side...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
220 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
