Question about Brother HL 1440 Laser Printer
Fuser malfuncion is it possible to fix this printer? LED lights indicate a fuser malfunction
Try this:   "turn off the power ,turn on the power holding the button, wait, then when the "drum" light is burning wait a sec then press the button again.  The printer will "dump" whats in its tiny 0.5mb memory and start a self diagnosis and will begin to print the results of the test."
Posted on Dec 18, 2007
  • 56 Answers
Yes, You will have to replace the Fuser for it to correct the problem!!!
Posted on Dec 05, 2007
How do I fix Fuser Error, when prompted
Replace the fuser unit. What make and model would help???? try this site for a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 30, 2015 | Office Equipment & Supplies
Printer prints out but all powdery and wipes of page .
I agree the fault is almost cetainly with the fuser unit.
Oct 30, 2011 | Samsung CLX-3170FN All-In-One Laser...
I am having xerox 3100 mfp,and since last 4-5 dys massage on the screen is displayin FUSER TEMP. how i can get rd of this? pl help
Fuser problem is that the thermistor can be damaged due to overheating Fuser thermistor or try to replace the entire fuser, clean electrical contacts which could cause malfunction of fuser.Este indicated a specialist to handle this
Mar 04, 2011 | Xerox Phaser 3100MFP/S Laser Printer
My Brother HL-2140 Went out in a storm. All three lights just keep blinking no matter what I do. Held down on the blue light button a number of time, restarted computer, turned off printer, reloaded ink...
You can find the usre's manual here:
1) If the LARGE BLUE BUTTON is blinking:
Data remaining in memory
There is remaining print data in the printer memory. If the Ready LED is blinking for
a long time and nothing has printed, press the Go button to print the remaining data
in the memory.
2) If the TONER LED is blinking:
Toner low
Indicates that the toner cartridge is nearly empty. Buy a new toner cartridge and have
it ready for when Toner life end is indicated.
The Toner LED will turn on for 2 seconds and off for 3 seconds.
3) If the DRUM LED is blinking:
Drum life end soon
The drum unit is near the end of its life. We recommend that you get a new drum unit
to replace the current one. See Replacing the drum unit on page 69.
The Drum LED will turn on for 2 seconds and off for 3 seconds.
4) If the RED ERROR LED is blinking:
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
Mar 26, 2010 | Brother HL 2140 Laser Printer
Oki C3200 message on screen says '171 Fatal
Yes it can be saved, it is indicating the fuser thermister is open or below temperature. Try opening the printer and restarting it. If that does not fix it you may have to replace the thermister or the fuser
Jan 18, 2010 | OKI C3200n Led Printer
Kyorcera FS1030D - error light sequence what does it mean
If you mean that the sequence is: 2nd led and then 1st+2nd+3rd
the problem is in fuser unit. You have to call a technician to check the lamp, the thermistor and the thermostat inside the fuser unit
Mar 16, 2008 | Kyocera Mita FS-1030D Laser Printer
Konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Nov 08, 2007 | Konica Minolta DiALTA Di200 Copier
Error message C4551 anyone? pretty please.
C3451: Heat. Heater Trouble
You have to check machine fuser unit .
May be paper on the fuser unit. Check fuser unit rollers.
After check fuser unit you have to ececute a "trouble reset".
Turn on your machine by press and hold "utility counter" botton, after some seconds press to display "TROUBLE RESET" and turn off and on machine.
C4551: Cyan laser Malfunction
Check cyan laser connection and execute trouble reset.
Oct 03, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Canon Error Eoo7
This error code indicates to the copier that the upper fixing film on the fuser assy is not rotating. Paper wrapped around the fixing film or the film itself is damaged may cause this. Unless you are very mechanically inclined , it will take the removal of the fixing assy and possibly the replacing of the fixing film assy. A tech would need to be called in to correct the problem. The fixing film is a replaceable item. Good luck.
Sep 26, 2007 | Canon imageRUNNER 8500 Copier
Brother HL 1440 Laser Printer Logo
426 people viewed this question
James Cagle
James Cagle
Jim Keysor
