Question about Maytag Neptune Washer
Maytag Neptune 9700 getting E3 code,done diagnostics,code shows 25,2E,& bE instructions say replace control board.Anyone else had same problem? Anyone replace board? Did problem resurface after replacing board? Would a replacement board have the newest version of software?
  • Whitt1968 Jul 02, 2009
    Basic E3 reads motor not running properly,could mean overcurrent,undercurrent,bad motor,bad tach,bad motor control board,loose wires.Usually with these machines and all their issues its a bad control board.If you are into this kind of problem do some research eliminate all the basic stuff before spending a lot of $$ on something major.I have determined on my machine (MAH9700) that it is indeed a control board.New here in Canada they are $300 just for the part. I found one on ebay used for considerably less (located in USA).
A 3E error is an overcurrent detection at the motor. Some people say that unplugging and re-plugging the connector at the motor clears up the problem.
Discussed here: http://applianceguru.com/forum2/6484.html
Posted on Jul 01, 2009
03 Error on Maytag Neptune front load washer
Hello & Welcome to FixYa
E3 is a locked hall sensor fault and is displayed when the machine control is attempting to drive the motor but is not seeing any tach response and the motor won't move. You can check for any loose wire connections before replacing the motor control board/motor. Please get back to me if you have any other questions.
Kevin
Aug 06, 2011 | Maytag MAH8700A Front Load Washer
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
E3 and be error on maytag washer
E3 error code is indicating that the motor should be running but the hall sensor for the motor is not sensing the turning of the motor.
Note - You could disconnect the power supply for few minutes, say 15 minutes and see if that resets the control board and solve the problem unless follow what was mentioned above.
For replacement instructions you can download this repair manual for your front load and follow the steps given in the manual and here the search parts.
Hope helps.
May 17, 2011 | Maytag MAH9700AWM Neptune Front Load...
Maytag neptune washer will not get up to speed in spin cycle error code E3
E3 means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code somes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 09, 2010 | Maytag Washing Machines
Not finishing the spin cycle and have a code that says dc
here is a website you can view a bulletin on the error code DC pertaining to your washer
http://fixitnow.com/wp/2009/06/11/e3-and-dc-error-codes-in-maytag-mah6700-8700-and-9700-washing-machines/
May 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Getting error E3
3E == overcurrent detected at the motor.
Open the control panel, there you will find a tech sheet that explains how to put the machine into service mode and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes. You will also find serveral other diagnostic service notes. Read them and follow the instructions to test the motor, motor control, and main control board. Hope this helps.
Jul 16, 2009 | Maytag Neptune Washer
Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
May 28, 2009 | Maytag MAH6500 Neptune Front Loading...
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
E3 code showing sometimes on Neptune MAH-3
Mar 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
373 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
