Question about Refrigerators
I have a 642/0 side by side sub zero. Although
I have a 642/0 side by side sub zero. Although the thermastat is set at 34 temp has been flucuating betweening 47 and 51 even when door is closed for long period.
I cleaned the condensor but it didn't seem to help
  • 52 Answers
Has the ambient temp around the unit been going up? Depending on what refrigerant you have here the pressure temp relationship will change in the system, also when you add foodstuff, and again when you open the door.
Posted on Jun 29, 2009
Sub Zero 642 side by side, refrigerator side not working.
If the refrigerator compressor runs and cools when you use the manual activation mode but does not run normally then the control board would be what I would suspect. If it has the manual activation then it is new enough to give error codes. If it is not running and not recognizing it's not running, something is wrong with the control. Unless you are seeing two dashes in the refr display. That would mean the refr section was disabled.
Jan 11, 2016 | Sub-Zero 642
Sub zero 690 control center readout
A picture would be helpful, but there should be two 2 digit numbers. the one on the top should be fridge temp reading somewhere around 34-40, and the bottom one should be freezer temp, reading around -2 to 05.
Feb 25, 2013 | Sub-Zero 690 Side by Side Refrigerator
I have sub zero 642 and my techinician says that I need a ice make valve replacement. He says it costs $495, does that seem accurate?
Sub-Zero a hallowed name in refrigeration, and the 642 side-by-side refrigerator/freezer unit is a landmark Yeah, it's that impressive. Dual refrigeration uses two compressors and three evaporators, I can tell you to never expect less than $300 for calling anyone to your home!
Aug 10, 2011 | Sub-Zero 642
The freezer side of our sub zero 642 is over heating - I have set the temp control but it immediately jumps from 5 to 30 degrees within seconds - I am not sure what is causing this
ck the cond coil and if dirty cclean it and make sure the fan on the coil is workiign / if this does not correct problem change the tempt control .. mm .. do the general mantaince first then look for the tuff stuff. mm
Jul 22, 2010 | Sub-Zero 642
Although my sub zero 642 is holding the temperature, there is water leaking from underneath the refrigerator every day onto the floor. Sometimes it is heavier than others.
it's condensate from the evaporator coils. when the humidity collects on the coils, it should drain into a pan under the fridge that gets evaporated from the hot-side line. check to see if the condensate tube from the coils is still in the pan.
Jul 29, 2009 | Sub-Zero 642
Sub Zero 680 freezer temperature problem
check the condencer on top .open the doors look up you should see three screws take them out and pull down the panel and clean the condencer if its clean CALL repair guy!
Jul 24, 2009 | Sub-Zero 680 / F
Main door handle top section pulls out from bolt on sub zero 642
There is a tiny set screw that holds that in place. It is on the bottom of the stand off and just needs to be tightened.
Nov 26, 2008 | Sub-Zero 642
Handle has come off of Sub Zero 642
I assume you have the long stainless handle. If so there is a tiny set screw on the stand off. It is on the floor side and just needs to be tightened.
Nov 25, 2008 | Sub-Zero 642
Sub-Zero temperture fluctuation
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be an issue with Sub-Zero.
Aug 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
