Question about Hobart Dishwashers
Code e3 on model Lx30c Hobart dishwasher what is this code
SOURCE: hobart amx/aux-s dishwasher "bof" error code
press the 1st and third buttons on the display nxt to the start button then press the start button,this will change the the display to something like BOF1 then allow the achine to fill the rinse tank you will know when this has happened as the display will go out (all of it) then you can turn on the machine using the button marked with a I the start button will light red allow it to go green and you are ready to go ... if when you are boffing it it changes to FIL the your water pressure is to low good luc fella
Posted on Mar 04, 2009
  • 109 Answers
SOURCE: Hobart dishwasher model LX30H; displays wrench and E4.
Water is not to top sensor in alotted time.
Top sensor is in right rear corner, and is the upper of the two. Check the connector to the probe on the outside at the back. (sometimes gets wet fro vacuum breaker leaking when dirty or low flow pressure. Machine needs 20 psi flow rate
Posted on Aug 14, 2009
SOURCE: what is p3 code on hobart am15 dishwasher
Our AM15 Hobart dishwasher is showing the wrench symbol. Past answers suggested repalcing the thermistor. I did that. Then I did a hard reset on the dishwasher, but the wrench symbol is still there. The water is only getting to 160 not 180. Now what?
Posted on Nov 13, 2009
  • 110 Answers
SOURCE: Hobart dishwasher model LX30H displays -5 on
by the way you're describing the problem, i would have to say there is something wrong with your control board. part#473173 can be bought @ any hobart office in your area. dont forget to vote
Posted on Feb 13, 2010
Testimonial: "Turns out it was mice eaten wiring."
SOURCE: wanted hobart dishwasher model am700 manual
wanted hobart dishwasher model am700 manual, where could I find it
Posted on Nov 21, 2011
Hobart lxih stuck in Delime loop. After I turn off and attempt to run the Delime cycle it fills and I get another E3 error. Any thoughts? Thank you
E3 is low water level. This can be from a number of issues. Water pressure, fill solenoid, level sensor. Check these 3 to start, as its most likely one of them
Jan 11, 2018 | Hobart Dishwashers
What is a E3 code on the lxi hobart dishwasher
I just searched and find no information on Hobart machines
Feb 26, 2015 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Bof fault code
The display of "BoF" on the display is simply a confirmation code to commence the next operation on the dishwasher. It is not a fault code.
Refer manual of a AMX model Hobart dishwasher. If your model is different the general codes are same.
http://www.dishwashers-direct.com/uploads/Operating%20instructions/Hobart/AMX%20RANGE%20OP%20MANUAL.pdf
Apr 19, 2014 | Hobart Dishwashers
What type of detergent is used for a lx30c hobart undercounter dishwasher
What type of detergent is not necessarily important - anything intented for use in commercial dishwashers should be sufficient. A restaurant supply store should have something suitable for you.
Also, in case you don't already know, the LX30C is the non-booster-heater version of the LX30 (LX30H has a booster heater). Without a booster heater, you'll need to use chemical sanitizer. The LX30C should, hopefully, have a sanitizer pump installed to inject chemical sanitizer into the rinsewater stream. Most of these dishwashers also have a detergent pump to inject detergent into the wash tank and rinse aid pump for chemical rinse aid.
If present, these pumps are located in the bottom of the machine. Remove the lower front panel (2 screws) and look for the small, black plastic assemblies with 2 hoses connected to each.
Mar 13, 2012 | Hobart 24 in. LXIC-5 Built-in Dishwasher
I would like to get a manual/guidefor dishwasher DW009H from B&Q . Drying does not seem to be very thorough at the end of the cycle. Also the code E3 is showing when finished.
E3 Error Code
Cause: The water heater element does not work properly or the filter mesh is blocked.
Remedy: Clean the filter mesh and if the problem continues please contact service
As far as a manual is concerned, I believe Hobart manufacturers your model and not B&Q. B&Q just sells the unit. You may want to locate a Hobart dealer in your location to try to get the manual. You will probably need one to fix the heater element any how.
Jun 05, 2011 | Dishwashers
E3 Error code on hobart lx30 dishwasher.
my dishwasher Hobart LX 30 will not shut off and displays 30
Jan 21, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart glasswasher: code E3, not working, not pulling rinse aid
The error you see is that the dishwashers chemical board (located on the back of the machine) isnt sensing the chemical.First thing to check is remove the lower front panel,2 philip screws.On the left you will see 2 pumps one on top of the other.
They may be marked (det and r/a),turn the dishwasher on these 2 pumps should run.If they dont your pump may be bad or the control board.Run a full cycle to make sure.
If they do run i would make sure the standpipe in the r/a bottle isnt kinked or the tubing.Let me know,i'm a hobart tech.
Apr 11, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX30 error code wrench & E5
What error code is displayed?e1,e2,e3,e4?I'm a hobart tech let me know.
Apr 10, 2009 | Dishwashers
Hobart LX30
Hopefully you took the suggestion to run the correct 50 amp 208-240 service to the unit.
Converting the unit to an LX30C has a couple of pitfalls. The LX30C is connected directly to the incoming water supply, which should run 120-140 degrees. By reprogramming the unit as an LX30C, the booster would be disabled, which would mean the incoming water would flow through the de-energized booster and be cooling off while it sits in there between cycles and when the unit is shut down.
The incoming fill plumbing (5/8" heater hose) would have to reconnected from the fill solenoid valve directly to the vacuum breaker on the rear of the unit to bypass the booster heater.
On the 208-240 volt LX18/30/40's, the pump motor, booster heater, and sump heater run on 208-240. To convert it to 120 volts you would have to replace the sump heater and reconfigure the motor wiring in the motor junction box.
By the time this is all done, you've downgraded a great machine, confused the next service guy, and have to deal with nasty chlorine and all of it's headaches.
I
Aug 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart lx30 E3 error
Error Code E3 relates to a problem with the fill. Specifically that the water level has not been recognized at the middle water sensor. This can be caused by a problem with the drain system as you describe, or by low water pressure to the machine (should be 15-25psi flow), or bad wire connection to this middle sensor.
Check for proper water pressure first (should be a gauge on the machine) during the fill. Then check / repair drain as needed. These will probably eliminate the problem
Jun 19, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwashers Logo
97 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
