I have a set-back number on my thermostat
I have a carrier central air conditioning system and the previous owner set the thermostats to a ''set back'' of 75 degrees and no matter what we do, it keeps going back to 75 degrees and my electric bill was huge. How can I change or clear the set backs?
  • 1 more comment
  • deassis Jul 02, 2009
    The thermostat is by Carrier and it says VVT on it. I hope that is the info you needed.
    What is the "hold" button? We have an up arrow and a down arrow... that's it.
  • Robotinner May 11, 2010
    What is the model of the stat and the manufacturer
  • 38 Answers
The easiest way with a programmable t-stat which i assume it is, is to set the temp you want then press the hold button, otherwise if it isn't held at that temp at different times of the day the t-stat will resume its programming schedule.
Posted on Jun 30, 2009
I don't know a good setting on a robertshaw 9420 thermostat, for really cold,and fast air condition.
Well Brian, an air conditioner creates the same temperature drop across the evaporator at any thermostat setpoint, so there is no setting that will get it really cold really fast. If your return air is 88 degrees (in a hot house where the system has been off) the supply air temp is going to be near 68 degrees..... as the a/c runs, the air changes within the structure cause a reduction in the average return air temperature and slowly drops the return to 87, then 86 then 85 etc, etc and the corresponding supply air temp continues to drop from 68 to 67 to 66 to 65 etc etc. Eventually the supply air temp after the appropriate 'air changes' within the structure will drop to 55 degrees and possibly even lower to satisfy the average room temp at 75, 74, 73 etc. to a point.
There are SOME newer a/cs that have two speed compressors that may effect the supply air temperature drop under differing load conditions, but thats a different ball of wax.
So, if you want it cold quickly you are out of luck, just leave the t-stat set at 70 degrees and pay the electric bill when it comes in.....
Dec 25, 2014 | Heating & Cooling
Set thermostat at 74 heat pump will not cycle it will cycle at 75 degrees ?
check stat calibration. see if you can measure temperture at stat. the thermostat cover temperture reading is not that accurate.
Jun 01, 2014 | Goodman CLQ36AR49 Air Conditioner
What does -AC on honeywell chronotherm III thermostat mean?
AC means "air conditioning." If the AC icon is showing on your thermostat it means that your air conditioning is activated and should come on when the temperature threshold you've set on the thermostat is reached.
For example, if you've set the temperature level to 78 degrees, when the house temperature goes above 78, usually by about two degrees, the air conditioner should cycle on to cool it back down to 78 degrees at which point it will then turn off.
This information should be in your air conditioning/heating system or thermostat owners manual. If you don't have the manual, you should contact your air conditioning dealer or your builder to secure a replacement. The manual is essential for proper operation and maintenance of your system.
May 14, 2014 | Heating & Cooling
I have never used central ac before - how do I set it? If it is on 75 will that cool the house? If I want it cooler, do I put it lower? like 65?
As to your question 'will 75 cool the house?' The answer is 'yes' - if the outside temperature is low enough. Typically speaking you can expect your central AC to cool a properly insulated house to a down to a temperature of about 20-25 degrees lower than the outside temperature. For example - if the outside temp is 95 degrees. You could expect to get your house down to 70-75 degrees. If the outside temp is 110 degrees then you could only expect to get the house to 85 or 90 degrees.
So .. as you can see - your 'inside' temp will be directly affected by the 'outside' temperature.
As to the operation of central air; it is very simple.
I would suggest that you not pay 'too much attention' to what you have the thermostat set on. A comfortable temperature - is a personal thing - so - I would set it somewhere - say 72 and see how I (and others in the house) was handling that setting.
If you want it 'cooler' just 'notch' it down a degree or two - if you need it a little warmer - turn it up a degree or two. Do this "fine adjusting" till you have the temperature setting you are comfortable with.
Usually the more you can leave your thermostat alone the better off you will be from a comfort position and an electrical useage standpoint. Obviously, the higher you have your thermostat set the 'less' it will cost you on your electric bill.
How high you set the temperature is a balance you have to come to based on how comfortable you want to be - matched with how much you want to hold down the electric bill.
hope this helps
Aug 14, 2010 | Honeywell Heating & Cooling
My air conditioner will kick on but will stay on and not
The thermostat is not functional, therefore its not cutting off the compressor once the room air gets cooled to the temp setting of the thermostat, also the refrigerant gas may have leaked out some but not the entire refrigerant gas(freon, CF4, etc.), keeping the compressor running contentiously to come down to the set temp..............sodeep
Aug 20, 2009 | Carrier 38CKC042 Air Conditioner
My problem is in addition to moisture near some duct outlets the thermostat always go 2 degrees below the set limit .I also have a carrier infinity system installed only 1 yr, had the problem from the...
if you have a mercury thermostat and it is not leveled properly it will turn the temperatyure on and off by a couple of degrees
some thermostats have the capability of running the unit longer than the set temperature
i would recommend calling a local heating and air conditioning contractor and get the unit cleaned and bring up the issue then
Aug 04, 2009 | Heating & Cooling
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Air conditioning unit not cooling
the problem sounds like a defective capacitor its located on the condensing unit outside, also a contactor that is used can be defective also.
Jun 05, 2008 | Carrier 38CKC036 Air Conditioner
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
Heating & Cooling Logo
71 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
