I had the bulb blow out in my Sony 60" projection TV. I replaced the bulb and with in 2 weeks I had the on screen notice appear that the bulb was failing. I returned that bulb for another one but the on screen notice is still there. Can this be reset or do I have a 2nd bad bulb?
  • jeffnkim520 Jun 29, 2009
    The model of my Sony TV is KDS 60A2000. I went into the menu screen and the only selection I saw that might work was resetting to factory defaults, that didn't work. Any suggestions at all would be greatly appreciated.
  • video-tek
    video-tek May 11, 2010
    Hi, some sony models need to be re-set, usually in the "menu section", you need to post your model number or we can`t look up the procedure for you, please re-post , video-tek
  • 261 Answers
Have you reseted the lamp timer of your tv? if not, you should do it, because it's just adding more and more hours to it to the ones it already had and it's indicating the tv that the lamp is going out, reset the lamp timer and you should be fine, if not, it's probable you might have a defective ballast which are not expensive, they're way cheaper than a lamp, they're running around 70 dlls
Posted on Jun 29, 2009
I have noticed the screen is now not as bright as it use to be, still works just not bright. A darker look is the best way to describe it
The most common indications of a weak bulb in a Sony LCD Rear Projection TV are:
  • Dimimage with low brightness and contrast.
  • NoPicture, Dark Screen.
  • Shadowsin Image, sometimes circular.
  • Intermittent Shutdown.
  • Fluctuating or Flashing Brightness.
  • Longerthan Normal starting time.
Also check for distortion caused by Optical Engine Failure. If any of these faults are present, bulb will not fix. Sony Optical Engine Fault Gallery
Here is a link for Identifying Sony TV Lamps.
easyab@hotmail.com
Feb 11, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a 60" Sony
It seems lamp/ bulb popped again, check lamp inside tv.
If tv does not show red blinking light then it would be lamp that knocked off, replace lamp in tv to fix its problem, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Jan 15, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Blue tint at the bottom of the screen
No, it's a sign of bad convergence. Fix it from the convergence menu.
Jul 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Blue dots appearing on screen n bulb blew twice
IT NEEDS A LIGHT ENGINE. COST A LOT TO REPAIR.
Oct 06, 2009 | Televison & Video
Sony xbr 60 tv has lost red color
SONY IS INVOLVED IN A CLASS ACTION SUITE-problem is a bad light engine-check into this on the web-check your model number to see what they are willing to do.
IT IS A COSTLY REPAIR IF YOU HAVE TO PAY A TECHNICIAN
Sep 03, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
LOST THE LIGHT BULB [SET ON RIGHT SIDE OF SCREEN] THEN LOST BLUE
I replaced bulb on SOny XBR 60 with sony brand bulb about six months ago. everything was fine, then a week ago it seems that I lost the "red" portion of the color. Any suggestions?
Jul 23, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
The green is taking over all the color on the tv
March 14, 2009
I have the same TV which had the same issue ( green in picture ) - back on 10/2007. I called Sony. They had their technician replace the optical box ( factory defect ). There was no charge for the repair even though TV was out of first year of warranty. Call Sony.
Sony Repair (866) 282-7412
Mar 12, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Turns on and off green LED flashes until TV turns back on.
this is a symptom of a bad lamp. for some reason it won't spit out a lamp error. shaking up the lamp will sometimes fix temporarily but you will find replacing to be the answer. if your tv has a fan error, you will get 4 red blinks.
Dec 09, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Televison & Video Logo
213 people viewed this question
Top Televison & Video Experts
