Question about Poulan Weed Eater Electric Blower/Vacuum 12a
WILL NOT START checked spark plug it's ok has no fire to plug
  • 279 Answers
Probably the ignition module. Try: www.baileysonline.com . If you have a digital camera, try taking pics as you dismantle the machine. Use those pics to reassemble...Lee
Posted on Aug 05, 2009
Nissan sentra 2000, start but not fairing, spark plugs have been checked, fuel pump is ok. What we be the problems?.
Start, but not... what? "fairing"? You mean firing? But if it starts, it has to be firing the spark plugs?? If not firing, then ignition system is not working-plugs, plug wires, ignition coils, ignition control module, crank position sensor, and ecu- these are all part of the ignition system.
Mar 02, 2016 | Nissan Cars & Trucks
I just put an engine in a 1972 VW bug just won't start firing order is fine top dead center is fine just turns but doesn't want to turn over
Hi Timothy:
Old Dude wisdom..........
- Fire at the plugs and
- Fuel in the jugs
If everything else is OK it should run. Not necessarily well, but it should run.
What to do?
1) Check for hot blue spark at the plug electrodes
2) Check for fuel in the carb.
If you have spark, give it a shot of gas into the carb, and give it a try. If it doesn't start, backfires, or catches fire, you'll need to double check the timing and plug lead firing order.
Not kidding! Don't set fire to it!.
Jul 13, 2015 | Cars & Trucks
89 camery no start , has fuel p.s.i. , injectors fireing , spark on all plugs , compression even across
Have you checked cam timing?If it has jumped a tooth or two it will not start.
Jun 18, 2017 | 1989 Toyota Camry
2001 Nissan Pathfinder won't start, fuel pressure ok, spark plugs not firing
make sure you have fire at the coil if not there will be no fire to the plugs
Feb 08, 2013 | 2001 Nissan Pathfinder
2001 Kia Rio, motor start very well first time after drive around 2 miles motor no start no more
For spark plug problem,click the help links provided below :---Car has no spark?http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
------------How to Replace Spark Plugs?http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
-------------Car cranks, has spark but will not start?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
----------How to gap spark plug ?http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html-----------Spark plug Replacing for?http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
-----------How to identify number one spark plug on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
---------How does the spark plug wire go on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
---------Spark plug Firing Order Diagram?http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Feb 03, 2012 | 2001 Kia Rio
We have a Honda GX160 powered generator. It just won't start. We have changed the spark plug, air filter, checked the fuel lines and all look ok. We have checked the on/off switch and that is ok too. The...
Sounds like the carburetor is plugged up on this generator since starting fluid starts the engine.
Rebuild the carburetor to get it to start.
Jan 19, 2011 | Garden
I GOT NO FIRE ON THE PLUGS
The spark gets power to spark from coil packs.If the connection between coil pack to spark plug is weak or loose then it will not fire.But if the coil pack as well as the connection between coil pack to spark plugs checked ok then its faulty or dirty spark plugs.Clean the spark plugs with the carb cleaner liquid and let it completely dry.Then check.Also check the voltage between coil pack to spark plugs.If both checked out ok then the other possibility can be weak crank shaft sensor. Thanks.Helpmech.
Nov 12, 2010 | 1995 Dodge Dakota
Fuel and ingition ok will not start new spark plug try to start and the plug gets wet have checked spark and plug is firing when checked
check the muffler to be sure there are no blockages. wasps love to block them with mud. ive seen this before
Apr 02, 2010 | Garden
Won't start
1: remove spark plug from engine...connect the spark plug cap to the plug...and make the other end ground somewhere on the cylinder head...kickstart it and check for fire...if not change spark plug and test spark again...if there is no fire again...you will have to get a owner manual to check electrical component with impedence...if fire is ok .....and wont start
2: put some gaz into the spark plug hole put the spark plug on with wiring and crank it again
if it start and stop after a moment...then you're carburetor is not providing fuel to motor....
3: if it is not starting yet....check for compression or blown crank seal...or leak
Sep 14, 2009 | 2001 Yamaha TW 200
Brand new , won't start, no spark at plug, switch ok
If you know for sure that it's not getting fire, then I would take it back to where you purchased it. It sounds as if it has a bad ignition module.
Jim
Jun 20, 2009 | Troy Bilt Tb70ss Gas Trimmer
Poulan Weed Eater Electric Blower/Vacuum 12a Logo
290 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
