Question about John Deere Tractor Side Screen 1050,1520,2020,2030
I have a 2020 jd it over heats after about 1 hr work radator is clear?
    President:
  • 986 Answers
That radiator is not in the best place ,wash it out real good it usally has hydo leaks that drips on the radiator then collects dirt
Posted on Jul 29, 2009
Compression in a 1966 john deere tractor its a 2020
is this a multi cylinder diesel farm tractor or what
remember that questions go global and you have to be specific in details as a jd unit 202 in your country may be a 1212 or what ever in another country
however moving on , if it has more than 2 cylinders , the problem can be a head gasket blown between adjacent cylinders , cracked head or valve problem ( burnt or incorrect valve adjustment)
same ideas apply to petrol engines as well
Dec 15, 2015 | John Deere Garden
2000 elantra overheats replaced thermostat bottom hose cool
You might need to fluss the radator out with a hose pip. take the botom hose off and take th radator cap off. then crank the car up. stick the water hose in the top of the radator were the cap you took off and let the water run throu the radator for feww min.
Aug 18, 2012 | 2000 Hyundai Elantra
I cannot get the three point hitch on my tractor to come down. The internal and external controls will not work and even heat will not loosen it up
HAVE YOU TRIED ADJUSTING THE DOWN SPEED? ON MY
1967 JD 2020 THE ADJUSTING SCREW IS LOCATED AT THE
CENTER OF THE TRANSMISSION CASE BELOW THE FRONT EDGE OF THE SEAT. LOOSEN THE LOCK NUT AND
ADJUST THE SCREW TO OBTAIN THE DESIRED SPEED.
Jan 02, 2011 | John Deere 420,1020,2010,2020,2510,2520...
I have a JD 2020 1970. The brakes lock up when I
sounds to me like the caliper/piston/cylinder is freezing up on it
try looking at replacement
Oct 10, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Engine shutoff when hot.....jd lawn tractor 170
if the engine shuts off when it runs and then will start back when cool you have a bad coil
Sep 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Clutch problem
Hello:
It Sounds like the Clutch Idler is Bent and Requires Replacing.
A Homeowner can Replace the Clutch Idler Arm and Pulley with Little to No Worries.
You can View a Breakdown of this Unit at the Following Site Addy.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Enter the Model Numbers 2020 and CLick Search. Now Select your Model and then Select Sectional Index.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Tractor Side Screen 1050,1520,2020,2030 Logo
130 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
