Question about Ericsson Sony Wireless Headset for Bluetooth Phones - HBH60 Headset
My phone is bripping and cant receive or write message it sends busy tone and it moves from feature and has no demotour is deleted, am frastrated and i love it too much just advise me because i had the first one and it started the same proble and no body could work on it . is it that they become worn out after some time ,ibought it 1yr ago,plizz am totally deparate where i am cant by a good phone so am depending on u
I can't send or receive faxes.
You have connected the phone line, right? Checked the phone line with a phone and you get a dial tone?
Aug 31, 2016 | Canon Pixma MX410 All-In-One Printer
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
How to send and receive Business Card from Samsung Galaxy S GT-I9000
Thanks for the tips.but what about receiving the business card.i always cant receive the bussiness card when people send it to me
Feb 19, 2011 | Samsung Galaxy S GTI9000 Smartphone
My Samsung B7320 doesn't allow me to select a message ringtone from my Storage Card...i've tried moving/copying the files in storage card to My Sounds but i cant seem to see any of them there...how to...
first you can try going to your settings and selecting phone settings then go to connectivity and then select usb mode click on media player tab. then u need a usb cable plug it in to ur phone and your pc then transfer the songs from your your storage card to your media player then remove storage card and transfer songs from media player to phone they should automatically b sent to your music folder in your audio section of your my stuff folder from there you should be able to select it as a message tone. if that doesnt work you can try one more thing. you can send the vibration feature to your storage card and it should automatically associate your music with the vibrate feature then set your messag tone to vibrate 7 ring and pick a tone to go with
Jul 24, 2010 | Samsung Omnia Pro B7320 Smartphone
I cant receive or send mms messages
To send or Receive MMS you have to call your Customer Care and inform them to Activate that feature to your sim and then only you can able to send MMS
Feb 26, 2010 | Dual Electronics CECT P168 Cellular Phone
It cant take a free tone or send picture messages
you need to call the customer service to activate your MMS service. they will send you a service message
Nov 12, 2009 | Nokia 2680 Slide Cell Phone
My Motorola Moto Q can recieve messages, but can't send them.
check the settings of your phone.the battery has no relation whether you cant receive messages or you cant send unless it is fully charge when you use it...what you will goin to do is to re-format your phone. .
Jun 28, 2009 | Motorola Mobility Moto Q
Can't send text message. "unable to send message"
check your message centre number..If its edited or deleted..u cant send or receive any messages..contact your operator for tat number..
May 21, 2009 | Nokia N73 Cellular Phone
Have a new all in one printer (print, fax, scan and copy) feature
Here's where a Panasonic TA-824 would work great. At a street price of about $200, you can control your 3 lines and up to 8 extensions, one of them being your fax machine that would have access from both lines, and an answering machine that could take messages.
Some of the fax machines can detect a fax tone on a phone line, so you could have the answering machine answer the call and you tell them to press send (or it listens for a CNG tone, but the fax machine is limited to only one line.
Carl
Apr 01, 2009 | Panasonic KX-TG2740 Cordless Phone
Nokia 6600 no new message received display
HI Qrasengan,
1) Open the menu, and go to profiles.
2) Enter the general option, and click on personalise.
3) after that, several option appears.
4) some of them are ringing tone, ringing type, ringing volume, message alert tone, vibrating alert, etc.
5) Go to message alert tone and change the tone u want to listen when message is received.
NOte :Only wav or midi formats are accepted as ringing tone. MP3s are not accepted as ringing tones in NOKIA 6600. U need to install a software "mp3 as ringing tone" or "mp2wmaogg.codec" to make mp3 as ringing tone.
If u want that software, send me feedback or reply.
And I will deliver u as email in ur email id.
Sajan(sajwhat_2003@yahoo.com)
May 03, 2008 | Nokia 6600
Radio Communications Logo
41 people viewed this question
Top Ericsson Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an Ericsson Radio Communication Expert? Answer questions, earn points and help others
