Question about Samsung SGH-D980 Cell Phone
When I try to search for an entry it will not find it if the entry is in the sim card. Why? Is it a fault of the firmware? Is there an update?
Go to "phonebook", then "more", then "settings", then "view phonebook from" and select "sim"or "all" or "phone" and see what happens.
I had all my contacts in sim and when all was selected the phone would not search. So I slelected from sim only and it works ok ???
You may have to copy all contacts to sim and work around it that way.
Posted on Jul 02, 2009
Am having nokia 7210 supernova,recently it is showing no sim card inserted .if cahanged onother sim card again it showing as it is,what 2 do
TRY REINSTALLING YOUR PHONES FIRMWARE USING NOKIA SOFTWARE UPDATER.IT MAY SOLVE YOUR PROBLEM IF THIS IS A SOFTWARE FAULT.
GOOD LUCK
Sep 20, 2011 | Nokia 3120 Cellular Phone
I purchased an IPhone from
You need to install the old firmware back. It is quite difficult to find a firmware downgrade, let see.
Jul 14, 2008 | Lands Phones
Hi i have nokia 8800 e-1 shaphire arte and the phone work fore one day but nekst da i cant call out or take call inn? so i vonder what can bee wrong and i hope you can help
Hi.
Do a firmware update. This phone uses FOTA technology that allows doing the firmware update straight on the phone, downloading firmware directly from Nokia server.
To do the update:
Select Menu > Settings > Phone > Phone updates
Try also replacing the SIM card for a while to test if problem was SIM card. A defective SIM can cause similar problems.
If that does not work, try:
Select Menu > Settings > Rest. factory sett.
That will reset phone to factory, data and addresses won't be deleted.
Here manuals.
Nokia 8800 Arte User Guide
Download - Nokia 8800 User Guide
Sep 01, 2010 | Cell Phones
MC70: the scanners are becoming slow, not loading and no...
You could try and blank the Application folder. This would require installing any software and settings you require:-
Clean Boot Files for WM5
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=11744&sliceId=&dialogID=175898313&stateId=1%200%20175894231
Clean Boot Files for WM6
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12268&sliceId=&dialogID=175898313&stateId=1%200%20175894231
Also there is a firmware update for the Siemens MC75 v2 GSM card. That may help your SIM issues.
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12351&sliceId=&dialogID=175898529&stateId=1%200%20175894293
If its not that try and clean you SIM card and contacts.
Hopethis helps.
Ifyou need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.comor TEL 01202 620955
http://www.biastechnology.com/
May 17, 2010 | Symbol MC70
My iphone is only for emergency call only!
The easiest solution is to put in a sim card of the carrier you bought the iPhone from. If you can't do that you need to jailbreak and CID unlock the iPhone.
Without knowing which model, firmware or any details at all (as you provided none). I can only refer you to a tutorial on how to jailbreak an iPhone:
On the 3.0 firmware: http://www.iclarified.com/entry/index.php?enid=4254
On the 2.x.x firmware: http://www.iclarified.com/entry/index.php?enid=1558
Sep 06, 2009 | Apple iPhone 3G Black Smartphone
Storm 9500 invalid sim
did you upgrade/update the software or firmware on the phone after you put your sim card in? a lot of times, with unlocked phones, if you flash them or update certain software/firmware, it resets the phone so it is required that you unlock it again.
Jul 29, 2009 | Samsung SGH-E900 Cellular Phone
Already have numbers saved to phone, trying to save to sims card, please help! I am purchasing a new phone and want to be able to insert the sims and have the numbers.
How Do I Copy Contacts From My SGH-d807 Phone To The SIM Card?
To copy an address book contact to the SIM card follow the steps below:
While in standby mode, press the left soft key for Menu
Select Address Book (8)
Select Contact List (1)
Select the desired contact entry, stored in your phone's memory, using the navigation keys
Press the left soft key for Options
Select View (1)
Select one of the contact phone numbers, using the navigation keys
Select Copy (3)
Select SIM (2)
Press the left soft key to Save the single contact phone number to the SIM card
Note: Each phone number for a contact must be individually saved to the SIM card
PS-Not sure about updating/replacing entries though, which is what you may have been asking about
Dec 28, 2008 | Samsung SGH-d807 Cellular Phone
MY IPHONE COULD NOT RECOGNIZE MY SIM CARD AFTER I UPDATED TO IPHONE 2
the 2.0 firmware update disables the Zibri unlock.
No big deal, you have to use Pwnagetool/Winpwn to unlock it.
youll find great tutorials for mac and pc here:
http://www.iclarified.com/entries/index.php?caid=2&scid=11&seid=1
good luck!
Aug 20, 2008 | Apple iPhone Smartphone
Address Book Entries Gone
go to menu and then contacts hit option and the copy from sim to phone and you will find all your contacts
Oct 08, 2007 | Motorola Mobility RAZR V3
Wrong sim card problem with SE P910i, not P900 but pretty similar anyway
I don't have a solution, but my P910i did this immediately AFTER I did the firmware upgrade. The local repair shop refuses to look at it as the tag and internal IMEI numbers are different. I suspect it was repaired before and the tag not changed. I am still working on it and will let you know. But its xmas and Australia rolls up the sidewalks shuts off the streetlights and stops.
Jun 30, 2006 | Sony Ericsson P900
Samsung SGH-D980 Cell Phone Logo
110 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
