Question about NorStar M7310 Phone
Edit time on norstarM7310
How to change date and time on NorstarM7310 phone
    Problem Solver:
  • 18 Answers
Feature **8463 and the password is 266344.
After that it will give u option of cahnge date and time.
Thanks
Posted on Jul 12, 2009
Date is wrong on neff watch
Keep pressing mode until you get to where you get to edit the time and press the "light" button until there's a big number and that's the month and keep pressing the light button and you can edit the date and what day it is
Dec 16, 2012 | Neff Flava Watch Watches
I dont now how edit date and time?
go to phone settings and select time and date settings..there you can edit the time and date.
Apr 28, 2011 | Cell Phones
..clock did not change over
If you cant change the time and date in your control panel, you can try to edit the time in your bios, when you start your computer just click the delete key and you will see your bios setup page, try editing the date and time there.
Hope this one works. Thanx
Apr 02, 2011 | Computers & Internet
How do you change the time on a dymo datemark
Hi there!
Here's what you can do"
1. To set the current date and time, press and hold down the SET/EDIT button for a few seconds. Release the SET/EDIT button when the Month (M) and Day (D) indicators start flashing.
Note: The unit will revert back to normal display if no other key is pressed for 10 seconds
2. While the Month (M) and Day (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
3. Once you have chosen an appropriate date format press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR, and MINUTE fields. The field that is currently active will start flashing. To change the field's value press the LOCK button. Each stroke of the LOCK button moves one value up.
Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189 and back up to the current year.
4. Once you are finished setting the Date and Time press the Set/Edit button to return to the normal display. The Date/Time Stamper is now ready to print..
Hope this helps!
Vikroks
Mar 29, 2011 | Dymo DateMark Date/Time Stamper
WHEN I GO TO EDIT A CALENDAR ENTRY I DOUBLE TAP ON THE DATE TO CHANGE IT AND THE EDITING SCREEN WILL NOT OPEN, IT IS THE SAME IF I WANT TO CHANGE THE DETAIL OF THE ENTRY OR THE TIME
If you can't do it by double click the you must do it manually step by step. If you want to edit or add entry in calender or change the detail you can do it by click the entry once, then click the Option button, choose edit (to edit entry) or Add entry (memo, reminder etc), then the editing screen will appear and you can rewrite your entry.
Hope this help and if helpful RATE please.
Feb 09, 2011 | Nokia N97 mini Smartphone
Change time manually on blackberry bold ?
go to settings, go to time and date, edit the time in there.
Oct 30, 2010 | RIM BlackBerry Bold Smartphone
Need to reset date and time after changing the
Here's the instructions on how to do that :
Quick Instructions on Setting the Date/Time:
    Note: The unit will revert back to normal display if no other key is pressed for 10 seconds.
The manual for this device can be found here :
http://images.cableorganizer.com/dymo-label-printer/DateMark_Time-Manual.pdf
Oct 26, 2009 | Dymo DateMark Date/Time Stamper
Panasonic KX-TG2583. How do I change the time?
TIME/DATE ADJUSTMENT:
Press Function/Exit/Ch on the handset.
Press the up & down arrow keys until it points to 'program'
Press the Fwd/Edit > (yes key)
Press the up & down arrow keys until it points to 'tad program'
Press the Fwd/Edit > (yes key) the base unit will now display programming opitons.
Press '0'...'set time' is announced
Enter the time (hour & minute) using a 4-digit number
(Ex. To set 9:30 enter 0930)
Press * to select AM or PM
Press # repeatedly to set the day.
SELECTING THE NUMBER OF RINGS:
Press '2'...the current setting is displayed on the base unit
Press 0 or 2 or 7 to set the number of rings
(0='Toll Saver, 2=Two rings, 7=Seven rings)
Press Fwd/Edit (save key) a beep will sound
To return to normal mode press Function/Exit/Ch
I HOPE THIS HELPS! I copied it from my phone manual!
Best of luck!
Emma
Jul 22, 2009 | Panasonic GigaRange KX-TG5432 Cordless...
Panasonic KXT7453
To set date and time on your phone system you must first enter user programming mode.
Using a display phone with the receiver hung up.
Press PROGRAM
Dial ** 1234 (SYS PROG NO)
Dial 000 (DATE AND TIME)
Press SP-PHONE key once (display shows current date)
Normally this is correct if not dial the changes in with your keypad. Use the FWD\DND key to
move forward on the display and the CONF key to move backwards.
Press AUTO DIAL STORE (Confirmation tone)
Press SP-PHONE key once (display shows current time flashing on hour)
Dial new hour (Two digits) Use the FWD\DND key to move forward on the display and the
CONF key to move backwards. Dial in any changes and when your done:
Press HOLD (SYS PROG NO)
Press PROGRAM
Your phone should be back to normal.
Nov 03, 2008 | Panasonic KX-T7453 Corded Phone
NorStar M7310 Phone Logo
101 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
