Question about Sony Playstation 3 (PS3) Console
Reboot the hard disc stays on 0 percent? - Sony Playstation 3 (PS3) Console
  • Sony Master
  • 2,404 Answers
The reason why its not formatting and staying at 0% is because the hard drive is bad and needs to be replaced.
Here is an article that explains how to swap out the hard drive:
http://www.gamepro.com/article/features/127009/how-to-swap-out-and-upgrade-a-ps3-hard-drive/
Its on the right hand side of the page and it has pics as well. Its fairly easy and you'll have a working ps3 again.
Posted on Jun 29, 2009
5 over 16 as a percent?
5/16 as a percentage is,
0.3125*100-
31.25%
Jan 04, 2017 | Homework
What causes the machine to display messages like primary hard disk drive 0 not found. primary hard disk drive 1 not found. strike the f1 key to continue, f2 to run the setup utility?
The system cannot find your hard drive. Remove the Power Cord, Open the Case, then remove the cables that are plugged into the hard drive and plug them back up. Reboot and see if it recognizes the drive.
If not, you can try the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 30, 2012 | Computers & Internet
How to factory reset?
Hello and thank you for using Fixya.
First, You will need to make the recovery discs which are created using the built in program from your computer. Copy them onto a blank CD/DVD. Now insert the newly created restore disc to restore your factory settings by rebooting from the hard drive. Turn off the PC. Wait a minute. Now hold down the 0 (zero) key and push the power button once. A screen message will appear after a few seconds. Choose to reboot from HDD. (or you can choose to reboot with recovery disks using the DVD drive.) Follow the instructions. It will take about two hours to reinstall your operating system.
If you have any more question feel free to ask
-michael34
Mar 08, 2011 | Toshiba Satellite L500 Series Notebook
I was watching a dvd and ejected it with the eject button without quitting, then the screen went black for over 5 mins so i held down power button for 10-15 secs to shut down, turned it back on and it said...
Whenever you have a system that shuts down like that, you can expect to have hard drive problems.
ry accessing the recovery menu 'safe mode'.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
If you have a HDMI cable, plug it up, if you have AV plug it in as well. If you have both settings on your TV, be sure to have them both inserted into the system. Also, make sure that you are switching your TV from HDMI to AV and vice versa.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Try 1-5
If none of this works:
ou will need to replace the HD.
When you replace your hard drive, you will need to have the latest firmware on a
usb stick. Download the firmware from the playstation official website onto a usb
stick. Once prompted by your system you will need to insert the usb stick into the
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
Feb 04, 2011 | Sony Playstation 3 (PS3) Console
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Cannot reboot
Try to set the jumper setting of your hard drive to CS (cable select).
Nov 12, 2008 | Acer TravelMate 290LCi Notebook
Halo 3
heyy dude it might not be you're xbox,although microsoft makes a bad console it just might be you're game disc.if you have another game try it and then if it still doesnt work then its you're xbox.
Oct 23, 2008 | Microsoft Xbox 360 Console
Question about my hard drive
LOL , no my friend , you simply lost your HAL.dll , hardware abstraction layer
you need to reinstall windows , thats the easy way out
or you can take the hard road to china and attempt to recopy your HAL.dll to the proper location on the drive , my personaly I don't even go there , a fresh copy of windows is so much better in these instances because you don't know what else has gone wrong at this point , best to do a reinstall
because there really is nothing like a good ole fresh load of the operating system.
take the puppy back to school like it was at the factory baby :->
shalom
Aug 05, 2008 | Maxtor Hard Drive
Change of Hard Disk
well,you can install any size you want and make sure you reboot from the cd rom when you reinstall the disc toshiba are hard to reboot sometimes unless you have the reboot disc .. lala linda
Jun 03, 2008 | IBM TP A20M PIII700MHZ 64MB 12GB 14.1"24X...
IBM Deskstar Model IC35L040AVVN0-0
Well, I guess your running windows XP ? If you open the disk manager, does it show up there ? When you reboot, does the Bios discover the drive ?
May 29, 2007 | IBM Deskstar 22GXP (DJNA-372200) Hard...
Sony Playstation 3 (PS3) Console Logo
117 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
