Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Magnavox PIP, Insight Cable box, Sony DVD/VHS
How do I go about connecting all of these so that I can record useing VHS, at a seperate time watch a DVD, or just watch cable tv?
  • 137 Answers
Re: Magnavox PIP, Insight Cable box, Sony DVD/VHS
1st conect cable, then 2. VHS , Then 3 dvd to tv.
Then you can record Cable wile watching a DVD
Posted on Jun 29, 2008
0 characters
3 Points
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
WS-65611 PIP worked until cable tech connected new Digital Box
do u want pip form the cable box itself or watch dvd on one side then tv on other
Jan 25, 2008 | Mitsubishi WS-65611 65" Rear Projection...
VCR doesn't work when installed between cable box and TV
a simple way is to get an AV switch .
you may like to try connecting it with different cables
May 07, 2009 | Projection Televisions
I have a magnavox dvd recorder, model # ZV420MW8, that I cannot hook up to my comcast cable box, so altho the drawer will open and its showing that its loading on the dvd itself, there is no picture on the...
Please clarify how you have the dvd connected right now. You should use the video output out of dvd and into the t.v. That dvd don't have rf out. You have to match component or s-video or composite with what your tv has. We can't help because I don't know what inputs your T.V. has. You may have to come out of the cable box with video-outs/audio then into the dvd and then out to the t.v.. Remember, you MUST come OUT with the box and IN to the dvd, then OUT of dvd and IN to the t.v. Always out/in/out/in. You have 3 different formats. Depending on what the t.v. has is the one you will use. Composite is yellow cable...good then s-video used black cable with pins inside....better and Component uses 3 cables red/green/ Don't forget to also hook-up your audio signal too. This should be enough info for you to get it going. Remember too that you will need to set the dvd on your input the cablebox is on to feed the signal through. You can only record what the cable box is tuned to. That should do it. Good-luck.
Dec 05, 2008 | Projection Televisions
I want to convert a DVD to a VCR tape.
Do you want copy dvd movie on VHS tape?
Use DVD/ VHS Combo Player like shown in below picture...
Oct 27, 2008 | Projection Televisions
Have a samsung Samsung LE26A456C and a toshiba dvd recorder. Have set up telly fine, set up video to play fine but cannot record
What is it that you are trying to record? If you are trying to record a DVD you have purchased onto a DVD-R, you will almost always run into a problem because most purchased DVDs have copyright codes burned into them, making them unrecordable. Most VHS tapes have these copyright protection codes in them as wel. If you are trying to record a television show, and are unable to do so, make sure that the DVD that you are using is compatible with your burner. If your burner is set up to record only DVD-R, then you must use only the DVD-R discs. If your burner is set up to record only DVD+R, then you must use only the DVD+R discs. Some burners will record both the DVD-R and DVD+R. If you have the right discs for your burner, make sure that the discs are correctly formatted to be recorded. Also, make sure that if you are recording from a cable box or other input that you have the correct unput channel selected on the burner. If these suggestions don't work, then it could be the brand of DVD that you have purchased (i.e. Sony,Maxell,TDK,Fuji,etc.). Check your manual for acceptable brands. I hope this helps you out. Let me know if I can be of further assistance.
Sep 08, 2008 | Samsung Projection Televisions
I need to get a manual for a magnavox vhs/dvd recorder item #zv450mw8
Hey jleedwards,
If you have lost your owner's manual for this Magnavox VHS/DVD recorder, you should be able to find a copy of it online through the Magnavox/Funai support website:
Hope this helps you out.
Go Ahead. Use Us.
Jun 16, 2008 | Projection Televisions
No sound only get sound when dvd or vhs
Good Day;
No sound on what? DVD & VHS, okay?
Need more information:
1. Where don't you get any sound from?
2. Are you using cable box, sat.,or.....? What?
3. If box what type?
4. ANT, VIDEO, COMP, HDMI or ECT. inputs.
If you are using a cable box there are some boxes that have volume controls on them, please check volume level.
Please clarify what source you are using & check all 'other' cables.
Good Luck, Day, Big Irish.
Jun 16, 2008 | Sony KP-51HW40 51" Rear Projection...
Can't sem to get the PIP to work
In order to use the PIP feature, you Must have 2 different sources to view. Your current connections prohibit this. See if you can get say, a DVD or VCR connection going into the set also and you've got a fix!...accordianman
Feb 18, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Can't get second picture in Picture-in-Picture (PiP)
Watching two separate tv channels at the same time requires two tv channel sources,i.e. a split of some kind. For instance,the cable coming in thru the wall is split-half to tv or vcr/dvd combo and then to tv,the other half to cable box,then out to tv.If what I described fails,then you may have an actual tv failure.PIP video is generally a separate circuit from standard video.An expert tech w/service literature should be able to help. Let me know if you need more assistance.
Sep 16, 2007 | RCA HD52W56 52" Rear Projection HDTV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
211 people viewed this question
Top Philips Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Projection Television Expert? Answer questions, earn points and help others
