Problem with roxio - Office Equipment & Supplies
    Brigadier General:
  • 3,917 Answers
Roxio is error prone in my opinion; my fix was to uninstall Roxio, clean the registry, and re-install Roxio. A PITA for sure, but it worked.
Here's what I did (backup/export you registry first):
1. Uninstalled Roxio from the control panel; it's not called Roxio there, it's "Easy CD DVD.........."
2. Deleted all normally viewable Roxio folders
3. Ran Regcleanr (Tools/Registry Cleaner/Do Them All) and removed all errors
4. Ran RegscrubXP and removed all errors
5. Rebooted
6. Repeated 3. and 4. above
7. Reinstalled Roxio accepting all defaults.
8. Confirmed in Device Manager that my IDE/ATAPI Controller was the standard dual channel and all drives were set to a DMA mode
Took about twenty minutes, but has worked for me on a couple of my computers for various Roxio problems. A third computer did require a complete Windows installation rebuild.
You might also want to check you Application and System event viewer for clues.
If you are using a round data cable to the optical drive(s), try an 18" flat one.....either 40 or 80 conductor.
Try the flat cable with only one optical drive attached as master at the cable end connection.
It's also a good idea to defrag your system hard drive and check it for errors.
try using Nero instead of roxio
encoding tools
dvd shrink and or dvd decrypter
or
CloneDVD 2 with anydvd
guides to use them
http://bbmayo.home.comcast.net/
and burn at 4x max.
Good luck
Thanks for contacting Fixya
Posted on Jun 29, 2009
My roxio game capture installation is not working, it stops at installing roxio game capture and then comes up with Roxio Game Cap Wizard was Interrupted
OK here is my fix.
If you have any Roxio installed i suggest you uninstall all first.
I went to my computer and did a search for roxio.
i deleted every thing that said roxio.
I then went into regedit and did the same search roxio, i then deleted every registry entry that said roxio.
It installed with o problem.
i messed with this for days.
before i found the fix.
Windows 7 ultimate 64 was the operating system on a quad core I7 2.4 ghz
A sager note book.
Jun 30, 2011 | Roxio Easy Media Creator 10 Suite
Recently bought & installed Roxio 2011 on Windows XP and it worked fine. Upgraded laptop to Windows 7. Roxio stopped working. Uninstalled all Roxio programs and reinstalled Roxio Creator 2011. No...
If you are getting the error at startup, roxio service might not started or disabled. What you can try to do is to enable all roxio service. refer to the steps below.
- click start > run - type services.msc - look for all roxio service i.e roxwatch.db - double click it then select the startup type to automatic - save the changes then restart computer
Cheers . . .
Feb 02, 2011 | Roxio Creator 2011
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
Shrill sound problem
If you have Roxio 9, remove it (and other copies of Roxio/Sonic) from the computer.
Remember: Roxio Creator 9 and Roxio Creator 2009 are NOT the same things!! Creator 9 is an old software application that Roxio does not support.
Mar 29, 2009 | Roxio Creator 2009 for PC
I had roxio creator software and had the drive
After working with Roxio, if you find the software you're looking for, Roxio Tech Support will not be able to give you support. Try contacting Inside Sales or a Roxio Technician and see if they can give you a copy of the software again - it will just depend on where you purchased your original version.
Mar 26, 2009 | NEC ND-3540A DVD RW Dual Layer Burner
Can't install Roxio Creator 2009
There is a patch from Roxio to resolve this error!
http://kb.roxio.com/content//kb/Creator/000217CR
Deadog4201
Feb 05, 2009 | Roxio Easy Media Creator 10 Suite
Easy Audio Capture (Roxio Easy Media Creator 10 Suite)
I am a Roxio support agent.
Here is an article on troubleshooting audio:
http://kb.roxio.com/content/kb/MyDVD/000138CR
If you continue to have trouble, please contact support:
selfserve.roxio.com
Regards
David
Roxio support
Sep 20, 2008 | Roxio Easy Media Creator 10 Suite
Roxio creator 10
Roxio has included help files and tutorials that include step-by-step instructions.
a. Double-click on the "Roxio Easy Media Creator Home" icon on your Desktop.
b. Under the "Tools" section, click on "Help Center & Tutorials".
c. The links on the right side of the help frame will launch the appropriate tutorial or
manual.
Also, Roxio has posted flash tutorials on our support website. The website address
for online tutorials click here or go to:
http://www.roxio.com/en/support/emc/tutorials.jhtml
Thanks Roxio
Aug 27, 2008 | Roxio Easy Media Creator 10 Suite
Roxio Toast 7
Hi kspeer, sorry I do not ues Roxio 7 or Roxio Toast 7. In fact Roxio does not seem to support 7 all that much. If you open your roxio's help & type in supported file formats. Thats a good place to start. You can always try roxio here at this link.
http://www.roxio.com/enu/support/default.html
Mike
Mar 29, 2008 | Computers & Internet
44 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
