Question about Smeg FC40RX Bottom Freezer Refrigerator
Smeg FAB46 fridge freezer / need to locate the drip tray
Hi guys - i have a smeg FAB46 fridge freezer and have a cheesey smell wafting from the grill at the bottom/front. I think this will be something to do with the drip tray, but can't locate it. Please advise where it is and how i can get to it to clean it out. the inside f the fridge is not smelly at all. we noticed the smell on our return from holiday and it is stinking out the kitchen and most of downstairs!! thanks for any advice.
  • 1462 Answers
SOURCE: Freezer problems
remove back panel of freezer. check if there is excessive ice build-up preventing air flow. if there is, then defrost carefully with a hairdryer (with appliance switched off) if no ice or frosting on pipework, check if compressor is running. if it is or hot to the touch or clicking, then you have a compressor fault and replacement is not diy. if compressor not running, then probably module fault
Posted on Apr 16, 2007
  • 236 Answers
SOURCE: Leaking Fridge
you may have a faulty defrost timer, best consult a local dom apps store.
Posted on Jun 02, 2007
SOURCE: Fridge not cold enough and build up of ice at back of fridge
We had the same problem and were told that gas was not circulating properly. We had it topped up, but it broke a week later. It had to be scrapped.
Posted on Mar 30, 2008
  • 87 Answers
SOURCE: Smeg Fridge light
What you need to locate is the door switch mechanism for the fridge. These are normally located towards the top of the door and protrude so that when the door closes the switch is pushed in. To find out if you have a problem with the switch just press it when the door is open and the light should go off. The switch itself can appear in various forms either as a protruding rod or a curved plate which pushes upwards against the door side when it closes. If I could draw in this section it could be better explained. But if you look around the inside of the fridge on the side away from the door hinge then you should find something you can push. Sorry to be this vague. If you do need a replacement switch they are normally quite simple to change depending on where they are located, most are two screws, or just a push in type. Hope this has been of some help.
Posted on Jul 13, 2008
nuygas
  • 57 Answers
SOURCE: smeg integrated kitchen fridge and freezer unit - freezer stopped
beneath the freezer usualy installed timer and a fan look for a hidden screw on the sides...check the fan bushing f its lose or has a clearance change it f not check for the timer if its busted...replace.. becareful...electric shock can kill
Posted on Jul 11, 2009
How do I get to the drip tray on a Samsung American fridge freezer? Awful cheesy smell so think it's that...
  1. Consult the owner's manual for the location of the drip tray.
  2. Gently attempt to remove the piece under the doors to see if the drip tray is located there.
  3. Some Samsung refrigerator drip trays are accessible only from the rear.
  4. Reply with the model number for more assistance.
Dec 16, 2015 | Samsung Refrigerators
My Westinghouse fridge freezer, model WSE6100SF, was affected by a power cut lasting 3 days. It now smells, but not inside. Is there a drip tray under the fridge that collects the water?
yes there is but most are not removeable.... remove the cover in the rear of the fridge, the pan is located around the fan motor that's underneath the fridge... I would try pinesol, bleach or odoban to kill the smell..... good luck
Oct 09, 2014 | Westinghouse Refrigerators
How do I remove the plastic drip tray from behind my Wesitnghouse Aurora Fridge Freezer.
we had a really bad smell coming from the back of our westinghouse aurora. and yes found it to be emanating from drip tray at the back. To remove this we had to undo 4 clips at the base of black motor thingy, that the plastic drip box sits on. Then we were able to lift whole thing a bit ,(10mm up and 50mm out, approx) so we could tilt everything forward and sweeze and wiggle tray out. then cleaned with bleach. also we unblocked hole inside fridge that allows water to drip into drip tray at back.
Jun 01, 2011 | Westinghouse Refrigerators
Hi, I have a refurbished RFG297AARS from Samsung that we purcased as a refurb about 7 days ago. On day 1-3, a puddle of water formed under the back right underside of the fridge, without the water line...
Chances are its either the drip line or drip tray.. there is a drain to route the condensation pulled out of the fridge and freezer that leads to a drip pan underneat the unit.
Either the drip tray was not installed.. reinstalled incorrectly or the drain tube is leaking or no longer directed to it, or it's overflowing due to excess condensate.
Best of luck!
Apr 26, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Milk which was spilled in the fridge has dripped into the drip tray behind the fridge and has created the most awful smell. Can the tray be removed for cleaning and if so how?
Yes, usually the tray can be removed for cleaning. You will have to pull the fridge out, unplug power, remove the rear access cover. Then you should see the evaporator / condensate tray and how to remove it.
Jun 22, 2010 | Refrigerators
Smeg Fab40 fan stopped working - there is a build up of ice at bottom right freezer.
There is an upgrade kit for the FAB40 to prevent ice build up which falls under the warranty for the FAB40. I've had it installed and it basically replaces the entire back of the inside of the freezer. Following the upgrade, my FAB40 would ice up completely, plugging the ducts to lead cold air to the fridge below. You can spot this syndrome by the water dripping throught the grate at the top of the fridge compartment. This is melted ice from the freezer ducts. SMEG has now sent their top guy, a drunk and pretty rude guy who replaced the whole backside again, and I'm hoping it will improve.
The bottom line is, SMEG is just ****. Very, very expensive ****. I invested about 10.000 dollars in SMEG equipment three years ago, and every single piece of machinery in my kitchen has broken and needed repair during that time. I deeply regret having bought stuff from them and next time I will definitely go with something different.
Mar 31, 2010 | Smeg FAB40PS Top Freezer Refrigerator
There is a horrid smell coming from the back off my candy fridge freezer its a sicky cheesey smell what is it??
little green men from the planet DRAIN PIPE , awful smelly these people.. have lost the ability to flush out drainpipe with clorine beach (only drainpipe NOT INTERIOR OF UNIT)
Sometimes called streptococus..............
Feb 08, 2010 | Candy CPCA240FFK Bottom Freezer...
I have smoke coming out of the freezer fan grill and water dripping outside on each side of the shell between the freezer and refrigerator. What is the problem?
Your drain may be plugged and water is getting onto the fan's electrical.
Go to back of the unit, remove access panel, check that the little drain tube is dripping water into the evap tray. Tray should be somewhat wet. You can use pipecleaner or coathanger to check for clogs in drain. Or cut the bottom rubber piece off to allow better flow..
Nov 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
We have a Meile fridge freezer and the smell seems to be coming from the back (no smell inside)It has been a constant smell but occasionaly gets worse. It has taken us a week to find out that its coming...
Self de-frosting tray at the back of the fridge was full of old stagnent water. Removed tray cleaned out, flushed out the pipe from the inside of the fridge to the drip tray. No more smell.
Nov 02, 2009 | Refrigerators
Smeg FC40RX Bottom Freezer Refrigerator Logo
94 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
