Question about Belkin - F5D7000 - 54Mbps 802.11g Wireless PCI Card (TGB205168PRN)
Hello sir . I have taken a belkin wireless G PCI card last month.i am using in the institution provided wi-fi net work in the hostel. Card catch the network but detach immediately and also not carry pocket suppose internet provider send 1500 pocket then card only received 90-100 pocket. All my friend using wireless card of other company work properly in my room.so i am frusted behind this for solution of this problem i have changed the card twice. but even i unable to find out what is the problem. please give me solution. i am waiting for better solution. bye i am using window xp .
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 127 Answers
Well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Posted on Jul 16, 2009
What year was toshiba satellite 2410-S203 pc notebook first launched?was it equiped by WIFI?
My sources indicate 2003.
It has > Optional
http://www.csd.toshiba.com/content/pr/html/Satellite%201410%20and%202410%20Press%20Release%20%289-24-02%29.html
The Wireless Antenna On-Off switch is on the Right side. The Wireless Antenna LED is to the left of the On-Off switch. It glows when the wireless antenna is in use.
It has to have an > optional
Turn the laptop over, Front facing you.
The Battery Compartment is on the Front Right corner.
The Wi-Fi Compartment Cover is on the Back Left corner.
Remove the single screw in the right middle of the cover. (Philips head)
See if a Wi-Fi PCI Mini Card is installed.
No?
You'll have to obtain a Wi-Fi PCI Mini Card for your Toshiba.
From a quick search just now, (Not advertising for this website),
http://www.impactcomputers.com/p000339520.html
(Remember to remove ALL power to the laptop Before installing. AC adapter {Charger} and Battery.
Also remember to observe Anti-Static Precautions before handling the Wi-Fi card, and when installing)
Here is the Toshiba Satellite 2410-S203 Notebook PC User Manual, also,
http://www.fixya.com/support/p265858-toshiba_satellite_2410_s203_pc_notebook/manual-14885
Nov 16, 2010 | Toshiba Satellite 2410-S203 Notebook
Internet keeps getting disconnected.Computer needs rto restart
there is nothing to do with adapter... you need to check with some other laptop to isolate where is the issue...
if your laptop works fine without dropping connection then get a replacement for your belkin adapter...
if your laptop also looses connection, then you need to check your wireless router...
Jul 24, 2010 | Belkin (F5D8231-4) Wireless Router...
How do i set up wireless internet on my hp pavillion a330n desktop? Do i need a wireless card or is it built in? and where do i put the wireless card if i need one?
Yes you need a wireless adapter.
Solution one : Get PCI wireless adapter which you will insert in an empty PCI slot inside your computer.
Solution 2. Buy a USB wireless adapter, which you plug in a USB port.
However, if my memory serves me right, that particular HP pavillion is 5 or 6 years old, and it does support USB 2.0, just USB 1.1
My advice to you is to buy a USB 2.0 PCI card to be installed in an empty PCI slot )or in the one occupied by the firewire )if not needed). This card will provide 4 or 5 USB 2.0 adapters. Then buy a USB wireless adapter, which you will be able to use with other computers.
Hope It helps.
Rate this solution if it helps you.
Aug 29, 2009 | HP Pavilion a330n (Refurbished)...
Need driver for win xp pro 64 bit
Dear Sir,
You can trying to visit this web site and download the driver of your wireless card.
http://www.wardrive.net/drivers/belkin
May 01, 2009 | Belkin 802.11g Wireless Desktop Network...
Need Wireless Card on my T40 23734NU
if u ve usb slot and pci slot in ur laptop u can use wireless, there are may brands available in market like belkin , netgear , u can connect install the drivers come along with the wireless card install it and u ll go online wireless
Nov 18, 2008 | IBM ThinkPad T40 2373 Notebook
Wirless network card
well i think obviously the network card is damaged and causing the pc to stop when checking the pci slot that the card is in. Return to the supplier as the card should light up orange or green when operating normally, and under warranty if Os has a 12 month warranty period. Assuming you haven't had a power surge, they should replace the card.
Sep 24, 2007 | Belkin (F5D7000) 802.11g/b Wireless...
Axim X5 and he webanwireless
There are a few ways. It depends how and where you want to get online. One way would be to purchase a CF Wi-Fi card, (about $65, made by D-Link, Lynksys or Netgear). This will allow you to access the net via your home or office wireless nework (assuming you have one). The CF Wi-Fi card will also allow you to access the net at any of the numerous public Wi-Fi "hotspots". Airports, cafes, city parks and hotels are the most common public places that provide such access, and the number of such places is growing. There are websites out there that list where such hotspots are located in various cities and states throughout the country. You can also purchase a CF Wireless Modem card from a wireless internet service provider. You will have to subscribe to the service (about $40 to $70 per month), and purchase the modem (about $200 - $300). Make sure that the coverage area is compatible with where you want to acess the net most. There are national companies, but their coverage are seems to be limited to major cities. The last way that I know of would be to purchase a Dial Up Modem CF Card. (Not sure how much they go for, but between $50 and $120 would be a close guess.) This will allow you to connect it to a phone line and dial up the same Internet Provider that you use for your Desktop PC.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Computers & Internet Logo
108 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
