Question about Hardware & Accessories
Auto settings will not function. Manual works
Auto settings will not function. Manual works fine
Called manufacturer
Posted on Jun 30, 2009
2002 rendezvous low beams don't work. Fuses and bulbs fine. High beams work. Even swapped relays with high beams still no change. Running lights work but low beams don't in auto or manual. What else can...
What about the rest of the lights. The Auto and Manual function should turn the tail lights also. If they work, then it is a headlight wiring problem. If the tail lights are not working either, then it is the auto control module
Nov 14, 2014 | 2002 Buick Rendezvous
How to reset to factory settings , my fuji finepix s2 pro. the auto-focus function is not working. Camera can only be focused in the man mode. can you help?
Please try to download the manual in this website it can help you on how to reset the setting of your FUJI Fine Fix S2 PRO
http://downloads.fotosource.com/public/camera_manuals/Fuji/DigitalCameras/FinePixS2Pro.pdf
Thanks
May 09, 2011 | Fuji FinePix S2 Pro Digital Camera
I had just bouhht a new Fine Pix JX250. But the batteries always run out. It has a short life span. Although i had changed the battery, but it still doesnt work.
First u check the battery consumption for this model as prescribed in the manual provided with the camera. Second try to minimise the functions from auto to manual mode by changing in camera setting menu so as to avoid overuse of battery.
Mar 15, 2011 | FUJIFILM FinePix JX250 Digital Camera
Flash zoom function not working
have you checked that the diffuser is pushed fully home in its slot until you hear a click - this diffuser is for close-up work only and dissables the zoom flash
Feb 02, 2010 | Nikon Speedlight SB-800 TTL Flash
What is the auto and manual switch for on my pentax 6x7 105mm lens for? I just got this camera and shot film on it fine then i got another developed and nothing came out on the film...? Pretty sure the...
In the manual setting, the aperture will always be stopped down to what ever you have it set at. The auto function holds the aperture open until you take a picture. Your metering may have been effected with it stopped down in the manual setting.
Sep 19, 2009 | Pentax SMCP-67 105mm f2.4 Lens
JVC camcorder won't work inside at night anymore.
check the following in camera mode and the auto/manual switch set to manual:
exposure: set to auto shutter: set to auto or off agc: auto white balance: auto program ae: off gain up: auto display/bright: +1-+3
after all that, hit the auto/manual switch again to set the camera into auto mode, the new settings should sort you out.
Jul 28, 2009 | JVC GR-D290 Mini DV Digital Camcorder
Automatic zoom
auto zoom will only work while the build-in wide-flash adapter is slided inside.
Apr 05, 2008 | Nikon Speedlight SB-600 TTL Flash
Hardware & Accessories Logo
56 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
