Question about Briggs & Stratton Garden
WHERE DO I FINE THE MODEL# ON THE SNAPPER FRAME REAR ENGINE RIDER? IT HAS THE SMOOTH CLUTCH BUT WHEN ENGAGED WILL NOT MOVE. THE DRIVE DISC IS NEW.
  • 376 Answers
Should be under the seat on the front of the battery box or on the center tube in the same area.
Posted on Jun 29, 2009
Drive Disc on bottom of engine intermittently freezes and engine stalls out and remains frozen for some time 17.5 HP B&S on Snapper 3317523BVE 7800254 - Snapper 33 Rear-Engine Rider
check for grass and other material that is wrapped around the shaft above the disc and acting like a brake
when it is clear check for failing bearings on the disc shaft
May 14, 2016 | Snapper Garden
Replace friction wheel Snapper 3317523BVE (7800254) - Snapper 33" Rear-Engine Rider
Warren, Could not find your particular model, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HowTo Replace Your Disc Drive Friction Disc Wheel
Riding Lawnmower doesn go foward Drive Disc Replacement
snapper clutch repair for beginers friction disc
Snapper Friction Drive Modification
May 13, 2016 | Snapper Garden
Only after i got stuck in mud did blades on snapper lt 200 42 rider so working belts are tight must be sensor insert seat went out or went bad
Blades would not turn after I got stuck in mud. Electric clutch?
  • Turn the engine off and remove the key.
  • Check for physical damage; anything look bent?
  • Spin the pulley on the bottom of the clutch. Does it spin freely?
  • There could be mud or grit stuck in the clutch.
  • There is a drive key between the clutch and the shaft. Has this key been sheared? It's possible the clutch was burnt out during the mud incidence.
PTO Clutch will not engage or stay engaged.
There is a very fine discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
  • Resistance 3.7 ohms
  • Current Draw 3.25 amps.
  • It does not give the air gap.
It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
  • Cap Screw torque 55 lb-ft (75 N.m).
Fixing Electric Clutches
Apr 10, 2015 | Snapper Garden
Why will my Snapper riding mower NOT go into gear? forward or reverse?
what kind of snapper... RER ( rear engine rider ) tractor style, model number will help greatly here because snapper has made mowers since the dawn of time !!!
Aug 23, 2014 | Snapper Garden
I need a drawing of the gear arrangment of a snapper lawn mower model number 3011x6s
Displaying Smooth Clutch Assembly parts for the Snapper 3011X6S 30" 11HP Extra Tough Rear Engine Rider Series 6:
Sep 20, 2009 | Garden
Need to know how to adjust the rubber drive wheel on a rear engine snapper. Any help will be great. Thank you
Usually just replacing the drive wheel will fix the problem. There are two allen head set screws on the disc mounted on the engine shaft visable through the hole in the rear of the mower. However, don't expect when you loosen them that the disc will move up or down freely. I've only ever move one by taking the engine off. I'd try replacing the rubber drive wheel first.
Jun 14, 2009 | Omega Rear Drive Wheel Snapper Mowers
Garden Logo
145 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
