Question about Canon PIXMA MP830 All-In-One InkJet Printer
Power went off and unit will not turn back on. How do I get it to power up again
    President:
  • 2,306 Answers
You may have to remove the printhead to power up again, if thats the case then you need a new printhead..#qy6-0061-000 around $45.00. Otherwise the power supply or main PCB is bad.
Posted on Jun 29, 2009
  • Deana Martinson May 27, 2011
    How do you change the printhead when the power won't come on and the print heads aren't in the middle but off to the side?
  • Craig Gillette
    Craig Gillette May 27, 2011
    It's impossible to remove without removing covers. In the shop, I remove the right side cover and unplug the ribbon cables that go to the printhead and then power up. The cables are the ribbon type, about 1 1/2 inches wide that go from the board up over the top to the carriage. When the carriage is locked on the side, it will break if you force it to come out.
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
PANASONIC CS-CU E24PKR fault code H00
H00 No abnormality detected - Normal operation
You may have a problem with the outdoor controller, the indoor controller or both. Power outages can do some strange things to the electronics. Turn the A/C isolator off for five minutes and back on again to be sure the problem is still there. You could also try this:
• To clear memorized error (Protective operation) status
after repair:
1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
Jan 31, 2015 | Panasonic Heating & Cooling
Tv went off wont turn back on
Make sure you've unplugged all external connections to unit. Try unplugging TV from power source for no less than 10 minutes. Plug in again, and see if it comes on by depressing the unit's ON/OFF switch (NOT via remote). If not, then try something in receptacle that you're plugging into. If no power, then check your circuit breaker. If still no power, then may require service.
Jan 14, 2013 | Televison & Video
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Power goes off
Try resetting the unit.
Make sure there is no disc in the unit. With the unit on, go to the front panel and look for the STOP (square) button.
Hold it down until the unit shuts off by itself. Turn it back on it shoudl work fine.
Jul 01, 2009 | Samsung HT-X40 System
Turned unit on, and then went off, now will not
Had the same problem with my one, got a repair guy to replace the intergrated circuit (IC) at the standby circuitry but that did nothing, in my case one of the transistors that controls the relay was short circuiting the power supply to this circuit, yes i know it does not come up with check speaker wires but is part of a relay control, just get a repair guy to replace the relay control transistors and/or the zenor diodes in parrallel with the relay coil, if this does not fix it make sure he searches for dry joints and use a freeze spray to see if any component is affected by temprature, hope this helps, also to fix it intermediatly, this could work is unplug the unit, then while holding the power button throught the powerup stage, plug it back in, it will then switch off again, release your finger off the power button then try and power up it again, this resets the power supply and should work normally again fora while anyway. cheers
Toby
Apr 25, 2009 | Yamaha RX-V459 Receiver
Samsung dvd/disc protection
Try a hard reset: unplug from power source, remove all cabling and wait for 5 minutes before recabling.
If that fails, it is a logic board error, in which case you are probably better off buying a new device..
May 24, 2008 | Samsung HT-DS610 System
Sony VPL-CX4 projector locked up
keypad buttons probably need a good service.
you say you pushed power key twice
did you leave a small pause between each push
get a tech to checkout underneath keypad buttons to make sure that the contacts are clean.
Dec 12, 2007 | Office Equipment & Supplies
Constant clicking every half-second as soon as you plug it in.
I have the same problem-still troubleshooting...so far still not find the cause. DM1 power supply output voltages are operates correctly. Signal output of microprocessor up and down (no good) that turn on Q14105 and latch optical isolator U14102 to power the unit but both of ohmed out ok. it hard to troubleshoot the main board with power on.
Aug 29, 2007 | RCA F38310 38" TV
Canon PIXMA MP830 All-In-One InkJet Printer Logo
139 people viewed this question
old marine
old marine
