SOURCE: Digital TV not working
i had same probs tv 4 monts old new tuner fitted
and yet one more new tuner fitted when 8 months old
it now turns pick off at randod but sound stays on have to unplug mains for temp fix
now warranty has run out philips are not interested
SOURCE: my philips lcd digital tv says I am recieveing
First verify that the direct TV satellite box is set to receive and display digital stations. If you old set on the sat was analog, the box may not have been reset. You may have to contact you satellite provider. Next you will have to go to the TV menu and auto program/scan in the stations. This should pick up all the stations.
SOURCE: 47'' philips flat screen does not install channels
Go directly to theback of the set via the back RCA connectors(yellow, red, white) or component video, and turn set on Aux. If it works the tuner is Messed!
SOURCE: digital channels have stopped working, only blue screen!
Try resetting the TV:
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
SOURCE: Channel Scan on my Philips 26" TV only finds the local channels.
Hi.
you should go into your tv's setup menu and go to the tuner settings and make sure it is set to CATV (cable tv) and not Antenna/Air also splitting a cable to many times can cause the signal to weaken and gain a lot of noise/distortion that could be an issue that can only be solved by having the company come to the house and do a test ALSO when your in the tuner menu in under your tv's setup menu try adding a non local channel manualy and then see if the tv will tune to it, if so then you might have to add them manually at the worst... my guess is that it is not set to CATV/cable tv hope this helps and if not i hope someone else can.
