Question about Insignia IS 20" TV040919 TV
Remote control code needed for this TV
Im trying to program my COX cable remote to control the TV, however I cant find the correct code. I did do a search and found something close meaning a couple of buttons on the remote will work on the TV but not correctly, EG, the on/off button puts the volume up the volume down turn the tv off. and the power button selects only channel 4, NEED HELP PLEASE
  • 2 more comments
  • Anonymous Dec 25, 2007
    We are using a Brookstone Universal Remote and need the code for programming a universal remote. All of the other VCR, DVD and Satelite Dish work with the remote. The model number for the TV is
    Insignia IS-TV040919 20" TV:
  • Anonymous Feb 18, 2008
    NEED THE TV CODE TO PRGRAM THE CABLE REMOTE TO TURN THE TV ON
  • manuels52 Mar 09, 2008
    Hi. I need a code to program my comcast remote to my insignia 20in tv
  • misty297 May 05, 2008
    I need a code to program in my direct tv remote control to turn my insignia tv on and off
  • 4 Answers
The Insignia is-tv040919 is a Cytron and the code is 11326. But no Comcast multifunction remote contains that code -- so you cannot enter it manually and the 991 search function will not find it. I discovered the make and code because last year I installed the Insignia tv on a Comcast DTA with the small, black two function remote. That remote programmed quickly. When I moved that tv to the room with the cable box and multifunction remote, mayhem ensued. I got an $8 RCA 3 function remote today and it's working great on the Comcast cable box, a DVD player and, drum roll please, our old friend the is-tv040919.
Posted on Apr 07, 2011
0463 worked for me
Posted on Dec 06, 2008
Need to program my Insignia TV to my Direct TV remote. Need code
Posted on Feb 17, 2008
Have jvc tv, lost remote, have cox remote turns tv on but doesn't change channels don't have cable just tv antenna
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Sep 25, 2016 | Charter Cable Cox Cable URC-8820-CISCO...
Unable to find IR Code for power on/off using cox cable remote
1. Turn on a device and, if applicable, insert video
media, (e.g., cassette or disc).
NOTE: Please read steps 2-4 completely before proceeding.
Highlight or write down the codes and device
you wish to program before moving on to step 2.
2. On the remote control, press a device key once
(e.g., AUX, VCR, TV, or CABLE). Press and hold
SETUP until the selected mode key blinks
twice, then release SETUP.
3. Use the Manufacturer’s Codes (starting on
page 11) to locate the the type of device and
brand name and then enter the first four-digit
code for your device. If performed correctly, the
selected mode key will blink twice.
NOTE: If the selected mode key emits a long blink, the
code is invalid. Repeat steps 2 through 3 and try
entering the same code again.
4. Aim the remote control at the device and press
POWER once. The device should turn off. If it
does not, repeat steps 2-3, trying each code for
your brand until you find one that works. If it
still does not work, try searching for the code
(see Searching For Your Code on page 20).
NOTE: If the device does not have a POWER key, press
the (Play) key.
5. Repeat steps 1 through 4 for each device you
want the the remote control to control.
The potential codes for your Sylvania TV are:
0054
0030
0381
Here is the manual. The codes are on page 11 if you need more.
http://www.cox.com/Fredericksburg/digitalcable/Cox_d4.pdf
Hope this helps :)
Dec 22, 2007 | Televison & Video
Cox Universal Remote Won't Work for Zenith VCR
Try the Cox website's pdf. for this universale remote. I hope this is it and good luck to you. Sincerely, CBR2009 http://www.cox.com/support/cable/pdf/universalremote04.pdf
Jul 11, 2009 | Zenith DBZN-311 Remote Control
Programming Cox Cable Box Remote to Vizio TV
using a cox cable remote. cant program to work cable and tv functions at the same time. please help?
Jun 02, 2009 | Vizio VX37L Television
Need a code for universal cox cable remote to turn on and off Kenwood KR-V-8040 Receiver
[PDF] Cox Manual File Format: PDF/Adobe Acrobat - View as HTML
not respond to the Cox Universal Remote Control after trying all of the codes listed for your brand,or if your brand is not listed at all,try searching for ...
www.cox.com/support/digitalcable/hdtv/pdf/Universal_Remote.pdf - Similar pages
  1. More results from www.cox.com »
  2. Universal Remote Control Codes Apr 17, 2009 ... More Cox Remotes, Includes Cox Digital Interactive, Universal DVR, Navigator, Millennium and Model ER1 PDF manuals. Cox Universal Remote ...
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages
  3. How to Program a Cox Universal Remote for Your TV | eHow.com How to Program a Cox Universal Remote for Your TV. Have you ever dreaded programming your universal cable remote for your TV? Many people put off this very ...
    www.ehow.com/how_2153479_program-cox-universal-remote-tv.html - 52k - Cached - Similar pages
Jun 01, 2009 | Kenwood Audio Players & Recorders
Setting up for cox cable
Try this:
Searching the Code Library
(Program Code 9 9 1)
1. Turn on the device.
2. Press and hold SELECT and the appropriate mode key (CBL, TV, VCR, or AUX)
until the mode keys blink twice. For example, to search for a TV code, press and
hold SELECT and TV at the same time.
Note: If you reassigned mode keys, you may, for example, press SELECT and
VCR to search for a TV code to assign to the VCR mode key.
3. Press 9 9 1. The mode key you selected in step 2 blinks twice.
4. Point the remote toward the device, and press . The remote automatically tests
each code in its library, beginning with the most common codes. The mode key
blinks once each time the remote transmits a new code. The mode key blinks twice
when it reaches the last code.
5. As soon as the device powers off, press SELECT.
6. Verify the new code is correct by pressing POWER.
7. Did the device power on again?
• If yes, press SELECT to assign the code.
• If no, complete the following steps:
a) Turn the device on.
b) Press or to step forward or back to the correct code.
c) When the device turns off, press SELECT to assign the code.
8. Go to Which Code Worked to identify the code that controls your device. After you
identify the code, record the code in the space provided on the cover of this guide.
Jul 27, 2008 | Maxent MX-26X3 Television
Remote Control Programming
GE Universal remote only $12.00 at Target works on my Akai LCD HDTV, this remote also has learning capability but the third code under Akai worked!!!
Jan 24, 2008 | Televison & Video
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Remote control codes
You need remote rc64 to control the Olevia 32 inch LCD. You can call Directv and order the remote. Use code 11610.
Oct 15, 2007 | Olevia LT32HVM 32 in. LCD Television
Insignia IS 20" TV040919 TV Logo
563 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
