Question about Daewoo Televison & Video
My daewoo tv won't turn on I'm not sure of model no.
Automatic channel scan on daewoo tv
What is the exact model number to your Daewoo TV?
Apr 23, 2012 | Daewoo Televison & Video
Cant find code sheet need code for a deawoo tv for remote sru3006wm/17
Code Search Results--> --> Code For Model RCU300T
Code 004 for Daewoo TV Code 005 for Daewoo TV Code 006 for Daewoo TV Code 016 for Daewoo TV Code 017 for Daewoo TV Code 082 for Daewoo TV Code 171 for Daewoo TV Code 190 for Daewoo TV This is a basic set of codes for the TV, I am not sure of the model on the remote so I can only give you what I have. If these won't work, add a 1 in front of these 3 digit codes to make a 4 digit code, this should work. Good luck
Nov 15, 2010 | Universal Remote Control 6-Device...
PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
May 09, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Code for a tv remote
if u have a universal remote and none of the codes seem to work after trying all the codes and non still don t work follow these steps
1. make sure the power on the TV is turned on
2 press and hold code button until it flash twice
3 then press the TV mode button until the light flashes the press
4 power button until TV powers off
Feb 13, 2009 | Daewoo DTQ-20U4SC 20" TV
Daewoo TV model DTQ-27U4SC turns on by itself
A physical button on the tv is probably stuck / failed. In the past ive salvaged tvs by opening them up and disconnecting the switch boards and used a remote.
exercise the buttons gently and take note of any that crunch or make funny feelings noises as they push. It might start working after a gentle workout.
Feb 13, 2018 | Daewoo DTQ-29S1FCN 27" TV
CHILD LOCK Help needed
Hello i recently had a problem that my tv just locked itself which i think is the same type of problem, i contacted Daewoo and they gave me the following code to try and it worked, not sure if it will do the same for your set, but it might be worth a try.
press the following buttons in the remote in sequence
BLUE
YELLOW
GREEN
RED
STANDBY TO TURN OFF
STANDBY TO TURN BACK ON.
Hope this might help, if not try contacting Daewoo Electronics website and put in your model number.
Regards
H wilson
Apr 12, 2008 | Daewoo GB-20H4T2 20 in. TV/VCR Combo
Daewoo Universal Codes for Comcast Remote
For Daewoo TV Model DTQ-27U4SC, try this for Comcast Universal Remote (one with the red select button):
1. Press TV button
2. Press Setup button until TV button blinks twice
3. Enter 10451
4. Press Power button (TV should turn off and is set)
Mar 01, 2008 | Daewoo DTQ-1440FC 13" TV
Televison & Video Logo
465 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
