Question about Hitachi 42PD9700 42 in. Plasma Television
HITACHI PD429700U HI I HAVE A HITACHI TV AND IT HAS A FAULTY YSUS BOARD.WHEN I CONNECT IT IT COMES ON AND THEN CUTS OUT WHEN I REMOVE IT IT POWERS UP BUT NO DISPLAY.CAN YOU PLEASE TELL ME WHATS GONE ON IT AND ALSO WHEN IT DID POWER UP I WAS GETTING BLUE COLOUR ON PEOPLES FACES.AND WHEN I WAS CHANGING CHANNELS DISPLAY WAS ALL RED. PLEASE HELP
SOURCE: plasma P50H401 tv will not display picture
I know this might sound stupid but try changing the channel or changing the aux / cable / tv button... I  had to put my phillips 50" in the shop for the same problem ..but I had it for 3 yrs .they said it was the power supply and will cost 1k to get the power back and may cost evne more if one of the boards went out (video i guess?) so make sure u get the extended warentee u will need it .Its only a matter of time ... good luck quickdrj
Posted on Oct 12, 2007
Drummernick
  • 440 Answers
SOURCE: Hitachi 50" plasma no picture
well they give usaly 1 yr parts labor i would get it in asap to be fixed bad power thx nick
Posted on Feb 07, 2008
SOURCE: Hitachi HD 1080 has blue power light on but no picture
Press the reset button...it's on the bottom to the right (underneath the TV). Same thing happened to me.
Posted on Feb 24, 2008
VOTIT
  • 2071 Answers
SOURCE: Hitachi 42hds69 blinks 8 times and powers off and powers on, cycle repeats
SERVICE MENU SETTINGS
All system, geometry and white balance alignments are performed in production service mode. Before
starting the production mode alignments, make sure that all manual adjustments are done correctly. To
start production mode alignments enter the MENU by pressing “M” button and then press the digits 4, 7,
2 and 5 respectively. The following menu appears on the screen
There are 3 submenu in service menu. These are display, calibration and deinterlacer menus. Press
“◄/►” buttons to select a menu title and then “▲/▼” buttons to select a menu item and “◄/►” or “OK
buttons to set the menu item to the desired option. To exit the service menu press “M” button.
Entire service menu parameters of Plasma TV are listed below.
13.1. display menu
By pressing “◄/►” buttons select the first icon. display menu appears on the screen
blank color
By pressing /. button, select blank color. Press ./. button to set the blank color. The options are:
black, red, green and blue.
panel
Displays panel resolution
power on time
Displays total working time of the set
backlight on time
Displays total backlight on time of the set.
calibration menu
By pressing “◄/►” buttons select the second icon. calibration menu appears on the screen.
color temp
By pressing /. button, select color temp. Press ./. button to set the color temperature. The
options are: 5500K, 6500K, 7500K, 9300K and user.
user color temp
factory reset
By pressing /. button, select factory reset. Press “OK” button to return to the factory setting values.
Posted on Jul 31, 2008
Fujitsu
  • 29 Answers
SOURCE: hitachi power light blinking
You have problems with the SDR Printed Circuit Boards
You need change them
Posted on Nov 28, 2008
My LGPA4500-UF plasma tv has no picture only a clicking sound. I changed out the ZSUS Board same problem.Could it be YSUS or Power source unit?
hi i'd check the buffer boards that connect to the ysus board for white dots if there are some, the buffers need replacing and i'd replace the ysus as well thanks
shaun
Feb 15, 2017 | Televison & Video
Samsung PN43D450 Clicking noise
it sounds like its tripping on the power board
one of your boards is faulty
Jun 03, 2014 | Samsung Televison & Video
I have my tv hitachi model no 55HDS69 i have sound no pictures heplp me thank
There are two boards that could get failed and cause of this problem, these are XSUS and YSUS boards, please replace them to solve tv problem.
Require board is available with shopjimmy.com
Thanks.
Mar 01, 2011 | Hitachi Televison & Video
Hi, the lower half of our Viera screen is unviewab...
Yes the problem is the following.
Either the ysus board is defective or the y buffers are faulty.
more likely the ysus board.
May 20, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Screen problem with my LG 50" Plasma TV
its the buffer driver board the big long board that plugs into your tv,, i have one for sale if u need one,,30£..promo7uk2@hotmail.com
free+p+p
this will cause the lines on your tv after replacing the ysus it could well be that ysus mabe faulty still if u replace buffer and find u still have the lines 9/10 times when the ysus goes it normally takes out the buffer board on these worst cases the control board,, but im 98% shure its buffer board.. let me know on here if u find out.
Apr 21, 2010 | LG 42PX5D 42 in. Plasma HDTV
LG Tv 50PQ30 the lower half of the screen intermittely stops working
looking into the back of the tv with the cover removed, there is 2 boards on the far left the run down the back of the screen. These are the Ysus buffer boards.They both plug into a larger board (Ysus). Make sure that the bottom buffer board is pushed into the Ysus properly and that the wired lead connecting the upper buffer board to the lower buffer board is pushed in firmly.If this doesnt solve the problem then you will most probably have a faulty lower buffer board.
Feb 20, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
TV turns itself off then back on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Capacitors are very inexpensive but require some soldering skills to repair.
Hope this helps
Dec 15, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Haier 42EP24S
Replace vodio board check power supply board ok
Aug 23, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Hitachi plasma tv 42pd380ta problem
Hi, the ysus board on the left side looking from the rear of the plasma has blownup, this is a very common problem with 42PD380TA, if the unit is under warranty you are lucky otherwise hitachi charge alot of mooney for service kit.
I have seen 7 hitachi plasmas in 3 months all with the same fault.
HITACHI dont accept there is a production Fault
Dec 23, 2007 | Hitachi 42PD380TA 42 in. EDTV-Ready Plasma...
Hitachi 42PD9700 42 in. Plasma Television Logo
65 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
