Question about Thetford Norcold RV Cooler/Freezer
Do rv refrigerators take freon? - Thetford Norcold RV Cooler/Freezer
    Top Expert:
  • Thetford Master
  • 9,362 Answers
Cannot add need new cooling unit
Posted on Dec 16, 2017
My Norcold fridge isn't getting as cold as it should. Do I add freon?
No you don't just add freon and expect everything to be fine .if your system is low on freon then you have a leak so that needs to be fixed first .try cleaning you condenser coil and make sure both evaporator and condenser fan is running
Feb 08, 2018 | Refrigerators
Can we recharge freon
These type of refrigerators can not be simply recharged as there is ammonia inside and not freon.
The cooling units can be replaced tho. Most systems can be changed out in a matter of just an hour or two. Our Replacement units come standard with install instructions and a lifetime warranty. Check out our online Store
Toll Free ph 1-888-782-6665
check out our video on how to change a cooling unit
ArctiCold Refrigeration We keep it cold
Aug 17, 2014 | Dometic 2932641034 Refrigerator Part Front...
Freon capacity for 1998 ****** 37 ft ticonderoga rv
There should be a decal under the hood showing type of refrigerant and capacity for the system.
Jun 12, 2014 | RVs
Dometic refrig not cooling but found yellow oil at service panel
if you find an oily substance its most likely freon. this looks pretty new so i would say you have a bad soldered joint on a copper to steel line. theses usually ar fot the high side. where the condensor coil or loop runs either to underref or up in the ref walls
Aug 01, 2010 | Dometic RM2652 Refrigerator
How long does the Briskair Duo Thermal ac run before it runs out of freon? I have medical issues and can't breathe over 70 degrees. I can't go out side. Does anyone know where to take the rv for freon? Can...
I would think your RV repairman could add refrigerant. Any heat and air company could do this for you. The unit does not have service valves in it and a port will need to be added. I have seen these units 30 years old and still holding the original charge. It is impossible to say how long it will last. If you need to add refrigerant more than once a year you have a serious leak that needs repaired.
Jun 29, 2010 | Dometic Rooftop RV Air Conditioner
Duo therm air
unfortunatly with the new laws u are unable to unless u are a licenced refrigeration/ac technician
Sep 16, 2009 | Dometic Rooftop RV Air Conditioner
Air unit freezig up after 8hours or so of use on rv fithwheel camper
Sounds like you need to recharge system with freon. Hope this helps :>)
Jul 13, 2009 | Dometic Rooftop RV Air Conditioner
Dometic duo therm does not cool or heat...
it should never have to be recharged unless there is a leak. so you should isolate the leak with dye injectable into the system w/ the freon and correct it, then fully recharge system.
Jun 09, 2009 | Dometic Rooftop RV Air Conditioner
Thetford Norcold RV Cooler/Freezer Logo
103 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
tom wright
tom wright
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
