Question about Universal Kreepy Krauly In-Ground Pool Cleaner
Kreepy Krawley is not working I disconnect the hose & I can see it move the fins but then when I reconnect it does not move. There is enough pressure as the filter was just cleaned
  • 83 Answers
There are a few things for you to check to find out what is causing this issue.
1. Hook the unit up as normal. Then try shaking the hose back and forth. Does the cleaner start working, even if it is only for a moment or two? If so, you need to replace the Swivel Cone and Bearing Washer. The top two pieces on the cleaner, where the hose attaches to the unit.
2. Check for debris in the Flapper area. You can remove the Flapper (wedge shaped piece inside the cleaner) by removing the Baffle Plate and pulling out the Flapper. Check the Flapper for breaks, chips, and inside the cleaner for any kind of debris. I have seen hair ties, dimes, pool tiles and other things inside the cleaner that you could not see by looking down the tubes or just flipping the Flapper back and forth.
3. Check the Footpad for wear. The Footpad is the very bottom part on the cleaner and is dragged across the pool floor. The pad should have raised sections which are textured, like a soft sand paper. If the pad is smooth, then it needs to be replaced because this piece is what gives the cleaner suction on the pool floor.
4. Check for leaks in the hose, the Regulator Valve in the Skimmer.
Posted on Jul 09, 2009
    Problem Solver:
  • 10 Answers
Sometime they just give out. Just like cleaning pool tiles, it should be done every so often.
Posted on Jun 16, 2011
My Kreepy Krawley Bull Shark won't sit flat on pool floor
Try adjusting the hose weights 1m and 2m seems to work for most
Jan 18, 2017 | Pool & Spa
Hose broken where it fit into the kreepy krawley
Go to an autoparts store and ask about EASYOUTS. They are reverse tapered tools that fit in the opening and grab the piece and screw it out.
Oct 14, 2012 | Universal Kreepy Krauly In-Ground Pool...
My kreeper craler wont stay on the bottom of the poll its tippietoes across the bottom of the pool
it's usually caused by not enough weights on the suction hose, or the vertical stabilizer float has gone past the stop tabs and it sitting way too high on the unit. the hinged double stabilizer should be secured near the bottom of the unit and should only move side to side, it should not travel up the kreepy at all.
Jul 30, 2011 | Universal Kreepy Krauly In-Ground Pool...
Hi, I also bought my Bull Shark Kreepy Krauly recently - 3 months ago. Since day 1 it liftes up at the end and does not move flat on the surface of the swimming pool. Please assist.
First, check for debris in the pool cleaners flapper. This can cause a lack of suction the floor. Also, check for proper hose balance. If the hose rests at a greater than 45 degree angle, the hose is too light and you need to move the hose weights closer to the cleaner. If the hose rests at a less than 45 degree angle, you need to move the weights away from the cleaner.
Feb 11, 2011 | Universal Kreepy Krauly In-Ground Pool...
My Kreepy Krauly won't move. I've checked the hose for holes and also replaced the vinyl suction cup on the bottom but it won't budge. Doesn't appear that there is much suction. Could it be something...
Yes, it could. Check the filter and pump for debris. This could severely restrict movement in these pool cleaners. Also, check the flaps of the Kreepy Krauly for debris. Also, check to make sure that the main drain and ALL suction lines, except the one the cleaner is attached to, are closed. This might also be why you have a lack of suction. My final suggestions would be to check the return line water flow and make sure that it is strong enough.
Dec 30, 2010 | Universal Kreepy Krauly In-Ground Pool...
My Kreepy Krauly doesnt want to ****
With these pool cleaners, your problem if going to be an air leak. You need to find and correct the air leak that is causing the pump to lose its prime. Check the hose to ensure that there are no leaks. Check your vacuum connection. It should be submerged so no air enters the system. Check your pump basket lid for looseness, cracks, and worn or missing o-rings.
Aug 01, 2010 | Universal Kreepy Krauly In-Ground Pool...
My Kreepy Krauly works for 10-15 minutes and then stops hammering and sits on the pool floor. I have replaced and checked parts and the pump runs well.
you may have a hose that allows air to get sucked in at times when the unit moves and the hose with crack is able to float to the surface and make contact with outside air. move hoses around and see if that helps you can also start from the closest connection at the suction port and lift the hose out of the water one section at a time hold it out of water for a moment and see if you notice any weird feeling or hear a slurping do this section by section until you get to the last hose section at kreepy head
May 14, 2010 | Pentair Kreepy Krauly Inground Automatic...
My kreepy krauly is moving at half speed and sometimes stops moving all together. All tubing is good, filter has just been cleaned, any ideas?
Check your pump pressure on the suction side. If there is any air gap in your pump strainer pot (if you have a see thru see thru strainer cover) then you have a leak on the suction side. Auto matic cleaners need ample pressure for them to move. or you might need to backwask the filter check your pressure gauge. If none of these help its more then likely the gears in the cleaner. also check your cleaners hoses
Aug 16, 2009 | Universal Kreepy Krauly In-Ground Pool...
Universal Kreepy Krauly  In-Ground Pool Cleaner Logo
719 people viewed this question
Top Universal Pool & Spa Experts
Andrew Taylor
Andrew Taylor
Are you an Universal Pool and Spa Expert? Answer questions, earn points and help others
