Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher Paykel Dishdrawer - White residue buildup inside
Can you recommend what to use to clean inside of dishdrawer? Our dishes weren't being cleaned so we looked and there is a lot of white calcium looking buildup on the arm and spinner in the bottom of the drawer. In fact all throughout. Thank you.
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Www.dishwasherfilter.com makes a filter that will filter the hard water before it enters your dishwasher. your dishes will be sparkling after the first load. it is very affordable and guaranteed to work. you will love it.
Posted on Aug 04, 2009
Dishes dont seem to be coming clean. they have a film on them. i tried jet dry and still not coming clean
Posted on Jun 29, 2009
Fisher and Paykel twin dishdrawer
there is water in the base setting off the flood sensor, you will need to remove the bottom draw and dry the water up with a towel (make sure the power is off and unplug it from the power point) then you will need to do a bit of testing to locate the cause of the leak, if your lucky the leak was caused by incorrect dish stacking or something too big in the draw
Jan 02, 2017 | Fisher and Paykel Dishwashers
F 2 on fisher paykel
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/590199D%20DishDrawerP7%20userguide%20USCANZAUGBIE.pdf
More then likely you will have to remove both drive impellers and give them a good clean as well as the stainless strainers . Every month or so I run a rinse cycle through them with a cup of white vinegar . this also helps with the damp smell in the warmer weather.
Good luck
May 04, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
Dishdrawer f2 error
This is linked to a rotor problem. Check this video and clean the cavity. If no difference then need to replace the rotor.
http://www.appliancerepairlesson.com/2011/02/25/fisher-and-paykel-dishwasher-dish-drawer-repair/
Feb 16, 2014 | Fisher and Paykel 23 in. DD-603 Built-in...
After a cycle the dispenser is filled with water. The dishes are clean, the detergent is gone, but there is water filled in the dispenser. Thanks!
There is a small drain hole in the bottom of the dispenser. Most likely it is blocked. Try a toothpick or similar to unblock it.
Feb 11, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
Fisher paykel dishdrawer
It is likely the top panel of the drawer needs cleaning.
First turn off the mains power to dishwasher and take the plug out if accessible. Wait a little and put the plug back and turn on the mains power. If this does not fix the problem, then get clean damp cloth and wipe the panel buttons on top inside of drawer.
May 17, 2013 | Fisher and Paykel 24 in. DS603H SS...
Greetings. I have a Fisher & Paykel dishdrawer - the top drawer appears to have lost power mid cycle and the lid has not retracted - no led display - no response from the buttons. The bottom drawer...
Describethe inside of unit,any wear on it anywhere, the rack the dishes go on is it plastic coated? is it wore with rust comeing though on tips here and there?
Mar 07, 2011 | Fisher and Paykel DishDrawer DS605FDSM...
Possible pump blocked
dishes have white film glasses are foggy
Jan 31, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer Fisher & Paykel Dishdrawer no lights lcd
Your original problem, F4, was the machine trying to tell you that the heater plate was not working. When you turned the drawer up-side down, you may have damaged the wiring harness. If you do get a technician, call a fisher paykel authorized servicer, not an independent, and make sure you tell him about the F4 problem. A new problem has been introduced by the cleaning procedure, and both issues will need to be resolved.
Dec 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
1,245 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
