Question about Samsung SGH-X680 Cellular Phone
Samsung reset button
    Sniper:
  • 56 Answers
There's no reset button for cellular phones
try this code, be advised that all information on your phone will be lost or deleted
*2767*3855#
Posted on Jun 30, 2009
  • 22 Answers
Well technicaly there is a reset button it is call master clear or master reset to access this function go to security and it should be there
BestWishes                  -SunShine-
Posted on Jul 04, 2009
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
Nov 22, 2017 | Tablets & eReaders
How to reset my pass word on my Samsung Security Video System SDH-B74041
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
These reset procedures cover many Samsung Security DVRs, but not all. I will add reset procedures to this article as they become available to me. By design, Security DVRs are made to be secure, and not all of them can be reset by the consumer. If you have an urgent need related to your Samsung Security DVR, you should contact Samsung directly at their support page Samsung Support, or by calling: 877-349-3149. For less urgent matters, you can email them directly at Email Samsung Support. Support is available 7 days a week, 9:00 am - 9:00 pm EST.
Jan 08, 2017 | Samsung Home Security
How do i factory reset my verizon samsung 10 tablet?
To help you perform a factory reset if your Samsung tablet is working and powered ON, please follow the instructions mentioned below:
- It is recommended to back up all the data like Phone contacts, Email accounts, App settings and Downloaded apps, Music-Picture-Videos, Internet browsing data and Personal data from the tablet before performing factory reset.
- From the Home screen, navigate: Apps > Settings > Privacy.
- Click on 'Factory data reset'.
- Click on 'Reset tablet'.
- Click on 'Erase everything'.
- Allow several minutes for the factory data reset and reboot processes to complete.
Now, if in case you need to perform a factory reset if your Samsung tablet is powered OFF, please follow the instructions mentioned below:
- Press and hold the 'Volume Up button' and then briefly press the 'Power button' to power on the device.
- Release the 'Volume Up button' and the 'Power button' when the Samsung logo displays on the screen.
- Use the 'Volume Up button' to select the 'small android with an arrow' icon.
- Press the 'Volume down button'.
- From the Recovery Console screen, use the 'Volume button' to select 'Wipe Data / Factory Reset' then press the 'Power button'.
- Use the 'Volume button' to select 'Yes' then press the 'Power button'.
- Once the Wipe Data / Factory Reset has completed, use the 'Volume button' to select 'Reboot System Now' then press the 'Power button'.
GuruAid.com
May 24, 2016 | Samsung Tablets & eReaders
How do I reset it
Hard or factory reset is also called as master reset
  1. Power the device off. ...
  2. Press and hold the Volume up button then press and hold the Power button.
  3. When the Samsung logo appears, release all.
  4. Select wipe data/factory reset. ...
  5. Select Yes -- delete all user data.
  6. Select reboot system now.
How Do Hard Reset My Samsung Galaxy Tablet Perform hardware factory reset Samsung Galaxy Tab reg 2 10 1
Mar 16, 2016 | Tablets & eReaders
Restore factory default setting samsung GT-19305
Warning! All data will be lost after hard reset.Please make backup first.
1.Power off your phone
2.Press together volume up + home button + power button until you will se Samsung logo on the screen
3.Select with volume buttons "wipe data/factory reset" and press power button to confirm
4.Select "yes" and press power button to confirm
5.Wait until format is complete
7.Press power to confirm "reboot"
8.Wait until the phone restarts
That's it!
- See more at: http://factory-reset.blogspot.ro/2013/11/samsung-galaxy-s3-4g-i9305-hard-reset.html#sthash.IRpj0Oyt.dpuf
Aug 15, 2014 | Samsung Cell Phones
Vibration mode is not working on vibrate Mode as well as Sound Mode on my Samsung GT I8262
hear try or reset all if well done f we not ur hardware of cp is problem
How to Soft Reset or Reboot or Restart SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL ?
There are several ways to do soft reset or restart, the easy way to soft reset or reboot or restart SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL by remove the battery and then put again to the place then turn on the SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL. If you do not want to open the battery, you can do easily with pressing Power Button for several seconds and the option menu to turn off or reboot will appear.
#Option 1, How to Hard Reset SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL with software menu:
  1. Turn on SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL
  2. Make sure SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL battery is not empty
  3. Go to menu: Setting > Backup and reset > Factory Data Reset > Reset Device
  4. Choose Erase Everything
  5. SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL will do the process to Master Reset to Factory Default, wait for several minutes.
#Option 2, How to Hard Reset SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL with Hardware key button:
  1. Make sure the battery of SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL charge properly
  2. Turn off SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL
  3. Press and hold together : Volume Up Button + Home Button & continue with Power Button (together)
  4. If we see the menu at LCD screen, choose Wipe Data/Factory Reset with Volume Button to select and use Power Button to ok or enter.
  5. The SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL will doing the process of restoring to factory default.
#Option 3, How to Hard Reset SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL with Secret Key Code Security:
  2. Make sure the battery of SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL not empty
  3. dial or press number to call: *2767*3855#
  4. That number code will force format SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL
How to Restore and Reinstall Clean Android Operating system / firmware at SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL ?
Do not worry to do reinstall or restore the clean and default setting Android operating system or firmware at SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL because the file source already saved inside the SAMSUNG GALAXY CORE GT-I8260 / GT-I8262 DUAL ROM. If we think the phone really need to be reinstall or restore the default Android operating system or firmware, then we can do it easily by doing hard reset or master format step above, because the operating system will be reinstall by itself.
goodluck sir.
Jul 04, 2014 | Samsung Cell Phones
Why my samsung corby 2 lost ALL MOBILE CONTENT..!!! plz help me
its cant retrieve that files T_T
try dis
Samsung Corby II S3850 Specifications and Features
Samsung Corby II S3850 features a 3.2" TFT capacitive touchscreen with 240 x 320 pixels resolution, TouchWiz UI, and Accelerometer. It only has 26 MB built-in memory, but you can expand the storage capacity by using external memory car up to 16 GB. The connectivity features include Wi-Fi 802.11 b/g/n; Bluetooth v3.0 with A2DP; and microUSB v2.0. For the camera, the phone is only equipped with a modest 2 MP camera with Smile shutter and video recording capability.
Other features that you can find in this phone are: Stereo FM radio with RDS; Email; Push Email; Instant Messaging; Dolfin 2.0; SNS integration; MP4/H.264/H.263 player; MP3/WMA/WAV/eAAC+ player; DNSe (Digital Natural Sound Engine); Find Music recognition service; Organizer; Document viewer; Voice memo; Predictive text input; and more.
Dimensions: 109.9 x 60.6 x 11.7 mm (4.33 x 2.39 x 0.46 in)
Weight: 102 g (3.60 oz)
How to Reset Samsung Corby II S3850
You can perform a factory data reset to restore your Samsung Corby II S3850 to the factory default settings and erase all data on your phone's memory (messages, pictures, contacts, etc). To reset your Samsung Corby II S3850 simply type the following numbers on your phone: *2767*3855#
Or
Press the following button: Volume Up button + Menu button + Power button at the same time. The select Wipe Data Factory Reset using Volume button. (see below figure)
Keywords:
s3850 hard reset,samsung s3850 hard reset,hard reset s3850,
Apr 26, 2014 | Samsung GT S3850 Corby II
Reset samsung p1000
Tous les codes hard reset de Samsung
Oct 25, 2013 | Tablets & eReaders
How to factory reset samsung galaxy mini
turn off your SAMSUNG GALAXY MINI. press and hold POWER button + ENTER button (HOME KEY button) for reset menu. select FACTORY RESET using VOLUME KEY DOWN BUTTON button. Press the ENTER BUTTON (HOME KEY button to RESET. warning: all your phone data will be lost! God bless.
Feb 21, 2012 | Samsung Cell Phones
Need to do hard reset on samsung sph m910
Follow these simple steps to reset the phone
[hold the vol down button and call button press Same time and then release the power button]
and then menu appear, it work for sprint samsung intercept
Step one, Turn the power off. You need to pull the battery out and reinsert it if your phone gets frozen
Step two, Hold the Volume Down button
Step three, Press and release the Power button
Step four, a menu appears that allows for Fastbook, Recovery, Clear Storage, and Simlock
Step five, press the Volume Down button to Select Clear Storage
Step six, Press and release the Power button
Step seven, make your decision by touching one of the two options: Volume Up for YES and Volume Down for NO
If you selected YES, all data will be deleted from the phone including third-party applications. The Samsung Intercept will reboot to its original data.
Source:
http://samsung-phones-apps.com/how-to-hard-reset-samsung-intercept-sph-m910-to-factory-default-settings.html
Aug 16, 2011 | Samsung Cell Phones
Samsung SGH-X680 Cellular Phone Logo
300 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
