Question about Uniden CLX485 Cordless Phone
Uniden tru8880-2hs We are in Hospice care presently and our phones do not work. I noticed the phone shows Ring Off and I can't find anything pertaining to RING OFF in the menu. We have the UNIDEN power max 5.8ghz. It is presently hooked up through the Bright House system.Can you help me by calling my cell at 727-709-3560Bo Snider
  • 37 Answers
In standby mode, press the volume "up" key or volume
"down" key on the handset or base to select one of three
ringer volume (Off, Low, or High).
Posted on Nov 07, 2007
My Uniden 8055 is shoingno caller id when I ring my mobile phone, how do I make it show caller id on all outgoing calls?
Try this .go to menu,then settings , then call settings ,then press' Show caller Id.'I hope this works for you .
Feb 09, 2015 | Uniden DECT 6.0 Cordless Phone ID
How to turn ringer on
There are two possible reasons for the handsets not to ring when they are functioning properly. 1) You have the ring volume set to off. This would be done on each handset. With the phone in standby, press the volume up button until you reach the desired ring volume.
(There are 4 volume levels.)
2) You have toggled on the Do Not Disturb feature; this will apply to all of the handsets when started on one handset. Press and hold the # key (below 9) on a handset that is in standby. You should release the key when the phone stops showing the DND symbol. You can actually set the length of time in hours for the DND feature by pressing a number key (1-9) when the screen shows a prompt. If you don't press a number key within 5 seconds, the DND remains on until you press and hold the # key again.
If neither of the above solutions work, you need to check that the base is receiving calls properly. Check if a different phone (preferably a basic wired phone) rings properly when you get an incoming call. If another phone doesn't work, you'll need to check your wiring. If another phone works, contact Uniden if the XDECT8015 is under warranty.
Uniden has the manual for the XDECT8015 on the product page: . The direct link is .
I hope this helps.
Oct 03, 2014 | Lands Phones
My phone won't ring, but it shows up on my computer screen that someone is calling. How do i turn on the ring?
Since you didn't specify the model of your phone, select it from the list beginning at
to get the manual to see how to change the ringer volume.
Jun 17, 2011 | Uniden 5.8GHz Dual Cordless Phone
The phone rings once, then stops ringing
Remember to also disconnect direct tv receivers. I had the same problem untill I unplugged them from the phone line.
Jul 31, 2010 | Uniden Cordless Phone
Answering system records message after hang up
One thing to try and take note of is when the message does pick up on the "two ring" message present part do you hear on your side two full rings before the pick up?
It may be that the primary ring starts on the home side as does happen sometimes with VOIP service. If you are only hearing 1 or 1 1/2 rings before the message picks up then you might try hanging up after the second full ring thus knowing no messages are present and it should overcome your problem.
Dec 12, 2009 | Uniden Cordless Phone
No dial tone and no ring on Uniden 5.8 GHz
I have the same handset and the 2nd one seemed to stop working after working great for 2 yrs. I placed both sets together and hit the PAGE button on the main handsets cradle. Both phone's were paged and, for some reason, the 2nd handset reset. It worked for me...or at least, something in what I did worked. BTW, H1 and H2 shows in upper right side (or at least it did after I paged)...and I made sure to put the phones in the correct cradle (H1 is the main handset). I just did this so hoping it continues to work!
Sep 29, 2009 | Uniden Cordless Phone
Uniden TRU8885-2 Restarts every time an incoming phone call, start showing the Welcome message ....
YOUR batteries are bad and not giving full current to phone.Clean charging contact and see battery gets full charge. IFthe battery indicator will show full charge due to voltage but once if you remove battery and put it again indicator will be minimum. then replace batttery.
Oct 07, 2008 | Uniden TRU8885-2 Cordless Phone
Uniden phone 5.8ghz
Make sure that you have caller id service from your phone company. If you do not have a different phone with caller id borrow a working one from a friend and see if it shows up on a different phone. Let a phone ring at least twice to give caller id time to work. If a different phone does not show the call information call your service provider.
Jan 28, 2008 | Uniden TRU8885-3HS Digital Cordless Phone
Uniden CLX485 Cordless Phone Logo
290 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
