Question about Arris SURFboard SBG900 802.11g/b (motosbg900) Wireless Access Point
Adapt an sbg900 to a 2wire phone modem
Is there any way to use an sbg900 wireless cable modem/router with a 2wire 1000HG phone modem? Can the ethernet or usb outputs of the 2wire be adapted to the sbg900's cable input?
NO.
Posted on Aug 10, 2009
I need connect a wirelees router a this modem,u help me plzzz
most wireless routers are setup for cable modems out of the box all you need to do is run an Ethernet cable from your modem to your wireless router. you can then access your wireless router by the ip address and a pc hooked you directly to the router.
Feb 28, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Have a modem and xbox gold is that all i need to go on line
hmm you need a cable or dsl internet provider, a modem that works with a given provider a phone or cable line to goto the modem and an ethernet cable to goto your xbox, unless your xbox has wireles capability then you need ISP, Phone line or cable to the modem, ethernet to the wireless router, then configure the xbox to work with your wireless router
Dec 24, 2010 | Computers & Internet
Tryin to install router, but it says ethernet cable not connected? not good with computers,
You should have an ethernet cable between your modem and your router. If it's dsl or cable, either one will have an ethernet cable (looks like an oversized phone jack with more connectors).
BUT this is the important sequence to follow.
Assuming that your modem is working properly already, connect the ethernet cable between the router and the modem. then turn OFF both pieces of hardware AND any wireless computers. THEN turn on your Router first and let it boot all the way. Then once the router is booted, turn on the modem and let it cycle up.
Once this is done, you can turn on all the other computers etc on the system... that should get you up to working status!
Nov 16, 2009 | Linksys Wireless-G WRT54G Router
I have the RCA DCM425C cable modem and also Vonage phone service. So my modem ethernet connects to my Vonage internet. I would like to go wireless in my house. How would I do this?
You would connect from the output of the Vonage modem to the wireless router and then from the wireless router you can connect Ethernet to your desktop if you have one and then anything else can run off of the wireless.
or
get a wireless router / cable modem combo provided by companies such as netgear then you would connect the Vonage to the router through one of the available Ethernet ports and any other Ethernet connections to the router as well and anything else wireless would work wireless.
Nov 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
How do i connect a Linksys wrt54g2 to a arris cm450a
Your modem is capable of linking up to a router. What you do is take an ethernet cable and run it form the internet port on your modem to the internet/wan port on your router. From there you connect your pc's into the LAN ports on the router (typically labeled 1-5) if they are hardwired or you connect wirelessly with your laptop. You need to also power cycle/reset your modem when you plug your router in.
Jan 31, 2009 | Arris Touchstone 450a (CM450) Modem
Unable to connect Linksys wireless router to my arris cm450a
All routers will only work with ethernet. You would need to get an ethernet card installed in your computer. You can probably buy one for about 20.00 at Walmart. If you don't want to do this you can purchase a usb/ethernet adapter and still use the usb port on your computer. You can purchase one of these for around 5.00's on ebay. Just go to ebay and search for usb/ethernet adapter. Please rate if this has helped. Thanks.
Installation problem
YES!!!!! IT DOES NOT HAVE TO BE A SPECIFIC ETHERNET CORD TRY A REGULAR ONE OUT FIRST IF IT DOES NOT WORK IT WON'T SCREW ANYTHING UP IT WILL STILL BE WORKING JUST FINE SO JUST TRY A REGULAR ETHERNET CORD
Dec 14, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
How to change Linksys wireless router?
When you get cable internet, the cable company provides you with a modem (usually). From the cable modem you can hook up the Linksys router with an ethernet cable and it will work just fine. Hook the router up to the desktop or laptop with another ethernet cable if you need to make changes to the router security or whatever. The router address is generally 192.168.1.1. YOu can type that address right into the internet address and you router page shoud show up. If you have been using the Linksys router with the phone line all you need is to connect it to the cable modem to work. An ethernet cable is like a telephone line with a fatter connecter.
Nov 29, 2008 | Linksys Wireless-G WRT54G Router
Ethernet Port failure new router
Check the socket in either the router or the PC. I had the same problem, only with my modem. When I inspected the port, the pins were misaligned, causing it to drop a connection. I corrected mine with a screwdriver, which is not ideal but it works.
Jul 14, 2008 | Arris SURFboard SB5120 Modem
Installing wireless G router
Yes, you do need a modem (DSL, Cable). This router does not function as a modem.
Oct 01, 2007 | Belkin (F6D3230-4) Router (F6D32304)
Arris SURFboard SBG900 802.11g/b (motosbg900) Wireless Access Point Logo
134 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
