Question about Home
Bath leakage - Home
  • 68 Answers
Gonna need a little more info other then bath leakage. would like to know does it leak only when being used? is it a lot of water little water leeking? what type of bath it is fiberglass ,cast iorn, plastic? is there a shower head? age of bath?caulking condition around bath.
Posted on Jul 04, 2009
What would cause a FLYGT 3152 submersible communator pump to keep tripping at the breaker in the control panel
earth leakage is tripping the breaker from bad insulation or water in the motor or wires
Jun 19, 2017 | Pool & Spa
I am looking to replace my left hand bath panel on my beresford shower bath 1700mm white and can not find one can you help
Bath Panels can be very difficult to locate. If the Mfg of your bathtub does not have them available the best solution is to go to Home Depot or Lowes and look in their bath section for a generic panel you can trim to fit.
You may need to change both panels so they match.
Rod
US Parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
Jan 18, 2014 | American Bath Factory Home
Machine won't power on
I know the the B65 and B70 line had a problem with a very slow leak in one of the pumps, which over time leaked in to the AC/DC (electrical) transformer in the unit. You might be able to flip over your unit and look carefully for any signs of water leakage (typically shows up as a scale deposit, e.g. white stuff).
I would take it back to Bed Bath and Beyond and ask for an exchange. They wont ask for a receipt.
Jan 01, 2014 | Keurig Elite B40 Coffee Maker
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
Mar 10, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Can hot baths help with muscle strain?
Hot baths can be really helpful to relieve stress and tension and in particularly to loosen muscle strains which benefit from heat treatments.
Some people add essential oils to their baths such as lavender and then massage the affected areas while they are in the bath.
Good luck
Jan 15, 2013 | Health & Beauty
It is good to take baths every day?
Some people prefer to take baths rather than shower as a hot bath can be very relaxing, particularly if you have any stress that you want to relieve.
Many people prefer to shower rather than take a bath if they are washing after exercise, but it's really a matter of personal choice and wont do you any harm to bathe regularly.
My showerhead leaks when I fill up the bath tub, do you have any suggestions as what will correct this?
Hi nanbooboo...
Sorry
Your problem shower control valve is ok, but the shower pull that turns on the shower is non-repairable.
Replace your shower controller with a new one if you want to solve this leakage problem.
Please take time to rate me
Mar 18, 2011 | Peerless Industries Peerless& Single...
I have a massive leak where the tank joins the bowl assembly. so i guess i need a new gasket,,,,yes?
Yes you will need to replace the old gasket to prevent leakage, and when you put the new seal between the tank and base be sure to level the tank using a level and do not over tighten the bolts that hold the tank to the base.
I would also use a little silicone on the bolt heads that are inside of the tank to help prevent leaks from there also.
Free answer...Please rate me
Dec 22, 2010 | Kohler Bath Wellworth K-11471-0 White The...
I have a chip in my bath tub
This is something best handled by a tub resurfacer. It is an area of specialized repair. Results varied depending on material tub is made of. Cast iron tubs Show repair more so than fiberglass. Check for tub resurfacing in Repair Service Link.
Dec 09, 2008 | Home
Home Logo
132 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
