Question about Syntax SV266M Motherboard
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
What is the fastest socket A CPU my system will run?I would like to put in a athlon XP 2800 w/Barton Core. Most have 333 FSB. My MOBO is 266 FSB. Can i upgrade the bios and run the XP 2800 Barton?
  • 54 Answers
I could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Posted on Jun 29, 2009
Upgrade CPU on Matsonic MS8147C+
Unfortunately I think the Athlon XP is a 462 pin package and the MS8147C+ has a SocketA/Socket 462 socket for the CPU. The Athlon 64 3800+ is a 940 pin package and requires a AM2 socket, so this CPU will not physically fit.
Jan 18, 2014 | Matsonic MS8147C+ (N82E16813184008)...
ASUS A7S333 upgrade solution
MPN: A7S333
Product Type: Motherboard
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
Compatible Processors: Athlon, Duron, Athlon XP
Processor Socket: Socket A
Chipset Type: SiS745
Max Bus Speed: 266 MHz
BIOS Type: Award
Storage Controller: ATA-100
your max cpu would be proably 3200 anthlon xp ok
Jan 10, 2008 | ASUS A7S333 Motherboard
Upgrade the 1.6GHz CPU on L7VMM2 Motherboard
ECS Support > L7VMM2 motherboard > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=419&CategoryID=1&MenuID=50&LanID=0
Click on the CPU tab.
(Features / Specification / Download / Support / FAQ / CPU / etc)
Will support Up To an AMD Athlon XP 2600+,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
Maximum Front Side Bus support is 266Megahertz.
(Max FSB = 266MHz)
(Motherboard manual states 133MHz.
Note that AMD processors are 'Double-pumped'.
This = 266MHz )
Supports AMD Athlon, AMD Athlon XP, and AMD Duron, processors.
Note in the CPU Support chart where it states -
Socket 462 > AMD Athlon XP > 2600+ (.13u)
The .13u stands for 130nm core architecture technology.
(nm = NanoMeter.
1 Billionth of a Meter )
NOTE*
For the Socket 462 (Socket A) processors, the AMD Athlon XP models are the top of the line.
'Sempy', or Sempron processors are at the bottom.
Low L2 processor memory cache compared to Athlon XP or Duron models.
http://en.wikipedia.org/wiki/List_of_AMD_Duron_microprocessors
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors
http://www.cpu-world.com/
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20XP.html
Regards,
joecoolvette
Oct 13, 2012 | EliteGroup L7VMM2 Motherboard
Want to upgrade to amd athlon 2
Hi........Socket 939 is an outdated processor and not compatible with Athlon 2. You may find a 939 dual core on ebay, but suggest you save up for an AM3 mobo. Hank
May 10, 2010 | ASUS A8N-E Motherboard
What is the fastest CPU I can run on an Abit KN8 SLI socket 939?
Your mobo rans in Athlon 64 socket 939 compatable processor. The fastest processor there is that you can install in this mobo is AMD Athlon64 4000+ Socket 939 Processor. =)
Apr 30, 2010 | Abit KN8 SLi Motherboard
Cpu Models to upgrade Compaq Presario sr1920nx
CPU/Processor
  • Socket: 939
  • Supports the following processors:
    • AMD Athlon 64 X2 up to 4800+
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Cpu/Processor Type
Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Dec 22, 2009 | HP Compaq Presario SR1920NX PC Desktop
A7V266E/AA MB CPU
The Ol' Asus A7V266-E?
1.The fastest Front Side Bus setting is 266MHz
2.Uses Socket 462 AMD processors
3.Uses Athlon, Athlon XP, and Duron AMD processors.
I would stick with an AMD Athlon XP. Fastest one? Hmmm, I believe that would be the AMD Athlon XP 2600+
The one that operates at 2133MHz with a FSB of 266MHz. Part number AXDA2600DKV3C
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors#Athlon_XP_.22Thoroughbred_A.2FB.22_.28Model_8.2C_130_nm.29
Here is the Motherboard Manual for your Asus A7V266-E, (It's a PDF file download. Let it download all the way before looking through it)
http://www.motherboards.org/files/manuals/1/a7v266e-100.pdf
If the above direct link does not work for you, then go here,
http://www.motherboards.org/mobot/manuals/ASUS/A7V266-E/ (Click on -> Download <- all the way to the right of -> File:a7v266e-100.pdfVersion:--Release Date:--)
Go to Page 19, Item 2. NO POWER connected to computer, make sure the SYSCLK (System Clock) DIP switches are set to 133MHz.
1, 2, 3, and 4 are set to the OFF position for 133MHz.
All you will see is the ON. The switches go to the opposite side as shown in Item 2.
I'm sure they are set there however, as your 1900+ you have in right now, uses a 266MHz FSB.
I should explain.
AMD processors are Double-Pumped. Therefore the 133MHz setting will become 266MHz for the processor. (Intel processors are Quad-Pumped.
They are both the same Core, (Thoroughbred A/B, Model 8, 130nm), so a BIOS update shouldn't be necessary.
Jul 07, 2009 | ASUS A7V266-E (A7V266-E AA/PA/WOR)...
K133ASA via Apollo motherboard cpu upgrde
Socket A/462 can take any AMD K7 family processor. The fastest you could get would be the Athlon XP 3200 I believe, but that could also include the Athlon 1400 and the Duron 1800. So it looks like you can make a significant upgrade of yhe processor.
Jan 28, 2009 | Computers & Internet
How to upgrade
Here is the list of compatible processors for your motherboard:
AMD Athlon 650, 700, 750, 800, 850, 900, 950, 1.0G, 1.1G, 1.2G, 1.3G, 1.33G, 1.4G (Thunderbird)
AMD Athlon MP 1.0G, 1.2G, 1500+, 1600+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon MP 2000+, 2200+, 2400+, 2600+ (Thoroughbred)
AMD Athlon MP 2800+ (Barton)
AMD Athlon XP 1500+, 1600+, 1700+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon XP 1600+, 1700+, 1800+, 1900+, 2000+, 2100+, 2200+, 2400+, 2600+, 2700+, 2800+ (Thoroughbred)
AMD Athlon XP 2500+, 2600+, 2800+, 3000+, 3200+ (Barton)
AMD Athlon XP 2000+, 2200+, 2400+ (Thorton)
AMD Sempron 2200+, 2300+, 2400+, 2500+, 2600+, 2800+ (Thoroughbred)
AMD Sempron 2200+, 2400+, 2500+, 2600+, 2800+ (Thorton)
AMD Sempron 3000+ (Barton)
AMD Duron 600, 650, 700, 750, 800, 850, 900, 950 (Spitfire)
AMD Duron 1.0G, 1.1G, 1.2G, 1.3G (Morgan)
AMD Duron 1.4G, 1.6G, 1.8G (Applebred)
You motherboard uses a "Socket A" CPU and therefore has limits to how high you can go.. I would recommend the XP 2200 or 2400+ as a good choice, but you can make your own choice.
Apr 03, 2008 | AMD Duron , 750 MHz Processor
Fastest CPU available for the K7N2G?
Look for socket A processors and ignore the XXXX+ and focus on the XXXXMHz rating (the MoBo's manufacturer's support site will give you the max processor your Board will handle). Since you mention that your MoBo is 4 to 5 years old, you'll probably better serve yourself to replace the MoBo and processor (you'll be able to upgrade to a much better/faster processor by upgrading both, and shouldn't cost that much more), and probably be happier with the result. You may want/need to upgrade your Power supply while you are at it too.
Mar 29, 2008 | MSI K7N2G-L Motherboard
Syntax SV266M Motherboard Logo
535 people viewed this question
Top Syntax Computers & Internet Experts
Roy May
Gbenga
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
