Question about Kicker KX300.4 Car Audio Amplifier
Kicker protection light won't shut off
Need help trouble shooting my amps protection light
  • 655 Answers
Hello newwithtech,
There are 4 possible causes for the amp to go into protection mode. Kicker calls it SORT for Short, Overvoltage, Reverse polarity, and Thermal. If the amp has been in and working properly, it's probably not reverse polarity. And if it goes immediately into protection when power is connected, I'd rule out thermal. So it's probably either a short or overvoltage.
1) Start by removing the speaker wires and see if the amp powers up properly. If it does, one or more of the speakers is shorted or grounded.
2) Test each pair of wires with a multimeter set to the lowest resistance (ohms) scale. Measure across each pair and from each individual wire to ground. Across each pair, the meter should read about 3-4 ohms. From each individual wire to ground, it should read infinity. If the meter reads "0" ohms (shorted) in any test, you have located the problem.
3) If the speaker wires test OK, set the meter to read DC volts and measure the voltage at the amp positive terminal. If the voltage is higher than 16V or lower than 9V, you've located the problem.
4) If the voltage is OK, remove the RCA inputs and test for proper power up. If it powers up without going into protection, you have a shorted/grounded input. Replace them one at a time to determine which one(s) is/are defective and replace the cable.
If these tests show all the wiring is good and the voltage is OK, the amp is probably shorted internally (most likely an output MOSFET), and requires service at the component level. You need to take it to your local audio shop or send it to Kicker for repair.
Hope this helps.
Posted on Jun 29, 2009
Kicker kx850.4 protection light stays on know power light
Check power make sure you have solid 12 volts. Disconnect speakers, shorted speaker can cause protection mode to engage. If still in protect mode will need to repair. Kicker does out of warranty repairs on kx series amps or try T.I.P.S contact at linearpower.com. Iirc Ray @ tips was one of the engineers at kicker back when kx series was introduced.
Jul 19, 2016 | Kicker Car Audio & Video
I have a kicker 500.2 red protection light is on and red light on top of amp flashes every couple seconds. Have checked all connections and other amp in truck works good. I bought two of these amps and...
Disconnect all the wires except the three main power wires, ground, 12v battery and remote. Now, turn on your radio, if the protect light is still on then there's an internal short in the amp. If the light turns green, then there's a short in either the auxiliary cables or the speaker outs. If it turns green, then troubleshoot the other wires that plug into the amp by connecting them one at a time until the protect light comes on, which will tell you that there's a problem with that speaker/aux wire.
Jul 25, 2011 | Kicker KX500.2 Car Audio Amplifier
Problem with Eathquake amp 2000w
the amp dose not have any such internal batery it is probly tosted call me 256-698-9903
Jul 05, 2010 | Earthquake Sound PH-D2 Car Audio Amplifier
It plays for a couple of seconds and then runs over to protect mode and stays there
usualy means there is a problem with the speakers, they may be wired wrong, short in the wires or the voice coil in the speakers themselves. best way to trouble shoot is to power the amp with no speakers hooked to it, if it only goes ito protect with the speakers hooked to it, the the problem is with the speakers, not the amp.
Aug 17, 2009 | Kicker KX400.1 Car Audio Amplifier
I think ma kicker kx1200.1 amp is blown or ma kicker L7 are gone
that would be the amp. sorry to say. when a wire crosses over, it sends a shock through the amp, there are a few things to try just to see if you fried the amp. the first thing to try is to move your ground to a different location. second thing to look at would be the fuses. alot of times the fuses will blow at the slightest shock. the amp will still turn on if you have an amp with 2 fuses, it just wont be getting all the power it needs, which could be causing your problem. also, it is worth the hour and a half to mount everything down in your vehicle. you might check the kicker website, because i have herd rumors that kicker offers a lifetime warranty on almost all of their products. best of luck, and i hope you didnt fry your amp.
Apr 09, 2009 | Kicker KX1200.1 Car Audio Amplifier
Protection light is on
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Dec 26, 2007 | Kicker KX600.1 Car Audio Amplifier
Amplifier wont turn on.
Generally, when an amplifier goes into protection when you attempt to power it up, it means that the output transistors have failed.
Measure the DC voltage across the B+ and ground terminals as well as across remote and ground. If you have less than 11 volts when the amp tries to power up, the amp could be shutting down due to low voltage.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Oct 25, 2007 | Kicker ZX10001 Car Audio Amplifier
Kicker KX300.4 Car Audio Amplifier Logo
1,232 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
